  3. OpenHAB
  4. 3 state switch and what to send via mqtt
3 Posts 2 Posters 1.9k Views 1 Watching
  • dakkyD
    dakkyD
    dakky
    hello
    i'm planning the following setup:
    • simple relay + light sensor node => controlling a lamp
      on / off is clear. auto should switch on the light when it becomes dark and vice versa.
    • in openhab i want to so set this lamp to on / off / auto => does this kind of switch exist in openhab?
    • if yes: how would the message sent via mqtt look like? The predefined api sub-types won't help me imho, because a V_LIGHT for example does know only two states. or can i set the payload to whatever i want? ie 0=off, 1=on, 3=auto and decide in the sketch what to do?
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      I would try to keep the logic at the controller side. You could make two buttons/switches in openhab. One for on/off and one for auto/manual. A sensor for the light level. Combine those with a rule.
      • dakkyD
        dakkyD
        dakky
        yep, i'm afraid that's the way to go. Thanks for ACK
