  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 700.4k Views 93 Watching
  • K kiesel
    Is there a video of how to solder the signing chip? Because from what I can see there is a connection to be made right in the middle of the chip and I am not sure how to.
    #701
    @kiesel - sorry, no video of this available at the moment. I made one some time ago but my HD crashed so I lost all my video of a project i made with signing. Maybe I have some left on the videocamera - I will check tonight.
    What do you mean with "connection in the middle"? I know there was a fault in the old gerbers with D6 not connecting to the arduino but this was fixed in May so if you have new boards it should be fine. Make a continuity test from SCK (Pin6 on signing chip) to D6 on the arduino.
    • K kiesel
      AnticimexA
      AnticimexA
      Anticimex
      @kiesel It is a SOT23 if I remember correctly. There are only 3 pins, no pad underneath so soldering should be easy.
      Perhaps the copper you see is part of a ground plane? It will not connect to the signing chip in any case.
      • AnticimexA Anticimex
        @Anticimex @kiesel - yes, you are right - i mixed it up with the flash chip. Signing should be good - no issues reported (i have had several boards myself working fine).
        • K
          K
          kiesel
          @Anticimex ,@sundberg84
          Thanks for the help, I think I was looking at the wrong chip. The one I considered byuing had 6 legs, not only 3. I was thrown off by the easypcb having what appears to be 7 soldering points in the signing area.
          AnticimexA 1 Reply Last reply
          • K kiesel
            AnticimexA
            AnticimexA
            Anticimex
            @kiesel Beware that I believe the 6 leg chip is I2C which is not supported. Only the 3 leg SWI variant is supported.
              Mr_sensor
              I'm not sure if this is the right place to ask. But it seems right to me :)
              Hi I have e few of the Easy/Newbie-pcb working for some time with good effort. One of them even in a shed at 20 - 25 meters in the garden which is fairly good isolated. Sending Temp/Hum/battery level. And the Gateway is in the house on the first floor behind a door in a wardrobe.
              Now I have a second shed which is behind the fist shed. Also very good isolated. The pcb I have in there is not reaching the gateway (it did before until the battery was empty).
              Can I have the pcb in the first shed also working as an extender, so the second pcb will be able to send out topics to the gateway as well? What to add to my code to achieve that?
              Nca78N 1 Reply Last reply
              • M Mr_sensor
                Nca78N
                Nca78N
                @Mr_sensor said in 💬 Easy/Newbie PCB for MySensors:
                you must program it to be a repeater. Of course it will need to have radio on all the time, so it cannot be battery-powered.
                https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
                • B
                  B
                  benhub
                  I'm thinking about switching to RFM69 with some of my nodes. From what I saw, RFM69 uses the same pins as nrf24l01 (except for pin 9 on Arduino). So, theoretically, would it be possible to connect the RFM69 to the nrf24l01 Easy PCB board (Rev 10) — of course, I will not fit directly and I have to create some adapter. But it should be possible, right?
                  • B benhub
                    @benhub - hello!
                    You need some sort of adapter, the use similar pins but not in the same order/layout.
                    Here is a suggestion for adapter: https://www.openhardware.io/view/601/NRF24-to-RFM69-converter
                    But... you know there is a RFM version of the EasyPCB right?
                    https://www.openhardware.io/view/389/EasyNewbie-PCB-RFM69-HWW-edition-for-MySensors
                    B 1 Reply Last reply
                    • sundberg84S sundberg84
                      @benhub - hello!
                      B
                      B
                      benhub
                      @sundberg84 Cool! Thanks for your quick response!
                      Yes, I know, but I already have nrf24 boards at home which I want to use too. So cool that it should be possible.
                      • B benhub
                        @benhub - ok, there are some things you need to consider, and that is the space of the adapter.
                        I read now i "suggested" this adapter, but let me clear it it is not tested, maybe a language barrier from my side.
                        You need to consider that it fits in the board and do not crash into other compontens, like the arduino.
                        If it does, you maybe need to consider some other board or even build one.
                        • K
                          K
                          koumac77
                          This post is deleted!
                          • K
                            K
                            koumac77
                            I want to dive in home automation using home assistant and MySensors DIY modules
                            I decided to order your boards from pcbway.com but when I select it, there is sql error
                            I discussed with their support but they were not able to find your PCB....
                            Can you give me an url link to order your 10x PCB from them ?
                            Thanks a lot for your design/support.
                            JC
                            I am looking for the Nrf24l01+ edition of EasyPCB
                            but could you tell me if It would be better to go with the RFM69 transceiver version ?
                            What are the pro and cons for Nrf24l01+ and RFM69 transceiver ?
                            Could there be a problem with WIFI objects using Nrf24l01+ ?
                            • K
                              K
                              koumac77
                              After new exchanges with PCBWay support,
                              problem fixed : i was able to order the 10x PCBEasy from PCBWay store.
                              Hoping to have some answers for best choice between Nrf24l01+ and RFM69 transceivers.
                              I am in France
                                mickecarlsson
                                What version of the PCB did you order? The NRF24 or the RFM69?
                                I used the NRF24 but found it very unreliable and swapped all my sensors to RFM69.
                                As almost every NRF24 from china is fake you will find out that the range between sensor and gateway is a couple of meters.
                                The RFM69 (on 868 MHz) will have a range up to 50 meters and above. If used indoors it will easy go over 30 meters.
                                K 1 Reply Last reply
                                • M mickecarlsson
                                  K
                                  K
                                  koumac77
                                  @mickecarlsson , thanks for your answer and help
                                  I ordered the NRF24 version
                                  So , will cancel it and order RFM69 version
                                  Cheers,
                                  JC
