  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.3k Views 38 Watching
  • blaceyB blacey
    @tbowmo said in 💬 Sensebender Micro:
    @marceltrapman
    There is no kicad project available for the Sensebender Micro, I tried to convert it myself, but didn't succeed with it either.
    I haven't tried this Eagle->KiCAD convertor myself but it might do the trick or at least reduce a lot of the manual labor to convert...
    There's even a tutorial video.
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    @blacey I tried that one but for some reason a dialog pops up that I can not click away anymore :(
    Complaining about files in a wrong place without giving more info.
    Fulltime Servoy Developer
    blaceyB 1 Reply Last reply
    • marceltrapmanM marceltrapman
      blaceyB
      blaceyB
      blacey
      @marceltrapman The author updated his repo within the past few days so you could open an issue on his GitHub repo to see if he can help...
      • tbowmoT
        tbowmoT
        tbowmo
        @marceltrapman
        Just tried the scripts from the url that @blacey mentioned above on the sensebender micro eagle files.. And got a semi working thing in kicad..
        And it seems that at least the forward annotation from schematics to pcb is working like it should..
        • tbowmoT tbowmo
          @marceltrapman
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @tbowmo Nice, I will try again (probably sunday or so)...
            meddie
            Hey together,
            i have a question, because i have some capacity troubles. I used the example sketch from sensebender micro that meassures the temperature and humidity but i have additional activated the signing and encryption and now i got over the availible space 109%.
            use anybody from you all the features? what i have to do?
            thank you
            • N
              N
              nldroid
              Re: 💬 Sensebender Micro
              I'm trying to flash the sketch to the sensebender micro using the Arduio IDE.
              I bought the sensebender micro with the suggested FTDI programmer.
              I connected the programmer to the sensebender and plugged in the USB cable.
              My windows 7 installation finds the device and installs the driver as USB Serial Port (COM3). The driver is from FTDI. The hardware device id is: FTDIBUS\COMPORT&VID_0403&PID_6001
              In the Arduino IDE, i've selected Board: Sensebender Micro, Processor: Atmega 328 8Mhz, Port: COM3.
              I tried using USBasp, made a clone with the right hardware id's and tried that. I tried AVRIsp Mk II.
              Whatever i try, avrdude.exe tells me it can't find the device:
              C:\Program Files (x86)\arduino-1.8.1\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cRF232RL -Pusb -Uflash:w:C:\Users\rob\AppData\Local\Temp\arduino_build_955073/SensebenderMicro.ino.hex:i
              avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
                       Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                       Copyright (c) 2007-2014 Joerg Wunsch
                       System wide configuration file is "C:\Program Files (x86)\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf"
                       Using Port                    : usb
                       Using Programmer              : RF232RL
              avrdude: Warning: cannot open USB device: Function not implemented
              avrdude: error: could not find USB device with vid=0x403 pid=0x6001
              avrdude done.  Thank you.
              the selected serial port
               does not exist or your board is not connected
              Anyone knows what's wrong?
                meddie
                Hey together,
                i have an problem, i had some troubles with the space on the sb micro, i have removed the #define my_debug that solved my space problem, but now i have observed that the node is starting and sends few times the temp and humidity but after the few times nothing happens anymore.
                i observed, when i hold the sensor in the fingers so that it will be worm, and start the node then it sends all minute the temp, but when the temp goes down to the room temperature then the node should send only when the humidity or temp changes over the threshhold, so in the room i dont have much changes and i think that when the node does not send about a longer time, that the the problem comes up.
                I tested it in some different distances, on another floor but in very short distance too. I dont think that is a radio problem.
                What do you think about?
                The Problem is, that i cant debug the node because i disabled it because of space problems.
                Thank you
                  meddie
                  wrote on last edited by meddie
                  #48
                  i have just tried it again, it worked for 20 minutes. After them i get this output:
                  Sensebender Micro FW 1.4 - Online!
                  isMetric: 1
                  TempDiff :122.28
                  HumDiff  :154.00
                  T: 22.28
                  H: 54
                  TempDiff :0.00
                  HumDiff  :0.00
                  TempDiff :0.10
                  HumDiff  :0.50
                  TempDiff :0.11
                  HumDiff  :0.50
                  TempDiff :0.12
                  HumDiff  :0.00
                  ok one more thing i found, when i close the serial monitor and start it again, i get the correctly output again, and i see in fhem the new readings.
                  but i cant understand what happens why stop the node to transmit the correct readings
                  qqlapralineQ 1 Reply Last reply
                  • M meddie
                    isMetric: 1
                    TempDiff :122.28
                    HumDiff  :154.00
                    T: 22.28
                    H: 54
                    TempDiff :0.00
                    HumDiff  :0.00
                    TempDiff :0.10
                    HumDiff  :0.50
                    TempDiff :0.11
                    HumDiff  :0.50
                    TempDiff :0.12
                    HumDiff  :0.00
                    qqlapralineQ
                    qqlapralineQ
                    qqlapraline
                    @meddie, do you use the default sketch for sensebender ?
                    If this is the case, please notice that after 5 measures, the clock speed is lowered to 1 Mhz. It means that the serial output won't work anymore using the default baud speed.
                    And, when you restart the serial monitor, it starts all over again from measure number 1.
                    Hope this helps.
                    QQ.
                    • qqlapralineQ qqlapraline
                      Hope this helps.
                      QQ.
                      meddie
                      #50
                      @qqlapraline
                      oh yes it does! It explains why i get the € signs in the serial monitor. But why does the node not send to my FHEM Controller? Depends it also on it, that the node switch to 1 Mhz and cant send anymore?
                      Thank you very much for your answer, its very helpfull.
                      Greets Eddie
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        Hmm I actually thought that this feature with switching to 1mhz was removed, as my calculations show that it (in theory) will use more current, than running at 8mhz (due to the fact that it sleeps most of the time)
                        • Michiel van der WulpM
                          @tbowmo : The code to switch the frequency back to 1MHz is still there at https://www.mysensors.org/view/1/Sensebender-Micro.
                          Should it be removed?
                          • W
                            W
                            Wavemaker
                            Is it possible to directly connect a RFM69* module to the Sensebender Micro? Or do I need the (rather costly) NRF2RFM69 to do that?
                            mfalkviddM tbowmoT 2 Replies Last reply
                            • W Wavemaker
                              @Wavemaker welcome to the community!
                              You can spend your time instead of your money to do exactly what the adapter does, no need to buy it.
                              • W Wavemaker
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @Wavemaker
                                What is costly? If you grab the gerbers for the nrf2rfm69, send them to dirtypcbs (or use the link provided in the thread and order the pre uploaded gerbers at dirtypcbs) you'll get around 30 modules for 12$..
                                W 1 Reply Last reply
                                • tbowmoT tbowmo
                                  @Wavemaker
                                  W
                                  W
                                  Wavemaker
                                  @tbowmo Aha, yes, well I was looking at the cost of just one adapter to test. But you're right, in larger quantities it's not costly.
                                  • Michiel van der WulpM Michiel van der Wulp
                                    meddie
                                    @Michiel-van-der-Wulp
                                    Can you tell me where in the code is the switch to 1 MHz? I still have the problems that my node dosnt send anymore. It works for several hours but after then it dont send anything.
                                    In programming i am not good, and so i cant find the switch.
                                    Thank you very much.
                                    Greets Eddie
                                    Michiel van der WulpM 1 Reply Last reply
                                    • M meddie
                                      Greets Eddie
                                      @meddie : Sure, I can:
                                      The following is an extract from the code shown at https://www.mysensors.org/view/1/Sensebender-Micro, from the "loop()" function:
                                      #ifndef MY_OTA_FIRMWARE_FEATURE
                                        if ((measureCount == 5) && highfreq)
                                          clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                                          highfreq = false;
                                      If you remove these lines, it will stay on 8MHz.
                                      (I did not test this but I am quite sure)
                                            highfreq = false;
                                        meddie
                                        thank you i will test it the next few days
                                        • D
                                          D
                                          Dominic Amann
                                          I assume there is no exposure to the SPI bus on this board?
