  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.7k Views 36 Watching
    Protocol version hasn't changed since 1.4
    https://github.com/mysensors/Raspberry/blob/master/MyMessage.h#L41
    So you must have some other problem.. As you can see you only get zeroes in the log...
    D
    D
    den2k
    @hek I'm running a custom 1Mhz build bootloader on a Pro Mini for the Sensor side. This was paired with the standard Serial Gateway running on another Pro Mini with v1.5 on both gateway and sensor. That setup was working. But I moved over to using the Pi gatway+nRF24+ radio and have this issue. I don't believe the hookup is the problem. I've seen the 0 readings before, and that usually meant node side issue or uninitiated Gateway. I have not changed the Node, so it must be the Pi gateway that is the problem. Any thoughts on what to test?
    • D
      D
      den2k
      Noob question. Any one have an idea on solving the "Permission denied" error.
      upload-a7ed9c85-5b6b-4198-af00-909e1861374e
      • D
        D
        den2k
        Solved my own problem. Using the following command did the trick.
        sudo chown -h pi:pi ttyUSB20
        • D
          D
          den2k
          weird. Permission Denied problem again.
          What is the USER : GROUP that is needed for this to work?
            @den2k I think your best chance is to post in the Home Assistant category. I don't have any experience with Home Assistant unfortunately.
            • J jpbabou
              Hi
              something is missing..
              Is there a problem with the repository
              Tks a lot for your job!
              pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
              Cloning into 'Raspberry'...
              remote: Counting objects: 273, done.
              remote: Compressing objects: 100% (3/3), done.
              remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
              Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
              Resolving deltas: 100% (114/114), done.
              Checking connectivity... done.
              pi@domoticjp ~ $ cd Raspberry/librf24-bcm
              -bash: cd: Raspberry/librf24-bcm: No such file or directory
              @jpbabou said:
              Hi
              The guide has been updated to reflect the updated in the MySensors Raspberry repository now. Thanks @jpbabou !
              • D den2k
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                #47
                @den2k
                Hi!
                Have you added the user that runs homeassistant to the dialout group? This group is usually owner of serial ports.
                Check default group of serial port (change for your port below) after connecting it:
                pi@martin-pi:~ $ ls -l /dev/ttyUSB0
                crw-rw---- 1 root dialout 188, 0 dec 18 03:21 /dev/ttyUSB0
                Check groups that user pi is in:
                pi@martin-pi:~ $ groups pi
                pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
                If pi runs homeassistant, which should be the case, and is not in dialout, add pi to dialout:
                sudo adduser pi dialout
                Changing owner of a port will only work until you disconnect it. Default owner will be restored upon reconnect, if you haven't written a special udev rule.
                Edit:
                According to the readme in the mysensors raspberry repo (https://github.com/mysensors/Raspberry), the group of the device is tty. So you should probably use that, and not dialout. But you will know, when you check with ls -l.
                  Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                  I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                  Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                  This is the first draft. Any feedback is welcome.
                  INTRODUCTION
                  The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                  Wiring Things Up
                  Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                  Raspberry Pi NRF24L01+ Color
                  6 / GND GND Black
                  1 / 3.3V DC VCC Red
                  22 / GPIO25 CE Orange
                  24 / GPIO 8 CSN/CS Yellow
                  23 / GPIO11 / SPI_CLK SCK Green
                  19 / GPIO10 / SPI_MOSI MOSI Blue
                  21 / GPIO9 / SPI_MISO MISO Violet
                  The IRQ pin on NRF24L01 is not currently used.
                  For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                  You should also connect a decoupling capacitor to the radio. See this guide.
                  COMPILING THE GATEWAY
                  Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                  git clone https://github.com/TMRh20/RF24.git
                  cd RF24
                  make all && sudo make install
                  cd ..
                  cd Raspberry
                  If you get the following error:
                  pi@raspberrypi ~/RF24 $ make all && sudo make install
                  g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                  gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                  bcm2835.c: In function ‘bcm2835_init’:
                  bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                  You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                  #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                  IOBASE := 3F000000
                  VERIFY THE GATEWAY
                  Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                  pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                  Starting PiGatewaySerial...
                  Protocol version - 1.4
                  Created PTY '/dev/pts/1'
                  Gateway tty: /dev/ttyMySensorsGateway
                  ================ SPI Configuration ================
                  CSN Pin          = CE0 (PI Hardware Driven)
                  CE Pin           = Custom GPIO25
                  Clock Speed      = 8 Mhz
                  ================ NRF Configuration ================
                  STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                  RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                  RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                  TX_ADDR          = 0xe7e7e7e7e7
                  RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                  EN_AA            = 0x3b
                  EN_RXADDR        = 0x07
                  RF_CH            = 0x4c
                  RF_SETUP         = 0x23
                  CONFIG           = 0x0e
                  DYNPD/FEATURE    = 0x3f 0x06
                  Data Rate        = 250KBPS
                  Model            = nRF24L01+
                  CRC Length       = 16 bits
                  PA Power         = PA_LOW
                  If the NRF24L01+ isn't correctly wired, the following error will be shown
                  pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                  Created PTY '/dev/pts/2'
                  check wires
                  If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                  sudo killall PiGatewaySerial
                  to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                  If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                  sudo /etc/init.d/PiGatewaySerial start
                  to start the gateway as a background process. Verify that it started correctly by running
                  sudo cat /dev/ttyMySensorsGateway
                  You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                  MAKE THE GATEWAY AUTOSTART
                  To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                  sudo make enable-gwserial
                  Enable the gateway for use with Domoticz
                  Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                  sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                  And change /etc/rc.local from this
                  exit 0
                  to this
                  exit 0
                  OTHER NOTES
                  • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                  • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                  • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                  As always, I stand on the shoulders of giants. Related posts:
                  • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                  • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                  TROUBLESHOOTING
                  If you get this error
                  pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                  [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                   failed!
                  or this error
                  sudo: /usr/local/sbin/PiGatewaySerial: command not found
                  you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                  Scala
                  @mfalkvidd Hi there and thanks for a great and super detailed step-by-step tutorial.
                  I've got mine running in no time with your instructions, but after a couple of minutes I've got the following error:
                  2015-12-30 20:51:30.356 Error: MySensors: Unhandled sensor (sub-type=32), please report with log!
                  2015-12-30 20:52:01.390 Error: Serial Port closed!... Error: End of file
                  2015-12-30 20:52:02.315 MySensors: retrying in 30 seconds...
                  2015-12-30 20:52:31.319 MySensors: Using serial port: /dev/ttyUSB20
                  2015-12-30 20:52:31.320 Error: MySensors: Error opening serial port!
                  2015-12-30 20:52:32.321 MySensors: retrying in 30 seconds...
                  2015-12-30 20:53:01.324 MySensors: Using serial port: /dev/ttyUSB20
                  I also attached a partial screen capture showing that it was working before 8-)
                  Any idea on why is this happening and how to solve it?
                  Southern regards and happy new year to all!
                  ronnyandreR 1 Reply Last reply
                    You are using a sensor type that your version of Domoticz doesn't support. What type os sensor is it? Which version of Domoticz are you using? Upgrading Domoticz might solve the problem (if the newer version supports this sub-type).
                    • Sander TeunissenS
                      Sander TeunissenS
                      Sander Teunissen
                      When I try to run the init.d script:
                      I get the following error:
                       failed!
                      No such file or directory.... Obviously a missing folder or file, but I am not savvy enough to debug this.... Any help appreciated..
                      • Sander TeunissenS Sander Teunissen
                         failed!
                        @Sander-Teunissen my guess is that you forgot the sudo make install part of the installation instructions.
                        • Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          @mfalkvidd Yesterday I stopped trying and shutdown the Pi. This morning I tried the same again and it works !!
                          Pretty sure I haven't done anything else.
                          Thanks anyway.
                          Sander
                          • MrRikkieM
                            MrRikkieM
                            MrRikkie
                            wrote on last edited by MrRikkie
                            #53
                            Hello, If followed the instruction and everything seemed to work without any problem.
                            However when I enter the command : sudo cat /dev/ttyMySensorsGateway
                            I get the message : cat: /dev/ttyMySensorsGateway: No such file or directory
                            Does anybody have any idea how to solve this ?
                            mfalkviddM ronnyandreR 2 Replies Last reply
                            • MrRikkieM MrRikkie
                              @MrRikkie what output did you get when you ran sudo /etc/init.d/PiGatewaySerial start ?
                              • MrRikkieM
                                MrRikkieM
                                MrRikkie
                                No output and no error message. Just a new command line.
                                pi@raspberrypi ~ $ sudo /etc/init.d/PiGatewaySerial start
                                pi@raspberrypi ~ $
                                • Sander TeunissenS
                                  Sander TeunissenS
                                  Sander Teunissen
                                  When I
                                  ls -l ttyMySensorsGateway
                                  I get
                                  lrwxrwxrwx 1 root root 10 Jan  3 20:21 ttyMySensorsGateway -> /dev/pts/0
                                  It's all root. This results in all kinds of acessability issues. I followed all instructions exactly. Anyone any ideas how to change this ?
                                  Sander.
                                  martinhjelmareM mfalkviddM 2 Replies Last reply
                                    When I
                                    I get
                                    Sander.
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @Sander-Teunissen
                                    Try writing a udev rule to set owner of the device (ttyMysensorsGateway) at boot. If you don't need to use the link you could write a rule that names the pts device to the same name every boot, I think. At least for usb devices this works. Haven't tried it in this particular case.
                                      When I
                                      I get
                                      Sander.
                                      @Sander-Teunissen said:
                                      When I
                                      I get
                                      The permissions for a soft link are not used (and if they were, any user would be allowed to do anything since everything is rwx). The permissions for the target is used instead. So it is the result of
                                      ls -l /dev/pts/0
                                      you need to worry about.
                                      • ahmedadelhosniA
                                        ahmedadelhosniA
                                        ahmedadelhosni
                                        Hello @mfalkvidd , I read the topic again but I am a bit confused. Normally we have a sketch on the Arduino board to enable signing for example or implement our desired code. I don't understand how to edit this before compiling ?
                                          Sorry @ahmedadelhosni, I haven't tried to compile the Raspberry gateway for signing. @Anticimex will probably chide me for that, and rightly so :)
                                          It should just be a matter of modifying MyConfig.h to enable signing, as per the instructions in http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors but maybe the MySensor files in the Raspberry repo haven't been updated with the signing features.
