  3. Vera
  4. Wind sensor plug in files for Vera (UI5)
16 Posts 3 Posters 6.8k Views 3 Watching
  • BartEB
    BartEB
    BartE
    wrote on last edited by BartE
    @hek Thanx for the offer. With the three devices i managed to reuse existing icons although the wind icon can be improved
    Are there any other Vera plugins you like to see (still busy with vosmont for the RGB device) ?
    (The best way to support an opensource project is to contribute code :-))
    hekH 1 Reply Last reply
    • BartEB BartE
      @BartE said:
      (The best way to support an opensource project is to contribute code )
      So true.
      Well, supporting RGB/RGBW probably is top on the list. :) Good priority.
      Another long forgotten device is the IR-thingie. I suspect we need to discuss how this should work and/or if we'd need a couple more V-types to do a more useable thing of it.
      As ir-codes often is too long to sent over the air I imagine we'd have to store them in the node itself and just sending some index back and forth. So a Vera device probably should have a record/delete functionality and a way of launching a few (10?) ir commands via GUI and the rest by lua if needed.
      CMD (payload)
      IR_SEND (index) - Instructs node to send an ir code on index X
      IR_RECEIVE (index) - Received ir code index
      IR_RECORD (index) - Initiates node to go into a record state, recoding into index X
      IR_DELETE (index) - Maybe superfluous? One could just overwrite an old index?
      Maybe an advanced tab like this:
      0 [ Send IR 0 ] [ Record ] [ Delete ] Name: [ ___________ ]
      1 [ Send IR 1 ] [ Record ] [ Delete ] Name: [ ___________ ]
      2 [ Send TV-ON ] [ Record ] [ Delete ] Name: [ TV-ON_______ ]
      3 [ Send IR 3 ] [ Record ] [ Delete ] Name: [ ___________ ]
      And dashboard device
      Last Received IR code: 1
      Last Sent IR code: TV-ON
      Well, just from the top of my head. Open for discussion of course.
      • BartEB
        BartEB
        BartE
        @hek : i did made a small windsenor icon like you suggested
        Can you please provide the full link once it is uploaded?
        About the IR module:
        This actually sounds like a great idea.
        I will create a plug in for this idea, let me think about this for a couple of days.
        Do you already have experience with a certain IR-record Arduino project?
          Here you go: http://www.mysensors.org/icon/wind.png
          • BartEB
            BartEB
            BartE
            @hek That's fast, i've made pull request for the plug in as well so the icon is used
              You're fast too! Great.
              • BartEB
                BartEB
                BartE
                @hek i've implemented your IR request see: http://forum.mysensors.org/topic/2413/ir-record-and-playback-module
                and the pull request i did make.
                These icons are needed for Vera to work properly
                abrmartinA 1 Reply Last reply
                • BartEB BartE
                  abrmartinA
                  abrmartinA
                  abrmartin
                  @BartE , hello I have a Fibaro RGBW module and an analog WindSensor and For me it doesn't work. Should your pluging work with these devices or it was designed for another components?
                  Thanks in advance
                  BartEB 1 Reply Last reply
                  • abrmartinA abrmartin
                    Thanks in advance
                    BartEB
                    BartEB
                    BartE
                    @abrmartin What is the problem?
                    The Fibaro RGBW module should work without MySensors directly connected to your home automation system.
                    What is the issue with the wind sensor maybe you can give some more detail.
                    • BartEB BartE
                      abrmartinA
                      abrmartinA
                      abrmartin
                      @BartE ,
                      I'm trying to set up an analog anemometer in my veralite system using the RGBW controller from fibaro. The problem I have is: which plugging should be used to let RGBW controller read the input from the anemometer and display the wind speed value in Km/h?
                      I'm not a programmer and all my configurations applied to my veralite was using internet.
                      I have spent lot of weeks looking for a solution but until this moment no progress achieved.
                      Any support from your side will be very very appreciated.
                      Thanks a lot.
