  3. Vera
  4. Wind sensor plug in files for Vera (UI5)
16 Posts 3 Posters 6.8k Views 3 Watching
  • BartEB
    BartEB
    BartE
    wrote on last edited by BartE
    I recently created a MySensor modules which records the wind speed and direction, to make the readings visible in my Vera box I've created Vera plug in files. From whoever likes them to use, I just post them here.
    Unfortunately i was not able to add a nice anemometer icon. The plug in is tested with UI5, they might work with UI7.
    Cheerz Bart
    WindSensor_Vera.zip
      Thanks @BartE.
      Would be great if you could create a git pull request with these files against the Vera plugin project.
      • BartEB
        BartEB
        BartE
        The pull requests should be available now.
        • BartEB
          BartEB
          BartE
          @hek I did make a small update to this device plugin together with 2 other Vera devices
          • Mutlimeter handling V_VOLTAGE, V_CURRENT, V_IMPEDANCE
          • LcdText handling V_TEXT
          I've created one pull-request for it
            Thanks @BartE, you are a saviour.
            I've had a hard time keeping up with the Vera plugin while doing a lot of work on the MySensors library.
              If you want to host a device icon here (like I do for the other devices), let me know.
              • BartEB
                BartEB
                BartE
                @hek Thanx for the offer. With the three devices i managed to reuse existing icons although the wind icon can be improved
                Are there any other Vera plugins you like to see (still busy with vosmont for the RGB device) ?
                (The best way to support an opensource project is to contribute code :-))
                hekH 1 Reply Last reply
                • BartEB BartE
                  @BartE said:
                  (The best way to support an opensource project is to contribute code )
                  So true.
                  Well, supporting RGB/RGBW probably is top on the list. :) Good priority.
                  Another long forgotten device is the IR-thingie. I suspect we need to discuss how this should work and/or if we'd need a couple more V-types to do a more useable thing of it.
                  As ir-codes often is too long to sent over the air I imagine we'd have to store them in the node itself and just sending some index back and forth. So a Vera device probably should have a record/delete functionality and a way of launching a few (10?) ir commands via GUI and the rest by lua if needed.
                  CMD (payload)
                  IR_SEND (index) - Instructs node to send an ir code on index X
                  IR_RECEIVE (index) - Received ir code index
                  IR_RECORD (index) - Initiates node to go into a record state, recoding into index X
                  IR_DELETE (index) - Maybe superfluous? One could just overwrite an old index?
                  Maybe an advanced tab like this:
                  0 [ Send IR 0 ] [ Record ] [ Delete ] Name: [ ___________ ]
                  1 [ Send IR 1 ] [ Record ] [ Delete ] Name: [ ___________ ]
                  2 [ Send TV-ON ] [ Record ] [ Delete ] Name: [ TV-ON_______ ]
                  3 [ Send IR 3 ] [ Record ] [ Delete ] Name: [ ___________ ]
                  And dashboard device
                  Last Received IR code: 1
                  Last Sent IR code: TV-ON
                  Well, just from the top of my head. Open for discussion of course.
                  • BartEB
                    BartEB
                    BartE
                    @hek : i did made a small windsenor icon like you suggested
                    Can you please provide the full link once it is uploaded?
                    About the IR module:
                    This actually sounds like a great idea.
                    I will create a plug in for this idea, let me think about this for a couple of days.
                    Do you already have experience with a certain IR-record Arduino project?
                      Here you go: http://www.mysensors.org/icon/wind.png
                      • BartEB
                        BartEB
                        BartE
                        @hek That's fast, i've made pull request for the plug in as well so the icon is used
                          You're fast too! Great.
                          • BartEB
                            BartEB
                            BartE
                            @hek i've implemented your IR request see: http://forum.mysensors.org/topic/2413/ir-record-and-playback-module
                            and the pull request i did make.
                            These icons are needed for Vera to work properly
                            abrmartinA 1 Reply Last reply
                            • BartEB BartE
                              abrmartinA
                              abrmartinA
                              abrmartin
                              @BartE , hello I have a Fibaro RGBW module and an analog WindSensor and For me it doesn't work. Should your pluging work with these devices or it was designed for another components?
                              Thanks in advance
                              BartEB 1 Reply Last reply
                              • abrmartinA abrmartin
                                Thanks in advance
                                BartEB
                                BartEB
                                BartE
                                @abrmartin What is the problem?
                                The Fibaro RGBW module should work without MySensors directly connected to your home automation system.
                                What is the issue with the wind sensor maybe you can give some more detail.
                                • BartEB BartE
                                  abrmartinA
                                  abrmartinA
                                  abrmartin
                                  @BartE ,
                                  I'm trying to set up an analog anemometer in my veralite system using the RGBW controller from fibaro. The problem I have is: which plugging should be used to let RGBW controller read the input from the anemometer and display the wind speed value in Km/h?
                                  I'm not a programmer and all my configurations applied to my veralite was using internet.
                                  I have spent lot of weeks looking for a solution but until this moment no progress achieved.
                                  Any support from your side will be very very appreciated.
                                  Thanks a lot.
