  3. Problem with adding new sensor
6 Posts 3 Posters 2.5k Views 1 Watching
  • J Offline
    J Offline
    jribera
    Hi Everyone,
    Can someone help explain why, when adding new sensors the following happens:
    In this example i just added a new relay sensor (Arduino light 1:3).
    If I then manually delete "Arduino Node 1" everything starts working:
    Thanks,
    Joseph
    • K Offline
      K Offline
      korttoma
      Restarting Vera and refreshing your browser would probably give the same result as deleting the device..
      • Tomas
      • J Offline
        J Offline
        jribera
        I've tried restarting the vera, my USB gateway and the sensor without luck. In fact if i don't manually delete the "Node 1" sensor my other sensors stop working.
        Just curious why this is happening. Other than this bug i can't believe how easy everything was to setup !
        B 1 Reply Last reply
        • J jribera
          B Offline
          B Offline
          BulldogLowell
          @jribera
          try to flash the EEPROM
          sometimes you need to reset the radio ID, in my experience
          * This sketch clears radioId, relayId and routing info in EEPROM
          #include <EEPROM.h>
            for (int i=0;i<512;i++) {
              EEPROM.write(i, 0xff);
            // Nothing to do here...
          J 1 Reply Last reply
          • B BulldogLowell
            @jribera
            #include <EEPROM.h>
            J Offline
            J Offline
            jribera
            @BulldogLowell
            Thanks i will try this over the weekend.
            I actually found a post from Hek on http://forum.micasaverde.com/index.php/topic,16170.msg158102.html#msg158102
            Which says "The -node (or -relay) device is automatically created for every Arduino in your sensor network. "
            So its interesting that i'm deleting this yet everything is still working :)
            • J Offline
              J Offline
              jribera
              Manged to fix this buy re-installing all the Vera Plugins. Thanks for everyone's suggestions.
