  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 105.3k Views 28 Watching
  • G GertSanders
    @yveaux indeed. It seems there is always some other thing to do first. Moving my desk was part of a greater reorganisation of desks and rooms. I set myself deadlines to be able to advance a little (next one is 16 May: lasercutting boxes at the FabLab), but still progress is slow.
    The fact that my switch to version 2.2.0 on sensors and on ethernetgateway on Raspberry is not going well, also slows down progress. Step by step ...
    Y Offline
    Y Offline
    @gertsanders said in Your workshop :):
    Well, if you need any help or have suggestions how to make the transition more smooth, you know where to find us!
    Good to have you back on the forum though :+1:
    G 1 Reply Last reply
    • Y Yveaux
      G Offline
      G Offline
      GertSanders
      wrote on last edited by GertSanders
      #162
      @yveaux I'm not sure the issues is with the MySensors part. The gateway listens, but presenting a new node crashes Domoticz. After reboot I do see the new sensor and can receive and show updates, but the "new node" part is what bugs me now (I made a new node with atmega1284p which I want to add to my network)
      I am using the beta version of the gateway & Domoticz
      D 1 Reply Last reply
      • G GertSanders
        Why are you using a beta version? I thought 2.2.0 was in stable release?
        • D dbemowsk
          G Offline
          G Offline
          GertSanders
          @dbemowsk like to push my luck I guess ;-)
          It seems the latest Domoticz beta (9379 build date 28.04.18-09:18:07) has a problem with presentation of new sensors. So I will have to sweat it until they fix that.
          I compiled the gateway on Raspberry also with the beta version (after trying the stable version first), as it was mentioned that this could fix communication errors. No luck so far.
          Bu this discussion of my problem should be on another forum branch.
            Use the 2.2 stable, your is not a radio communication issue.
              G Offline
              G Offline
              GertSanders
              @gohan
              Indeed, it is a Domoticz beta issue
              • B Offline
                B Offline
                bjacobse
                As I have updated my workshop, so I no longer sit at my family kitchen table, but instead have a man-cave, behind a sliding-door closet, next to the water-heater
                T 1 Reply Last reply
                • B bjacobse
                  T Offline
                  T Offline
                  tbowmo
                  @bjacobse something is wrong, it's way to organized ;)
                  B 1 Reply Last reply
                  • T tbowmo
                    B Offline
                    B Offline
                    bjacobse
                    @tbowmo
                    Well I must admit, it's just put in place - which means I have not yet started to use it - It must be messy when in use :-)
                    • T Offline
                      T Offline
                      tbowmo
                      #170
                      resurrecting this old thread :)
                      I got thrown out of my old mancave, and in to a small corner in the main building (the oldest son, aged 21, needed a place to stay, as his 19 year old sister didn't want to share room with him)
                      Anyways, I have moved from a 240x60cm desk to a 120x80 desk, and no storage space around me, other than a small office cabinet on wheels. Which means that I have to constrain myself, and find some alternative setups. As I have to work from home these days due to corona, I treated myself with a monitor mount for my 3 screens.
                      As a bonus, I can now use the space below the monitors for my tools (power supply and soldering iron,and probably the oscilloscope as well, when I get to it). I'm re-arranging stuff every other day, to figure out the best setup, and remove cable clutter (which isn't easy).
                      monteM B 2 Replies Last reply
                      • T tbowmo
                        monteM Offline
                        monteM Offline
                        monte
                        @tbowmo is that KDE?
                        • monteM monte
                          T Offline
                          T Offline
                          tbowmo
                          @monte said in Your workshop :):
                          Nope, Ubuntu / gnome, but with a tool bar at the bottom of the screen.
                          monteM 1 Reply Last reply
                          • T tbowmo
                            monteM Offline
                            monteM Offline
                            monte
                            @tbowmo nice! I was too lazy to open full-size image :)
                            • T tbowmo
                              B Offline
                              B Offline
                              bjacobse
                              @tbowmo
                              Looks really good, hope you will spend many good hours doing some fun stuff ;-)
                              • B bjacobse
                                @tbowmo
                                T Offline
                                T Offline
                                tbowmo
                                @bjacobse thanks, hope so too.
                                Just looked back into the thread, I posted a picture of my old workshop back in 2016, still the same tools around, just a smaller desk to work on.
                                / Thomas
                                • skywatchS Offline
                                  skywatchS Offline
                                  skywatch
                                  I thought I'd share a part of my 'workshhop'. Only part of it due the rest being in a bit of a mess at the moment, so here is the 'good' bit......
                                  Y mtiutiuM dzjrD 3 Replies Last reply
                                  • skywatchS skywatch
                                    Y Offline
                                    Y Offline
                                    @skywatch if this is the good & organised bit I would die to see the rest :rolling_on_the_floor_laughing:
                                      mtiutiuM Offline
                                      mtiutiuM Offline
                                      mtiutiu
                                      @skywatch
                                      OMG...
                                        dzjrD Offline
                                        dzjrD Offline
                                        dzjr
                                        @skywatch that is looking very good, but why would you measure the wind speed of your workshop?
                                        :innocent:
                                        • skywatchS Offline
                                          skywatchS Offline
                                          skywatch
                                          @Yveaux - I don't think it is really worth dying over ;)
                                          @mtiutiu - I guess you are referring to the lack of beer on the bench. Don't worry I will be sorting that out very soon! :)
                                          @dzjr I eat a lot of hot spicy food and you can never be too careful!
                                          Actually the wind speed anemometer is something I 3D printed. The problem is that I need to calibrate it and since I don't have access to a wind tunnel I was thining of securing it to the car and driving at different speeds to note the readings.
                                          Only 2 problems I have found with that so far. 1 - In the UK there are very few calm days. 2 - We have been in lockdown for nearly 2 months and I can't go out to test it.
                                          So it just sits there mocking me for going to all the trouble of creating it in the first place!
