  3. Vera
  4. VERA 2 Device Install
64 Posts 11 Posters 42.7k Views 1 Watching
  • S sailhome
    I have been using a VERA 2 with the Arduino usb gateway for two weeks now. I have two nodes, one with a motion sensor and the second node with a humidity/temp sensor. They are working well. I had to reload the VERA UI several times after I uploaded the files to VERA. After the reboots the gateway worked properly. I have more Arduinos and sensors on order, these things are great. Other than affirming that a VERA 2 will work I can't be of much more help.
    DeltaNu1142
    wrote on last edited by DeltaNu1142
    #41
    I wish I could attribute my troubles between this plugin & my Vera 2 to something. I hung it up a while ago. I've since installed ping sensors & then uninstalled them, but they worked as expected while I had them.
    Let me ask this... should you be able to install the Arduino plugin without the hardware, and get... anything? All I ever saw in the plugin was a blue circle. It's as if the plugin never configured.
    • J Offline
      J Offline
      jmmorgan
      I am just starting to install my plug in for VERA 2. It created the plug in without a problems. When Vera starts the plug in it states that the serial port has to be selected. How do I do that? Under the serial port tab there is only my serial port for my alarm system. If I ssh into vera I can see both USB ports. My alarm port (usbserial.c: PL-2303 converter now attached to ttyUSB1 (or usb/tts/1 for devfs)0 and the gateway USB (usbserial.c: CP210X converter now attached to ttyUSB0 (or usb/tts/0 for devfs)). So I know it connects, but I do not know how to tell the plug in to use that port. Any help would be appreciated.
      John
      • hekH Offline
        hekH Offline
        It usually pops up on the serial configuration page. You're using a Arduino Nano right?
        J 1 Reply Last reply
          J Offline
          J Offline
          jmmorgan
          @hek I am using Arduino Nano, but it does not pop up in the serial configuration page. I have read a lot of the post on USB to serial connection on the Vera forum, but no luck.
          JOhn
          • J Offline
            J Offline
            jmmorgan
            After much effort, I got it to recognize the serial gateway: Here what I did
            Log into WinSCP
            Run lsusb
            You should see a line similar to this. Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x Composite Device. The 10c4 is the vendor and the ea60 is the product.
            Find
            /etc/cmh/serproxy.port
            Open it up and make sure it has the line
            vendor:10c4 product:ea60
            If serproxy.port does not exist, manual create it.
            Reboot, Reboot and hope.
            Now on to the next step. I hope it is easier.
            • J Offline
              J Offline
              jmmorgan
              Well, I knew it was to good to be true. The plug-in loads properly without error and I have set the serial port. However, when I hit the start button (is it suppose to change color and stay that color until is stop) and reset the sensor, nothing happens. What is my next step. The sensor is sending a request for node id, which the gateway acknowledges, but it never send the node ID back. I tried looking at the Vera log, but there are just too many entries.
              hekH 1 Reply Last reply
              • J jmmorgan
                hekH Offline
                hekH Offline
                @jmmorgan
                > grep Arduino /var/log/cmh/LuaUPnP.log
                Only shows Arduino related stuff from the log.
                • B Offline
                  B Offline
                  blacey
                  When my Vera3 fails to show the USB port for the Gateway (typically after a power cycle), I do the following to get it to recognize it.
                  1. Unplug the gateway USB cable from the Vera3's USB port
                  2. Click Reload on the upper right of the Vera dashboard and wait for reload to finish
                  3. Plug the gateway USB cable into the Vera3's USB port
                  4. Click Reload on the upper right of the Vera dashboard and wait for the reload to finish
                  5. Navigate to Develop Apps->Serial Port to configure the port.
                  I don't know why the Vera removes the USB port if the device is power cycled while the gateway is connected but the steps above seem to reliably resolve it for me.
                  • J Offline
                    J Offline
                    jmmorgan
                    Here is my log. It seems the gateway startup ok and send the inclusion command. The node requests the ID, which the gateway acknowledge, but nothing happens after that.
                    jmmlog1.pdf
                    • hekH Offline
                      hekH Offline
                      I can't see that the inclusion mode was started in the log.
                      And what does the log say on the sensor when it requests an id? Does it receive anything?
                        J Offline
                        J Offline
                        jmmorgan
                        @hek the sensor send a request for the ID and the gateway acknowledge the request, but never send the id.
                        • hekH Offline
                          hekH Offline
                          Hmm.. yes.. it looks like serial communication only works one-way (from Nano to Vera) but not the other direction.
                          Gateway doesn't even reply on the request for version message.
                          How is this even possible? Some strange setting in Serial port configuration?
                            J Offline
                            J Offline
                            jmmorgan
                            @hek
                            There is my serial configuration screen.
                            upload-3d78c5ff-1b91-40c0-b8cd-3c3b66217419
                            • W Offline
                              W Offline
                              wmylionel
                              Could try reducing the baud rate between gateway and vera. I had trouble communicating with the serial gateway at the highest speed (only 1 way communication), reducing to 9600 solved it.
                              • hekH Offline
                                hekH Offline
                                yep, that might worth a try.
                                To update baud rate on gateway side, edit the following line in Sensor.h
                                #define BAUD_RATE 115200
                                  J Offline
                                  J Offline
                                  jmmorgan
                                  @hek
                                  How do you set it to 9600 in the Vera mysensor plug in? If I set the Vera serial port to 9600, the mysensor plug in states that it needs to be set to 115200 and the plug in fails.
                                  John
                                  • hekH Offline
                                    hekH Offline
                                    Edit the
                                    L_Arduino.lua
                                    You'll find it somewhere at the top.
                                      Edit the
                                      L_Arduino.lua
                                      J Offline
                                      J Offline
                                      jmmorgan
                                      @hek
                                      I set the L_Arduino.lua to 9600. The mysensor plugin now states to set the it 9600. I set it to 9600 and reload. It again states to set the serial port 9600 (but it is set to 9600), and the plugin fails. Is there something else I need to change?
                                      B 1 Reply Last reply
                                      • J jmmorgan
                                        @hek
                                        B Offline
                                        B Offline
                                        BulldogLowell
                                        wrote on last edited by BulldogLowell
                                        #59
                                        @jmmorgan
                                        what value is your serial port configuration page showing now?
                                        • B BulldogLowell
                                          @jmmorgan
                                          J Offline
                                          J Offline
                                          jmmorgan
                                          @BulldogLowell It shows 9600
