  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 106.3k Views 28 Watching
  • Nca78N Nca78
    @dbemowsk I bought from AliExpress in the cheapest price range too (but not so cheap with shipping) and it's been working very well until now.
    I bought this model, it's not available any more but there are plenty of seller with the exact same brand and model (Youyue 858D+), with extra nozzles (I had 3 only, now it seems 6 is standard) and accessories (I had none):
    https://www.aliexpress.com/item/Hot-Air-Gun-700W-UYUE-858D-ESD-Soldering-Station-LED-Digital-Heat-Gun-Desoldering-Station-Upgrade/32657929118.html
    I opened it after reception to check for the common safety problems that were reported with first versions of the 858D/D+ models and it was safely wired and earthed.
    It's also show the right temperature when overheating (it was not the case in the first models) so you know when to wait to avoid burning your board (don't worry this is only happening at start-up when it's heating fast from ambient temperature).
    dbemowskD
    dbemowskD
    @nca78 They have a youyue 858D and it is $92 and another for $63. The ones I am looking at are these for $30 with free shipping:
    • tbowmoT
      tbowmoT
      tbowmo
      Found an old post at eeevblog, where they hacked the Youyue heat gun. It was using atmega328p, so I am considering that one (even though they might have changed hardware since then. You'll never know what the sneaky people are doing ;))
      dbemowskD 1 Reply Last reply
      • tbowmoT tbowmo
        dbemowskD
        dbemowskD
        @tbowmo So what improvements/changes did they do with the hack?
        tbowmoT 1 Reply Last reply
        • dbemowskD dbemowsk
          tbowmoT
          tbowmoT
          tbowmo
          @dbemowsk better PID tuning etc.
          More info here https://www.eevblog.com/forum/reviews/youyue-858d-some-reverse-engineering-custom-firmware/
          • dbemowskD
            dbemowskD
            Still need to do some setup and sorting of things, but here are some pics of my newly remodeled workshop area.
            I really need to get rid of that old Leader analog scope and get myself a DSO. It is a conversation piece though. I have it connected to my old heathkit square/sine wave audio function generator. Does anyone have a recommendation on a cheaper DSO that would be good for microcontroller work?
            • GertSandersG
              GertSandersG
              GertSanders
              I moved my desk to a new spot in the house and reoriented the desk. Still a mess, but that is how my mind seems to work these days: lots of stuff in parallel ...
                Multiple parallel projects is a common problem :D
                • GertSandersG GertSanders
                  @gertsanders so that's what kept you busy last 7 months! :rolling_on_the_floor_laughing:
                    dbemowskD
                    dbemowskD
                    @gohan Agreed. I have up to 5+ going at any given time. That way I have something to do when one project goes stale or gets put on hold for a while.
                    • YveauxY Yveaux
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @yveaux indeed. It seems there is always some other thing to do first. Moving my desk was part of a greater reorganisation of desks and rooms. I set myself deadlines to be able to advance a little (next one is 16 May: lasercutting boxes at the FabLab), but still progress is slow.
                      The fact that my switch to version 2.2.0 on sensors and on ethernetgateway on Raspberry is not going well, also slows down progress. Step by step ...
                        @gertsanders said in Your workshop :):
                        Well, if you need any help or have suggestions how to make the transition more smooth, you know where to find us!
                        Good to have you back on the forum though :+1:
                        • YveauxY Yveaux
                          GertSandersG
                          GertSandersG
                          GertSanders
                          #162
                          @yveaux I'm not sure the issues is with the MySensors part. The gateway listens, but presenting a new node crashes Domoticz. After reboot I do see the new sensor and can receive and show updates, but the "new node" part is what bugs me now (I made a new node with atmega1284p which I want to add to my network)
                          I am using the beta version of the gateway & Domoticz
                            dbemowskD
                            dbemowskD
                            Why are you using a beta version? I thought 2.2.0 was in stable release?
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @dbemowsk like to push my luck I guess ;-)
                              It seems the latest Domoticz beta (9379 build date 28.04.18-09:18:07) has a problem with presentation of new sensors. So I will have to sweat it until they fix that.
                              I compiled the gateway on Raspberry also with the beta version (after trying the stable version first), as it was mentioned that this could fix communication errors. No luck so far.
                              Bu this discussion of my problem should be on another forum branch.
                                Use the 2.2 stable, your is not a radio communication issue.
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @gohan
                                  Indeed, it is a Domoticz beta issue
                                  • bjacobseB
                                    bjacobseB
                                    bjacobse
                                    As I have updated my workshop, so I no longer sit at my family kitchen table, but instead have a man-cave, behind a sliding-door closet, next to the water-heater
                                    • bjacobseB bjacobse
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @bjacobse something is wrong, it's way to organized ;)
                                      bjacobseB 1 Reply Last reply
                                      • tbowmoT tbowmo
                                        bjacobseB
                                        bjacobseB
                                        bjacobse
                                        @tbowmo
                                        Well I must admit, it's just put in place - which means I have not yet started to use it - It must be messy when in use :-)
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          #170
                                          resurrecting this old thread :)
                                          I got thrown out of my old mancave, and in to a small corner in the main building (the oldest son, aged 21, needed a place to stay, as his 19 year old sister didn't want to share room with him)
                                          Anyways, I have moved from a 240x60cm desk to a 120x80 desk, and no storage space around me, other than a small office cabinet on wheels. Which means that I have to constrain myself, and find some alternative setups. As I have to work from home these days due to corona, I treated myself with a monitor mount for my 3 screens.
                                          As a bonus, I can now use the space below the monitors for my tools (power supply and soldering iron,and probably the oscilloscope as well, when I get to it). I'm re-arranging stuff every other day, to figure out the best setup, and remove cable clutter (which isn't easy).
                                          monteM bjacobseB 2 Replies Last reply
