  3. Newby Question: compiler warnings and capacitor size on NRF+
14 Posts 7 Posters 5.6k Views 4 Watching
  • D
    D
    DutchMurk
    I just started a week ago building my own sensors. I can upload sketches to my two UNO clones , program some buttons, leds, etc. but I can't get my sensors to communicate to each other using PingPongSensor. Probably to do with the power supply or the connection of the capacitors to the NF module, so I will continue to struggle. Meanwhile I have two questions:
    1. what is the best capacitor size on the NRF+, I sometime see 4,7 uF sometimes 47 uF and even 100 uF
    2. I have two complier warnings (see below) can they cause an issue ?
    **Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
    WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
    I love this initiative. I do have an OpenHab system with some z-wave sensors and HUE lamps, but it’s way too expensive to buy it all, so this is a very nice opportunity to expand my home !
    • sundberg84S
      Hi!
      1. I primary use 4,7uF and are tested higher and two caps paralell on my gateway atm.
      2. I dont know but when i struggle with this, i mostly just completely reinstall the lib from the homepage.
      dakkyD 1 Reply Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        @DutchMurk
        Those are just warnings, and from what I see, there is no problem in them (they've changed some naming conventions in the core files, that we apparently haven't migrated to our hardware addons. But they gracefully change them to the right thing, together with the warning).
        Will probably need a minor change in the mysensors hardware definition files.. But I don't know if that will come in to master branch now..
        • sundberg84S sundberg84
          Hi!
          dakkyD
          dakkyD
          dakky
          I can ACK this:
          On the Gateway i need 2 caps: 100uF and 4.7uF. without the 100uF cap I had some really strange behavior when starting the gateway until the communication got established same (random) times
          At the nodes 4.7uF is sufficent.
          Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
          Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
          Software: MySensors 2.0development
          F 1 Reply Last reply
          • D
            D
            DutchMurk
            Thanks a lot for your answers. I have installed the caps and both the node and gateway are initiated every time flawless but they refuse to communicate to each other. The modules are recognized as being '+' versions using the GetStated sketch from the RF24library. Tried to setup both uno's in different ways (pingpong; serial gateway and sensor) but none of the combinations shows any way of communication between the two boards. I have been struggling for three days now; I am out of ideas and I am afraid it's a problem with the nRF modules (see this link also ) . I will try to order some new ones.....
            • sundberg84S
              How far from eachother do you have the nodes?
                D
                D
                DutchMurk
                @sundberg84 : in the same room. One on the serial monitor, one in an external power supply
                • D DutchMurk
                  D
                  D
                  DutchMurk
                  After a steep learning curve I found out that one of my UNO clones was not able to receive messages in any way. I have now made a sensor based on a pro mini which works fine with a serial gateway. The only problems I still encounter is that the node-ID is not assigned automatically but I solved it by defining it in the sketch. @sundberg84 : I saw a different post of you for the Easy/Newbie PCB for MySensors. It looks very tempting to start using them !
                  • dakkyD
                    dakkyD
                    dakky
                    openhab does not manage the IDs. it's simply not implemented on the openhab side
                    • dakkyD dakky
                      I can ACK this:
                      F
                      F
                      flopp
                      @dakky
                      Do it have to be electrolyte cap or can it be SMD cap?
                      • F flopp
                        @dakky
                        @flopp smd is fine
                          @flopp smd is fine
                          F
                          F
                          flopp
                          wrote on last edited by flopp
                          @mfalkvidd
                          Thanks. Make it much easier to make a small-size-project
                          • F
                            F
                            flopp
                            Can the SMD cap be like this?
                            http://www.aliexpress.com/item/Free-shipping-0603-SMD-capacitor-4-7UF-50V-475Z-100PCS/32621037834.html?spm=2114.01010208.3.11.IfcuOj&ws_ab_test=searchweb201556_0,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_10020_10018_10019,searchweb201603_6&btsid=87ae8cba-1bfa-4fdf-9c3c-02524011e44a
                            I have tried and it works but isn't to small?
                            • TheoLT
                              TheoLT
                              TheoL
                              This post is deleted!
