  3. Vera
  4. VERA 2 Device Install
64 Posts 11 Posters 42.7k Views 1 Watching
  • D Offline
    DeltaNu1142
    As a test, I created a Vacation Ghost device, and it worked fine. I can send you the log of that, if you'd like--please message me an email address.
    • hekH Offline
      hekH Offline
      wrote on last edited by hek
      #22
      In this screenshot:
      http://forum.micasaverde.com/index.php/topic,24057.msg170334.html#msg170334
      The log says"D_Arduino1.xml so device XXX is offline".
      This indicates that there was something that failed when your Vera tried to create the device. It would have been interesting to see te lines just before. It might contain some useful information.
      Also check that your Vera2 is no low on memory.
      • D Offline
        DeltaNu1142
        Well--these are the logs I'm getting from IP\cgi-bin\cmh\log.sh?device=luaupnp ... that screenshot is from plugging the Arduino into the USB.
        As it stands, I don't have a next step to try to troubleshoot this as I've done everything I can think of.
        • hekH Offline
          hekH Offline
          Could you ssh into you Vera and check the /etc/cmh-ludl/ folder
          According to your screenshot the file-size of D_Arduino.xml is 31508. But it should only be round 1000 bytes (uncompressed).
          /etc/cmh-ludl# ls -lart \*_Arduino\*
          -rw-r--r--    1 root     root           564 Jan 30 10:39 S_Arduino.xml.lzo
          -rw-r--r--    1 root     root          1245 Jan 30 10:39 I_Arduino1.xml.lzo
          -rw-r--r--    1 root     root           581 Mar 25 21:32 S_ArduinoNode.xml.lzo
          -rw-r--r--    1 root     root           485 Mar 25 21:32 D_ArduinoRelay1.xml.lzo
          -rw-r--r--    1 root     root           473 Mar 25 21:32 D_ArduinoNode1.xml.lzo
          -rw-r--r--    1 root     root          1873 Mar 26 00:28 D_Arduino1.json.lzo
          -rw-r--r--    1 root     root          9512 Mar 26 00:28 L_Arduino.lua.lzo
          -rw-r--r--    1 root     root          2011 Mar 26 00:28 D_ArduinoRelay1.json.lzo
          -rw-r--r--    1 root     root          1463 Mar 26 00:28 D_ArduinoNode1.json.lzo
          -rw-r--r--    1 root     root           575 Mar 26 00:28 D_Arduino1.xml.lzo
          • D Offline
            DeltaNu1142
            I'll do that when I get home later, thanks.
            • D Offline
              DeltaNu1142
              wrote on last edited by DeltaNu1142
              #26
              Here's what I've got... nothing out of the ordinary that I can see--but since the screen shot you referenced, I've gone through, deleted any Arduino files from Vera through WinSCP, then uploaded the files through the Vera UI again. No change in behavior, unfortunately.
              • stofakillerS Offline
                stofakiller
                Hi, i got mine to work, when i change the port from 5003 to 80...
                D 1 Reply Last reply
                • stofakillerS stofakiller
                  DeltaNu1142
                  @stofakiller
                  Do you mean, the device was blank until you changed the port? Or are you using an Ethernet gateway?
                    stofakiller
                    Yes, it was blank until i choose port 80...
                    I choose 192.168.1.166 as ip for my ethernet gateway, but it didn't work for me with the standard port 5003 (192.168.1.166:5003), but when i changed it in the sketch to port 80 and also in the MySensors Plugin, then it worked.
                    • D Offline
                      DeltaNu1142
                      I've been attempting to use a USB gateway. I'm unmotivated at this time to try an Ethernet gateway as I don't have any reason to think it would work.
                      • hekH Offline
                        hekH Offline
                        No, it is really strange and unfortunate that your Vera2 seems to handle the MySensors plugin differently than on the 3/Lite model. I tried finding some information on the differences but haven't found any on the micasa-forum.
                        Using the ethernet gateway wouldn't make a difference at this point.
                        • N Offline
                          N Offline
                          Nicola Reina
                          Hello
                          I was going to buy a few arduinos supposing that the project works with a Vera 2 (not vera light).
                          Can you please confirm that someone has it installed successfully on a Vera 2?
                          • hekH Offline
                            hekH Offline
                            @Nicola-Reina
                            Perhaps you could try to install the vera-plugin and see what happens. @DeltaNu1142 had problem just getting plugin to startup correctly.
                            Would be interesting to see if you are experiencing the same thing.
                            • D Offline
                              DeltaNu1142
                              I'd like to see what luck you have with it. I'd be willing to "float" you an Arduino Nano and radio if you wanted to try it out.
                              • D Offline
                                Dvbit
                                I am Planning to buy some sensor. Is vera 2 supported? Or is it just vera lite ?
                                • S Offline
                                  sailhome
                                  I have been using a VERA 2 with the Arduino usb gateway for two weeks now. I have two nodes, one with a motion sensor and the second node with a humidity/temp sensor. They are working well. I had to reload the VERA UI several times after I uploaded the files to VERA. After the reboots the gateway worked properly. I have more Arduinos and sensors on order, these things are great. Other than affirming that a VERA 2 will work I can't be of much more help.
                                  hekH D 2 Replies Last reply
                                  • S sailhome
                                    hekH Offline
                                    hekH Offline
                                    @sailhome
                                    Good to hear. But this makes the problems @DeltaNu1142 experience a mystery.
                                    • D Offline
                                      Dvbit
                                      Thanks. So i go a ahead and hold thumbs
                                      • D Offline
                                        Dvbit
                                        Vera is temperamental at least ...
                                        I have some plugins that once worked now not. Apparently nothing changed
                                        • hekH Offline
                                          hekH Offline
                                          Yeah, Vera is moody sometimes.
