  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • pepsonP pepson
    hi
    when i try compile sketch only with change radio to rfm69hw i have this:
    Arduino:1.8.9 (Windows 10), Płytka:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    SensebenderGatewaySerial:95:26: error: 'LED_BLUE' was not declared in this scope
    static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
    SensebenderGatewaySerial:95:36: error: 'LED_RED' was not declared in this scope
    SensebenderGatewaySerial:95:45: error: 'LED_GREEN' was not declared in this scope
    SensebenderGatewaySerial:95:56: error: 'LED_YELLOW' was not declared in this scope
    SensebenderGatewaySerial:95:68: error: 'LED_ORANGE' was not declared in this scope
    C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'void preHwInit()':
    SensebenderGatewaySerial:116:10: error: 'MY_SWC1' was not declared in this scope
    pinMode(MY_SWC1, INPUT_PULLUP);
    SensebenderGatewaySerial:117:10: error: 'MY_SWC2' was not declared in this scope
    pinMode(MY_SWC2, INPUT_PULLUP);
    SensebenderGatewaySerial:130:17: error: 'LED_BLUE' was not declared in this scope
    digitalWrite(LED_BLUE, led_state);
    SensebenderGatewaySerial:145:16: error: 'LED_GREEN' was not declared in this scope
    digitalWrite(LED_GREEN, HIGH);
    SensebenderGatewaySerial:149:16: error: 'LED_YELLOW' was not declared in this scope
    digitalWrite(LED_YELLOW, HIGH);
    SensebenderGatewaySerial:154:16: error: 'LED_ORANGE' was not declared in this scope
    digitalWrite(LED_ORANGE, HIGH);
    SensebenderGatewaySerial:167:17: error: 'LED_RED' was not declared in this scope
    digitalWrite(LED_RED, HIGH);
    C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testSDCard()':
    SensebenderGatewaySerial:219:33: error: 'MY_SDCARD_CS' was not declared in this scope
    if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
    C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testEEProm()':
    SensebenderGatewaySerial:249:2: error: 'SerialUSB' was not declared in this scope
    SerialUSB.print(" -> EEPROM ");
    C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testAnalog()':
    SensebenderGatewaySerial:267:30: error: 'MY_BAT_DETECT' was not declared in this scope
    int bat_detect = analogRead(MY_BAT_DETECT);
    exit status 1
    What is error ? please help me
    magpernM
    magpernM
    magpern
    wrote on last edited by magpern
    #361
    @pepson said in 💬 Sensebender Gateway:
    hi
    You cannot use the SensebenderGatewaySerial sketch on an Atmega2560. The SensbenderGatewaySerial sketch is for the SAMD board called Sensebender Gateway.
    If you have the real Sensebender Gateway you should use this one
    pepsonP 1 Reply Last reply
    • magpernM magpern
      hi
      pepsonP
      pepsonP
      pepson
      @magpern
      But get this board to Arduino IDE?
      magpernM 1 Reply Last reply
      • pepsonP pepson
        @magpern
        magpernM
        magpernM
        magpern
        @magpern
        Boards / Boards manager...
        search for sensebender
        You might have to
        File / Preferences / Additional Board manager URLs
        add
        https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json
        • pepsonP
          pepsonP
          pepson
          Hi
          I compiled and write to gateway this programmm. Then i connected it to my RPI with Hassio (Home Assistant). In logs on home assistant still show me info: Gateway /dev/serial/by-id/usb-MySensors.org_Sensebender_GW_6A153443514D355934202020FF10182D-if00 not ready after 15.0 secs so continuing with setup
          but after run Home Assistant gateway works ok. I send info mto developer Home Assistant ans she not see any bugs....
          How i can resolved this problem ?
          • pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            #365
            And please help me how i can compile it as gateway Ethernet with module W5100.
            Only add to sketch:
            #define MY_GATEWAY_W5100
            // Enable to UDP
            //#define MY_USE_UDP
            //#define MY_IP_ADDRESS 192,168,3,160 // wpisz adres ip bramki
            #define MY_PORT 5003 //wpisz numer portu bramki
            //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
            // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
            #define MY_MAC_ADDRESS 0xDC, 0xAE, 0xB2, 0x3F, 0xFF, 0xDC
            • pepsonP
              pepsonP
              pepson
              When try compilation with this W5100 i get error:
              Opcje projektu zmienione, przeładuj całość
              In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:208:0,
                           from C:\Users\Piotrek\Desktop\SensebenderGatewayETHERNET\SensebenderGatewayETHERNET.ino:111:
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:74:1: error: 'EthernetServer' does not name a type
              EthernetServer _ethernetServer(_ethernetGatewayPort);
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:89:8: error: 'EthernetClient' does not name a type
              static EthernetClient client = EthernetClient();
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportInit()':
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: error: 'Ethernet' was not declared in this scope
              if (!Ethernet.begin(_ethernetGatewayMAC)) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:149:7: note: suggested alternative: '_ethernetMsg'
                 _ethernetMsg
              In file included from C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MySensors.h:49:0,
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: error: 'Ethernet' was not declared in this scope
                          Ethernet.localIP()[0],
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/MyConfig.h:1815:48: note: in definition of macro 'DEBUG_OUTPUT'
              #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##VA_ARGS) //!< debug
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:155:2: note: in expansion of macro 'GATEWAY_DEBUG'
              GATEWAY_DEBUG(PSTR("GWT:TIN:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:156:16: note: suggested alternative: '_ethernetMsg'
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: error: '_ethernetServer' was not declared in this scope
              _ethernetServer.begin();
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:189:2: note: suggested alternative: '_ethernetMsg'
              _ethernetMsg
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportSend(MyMessage&)':
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: error: '_ethernetServer' was not declared in this scope
              nbytes = _ethernetServer.write(_ethernetMsg);
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:246:11: note: suggested alternative: '_ethernetMsg'
                     _ethernetMsg
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool _readFromClient()':
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: error: 'client' was not declared in this scope
              while (client.connected() && client.available()) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:289:9: note: suggested alternative: 'Print'
                   Print
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'bool gatewayTransportAvailable()':
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:409:2: error: 'EthernetClient' was not declared in this scope
              EthernetClient newclient = _ethernetServer.available();
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:411:6: error: 'newclient' was not declared in this scope
              if (newclient) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: error: 'client' was not declared in this scope
              if (client != newclient) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:412:7: note: suggested alternative: 'Print'
                 Print
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: error: 'client' was not declared in this scope
              if (client) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:422:6: note: suggested alternative: 'Print'
              if (client) {
                Print
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp: In function 'void gatewayTransportRenewIP()':
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: error: 'Ethernet' was not declared in this scope
              if (Ethernet.maintain() & ~(0x06)) {
              C:\Users\Piotrek\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:463:6: note: suggested alternative: '_ethernetMsg'
                _ethernetMsg
              exit status 1
              Błąd kompilacji dla płytki Sensebender Gateway.
              What is a problem ?
              • pepsonP
                pepsonP
                pepson
                please help me....
                • pepsonP
                  pepsonP
                  pepson
                  Hi
                  Can anybody help me how compile sketch to this gateway to work as Ethernet Gateway...
                  When i try compile i get the error:
                  https://pastebin.com/BSQGsCgi
                  and my sketch looks like:
                  https://pastebin.com/R3vG076i
                  tekkaT 1 Reply Last reply
                  • pepsonP pepson
                    Hi
                    tekkaT
                    tekkaT
                    tekka
                    @pepson Did you add
                    #include <Ethernet.h>
                    • tekkaT tekka
                      @pepson Did you add
                      pepsonP
                      pepsonP
                      pepson
                      @tekka
                      No.... thanks i fixed it....:)
                      • A
                        A
                        Andreas Kräuchi
                        I just got my Sensebender Gateway and loaded the Sensebender Gateway Serial sketch. When I use the MYSController I get those wired infos...
                        Currently there is no other Snesor runing just the Sensebender Gateway with an RF24. Why does it see a new child and what are all thos "hu;hu;hu" errors?
                        • A
                          A
                          Andreas Kräuchi
                          Ok solved it by adding:
                          #undef PRId8
                          #undef PRIi8
                          #undef PRIo8
                          #undef PRIu8
                          #undef PRIx8
                          #undef PRIX8
                          #undef PRIdLEAST8
                          #undef PRIiLEAST8
                          #undef PRIoLEAST8
                          #undef PRIuLEAST8
                          #undef PRIxLEAST8
                          #undef PRIXLEAST8
                          #undef PRIdFAST8
                          #undef PRIiFAST8
                          #undef PRIoFAST8
                          #undef PRIuFAST8
                          #undef PRIxFAST8
                          #undef PRIXFAST8
                          #define PRId8    "d"
                          #define PRIi8   "i"
                          #define PRIo8   "o"
                          #define PRIu8   "u"
                          #define PRIx8   "x"
                          #define PRIX8   "X"
                          #define PRIdLEAST8  "d"
                          #define PRIiLEAST8  "i"
                          #define PRIoLEAST8  "o"
                          #define PRIuLEAST8  "u"
                          #define PRIxLEAST8  "x"
                          #define PRIXLEAST8  "X"
                          #define PRIdFAST8 "d"
                          #define PRIiFAST8 "i"
                          #define PRIoFAST8 "o"
                          #define PRIuFAST8 "u"
                          #define PRIxFAST8 "x"
                          #define PRIXFAST8 "X"
                          • A
                            A
                            andy5211d
                            I have a similar issue with Sensebender Ethernet MQTT Gateway and MYSController. Can only connect to the gateway by serial from MYSController. The set-up is working correctly as best I can tell, and has several different MySensors in use. Has been working for a number of years. Only just discovered the MYSController software.
                            So the Controller only shows data in the MYSController Debug tab. Nothing in any of the others. NOTE in the screen grab below the Controller at 192.168.1.96 is not connected, there is no difference when it is other than the Gateway error (!GWT:RMQ:FAIL) is not shown. Anyone with any ides for me to pursue? Thanks.
                            • bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              As previously noted, Sensebender Gateway sketch from 2.3.2 with MySensors SAMD Boards 1.0.6 does not compile with Arduino SAMD Boards 1.8.9. Rolling back to Arduino SAMD Boards 1.8.8 or earlier version works.
                              • YoshuY
                                YoshuY
                                Yoshu
                                Does anyone have an idea about the sensebender gateway board not being recognised in windows 11? A new driver maybe or any other clues ?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  #376
                                  Unfortunately I do not have any hardware compatible with win11, so can't test myself.. But if I remember right it should turn up as a generic cdc device..
                                  Is there any info in the windows device manager?
                                  YoshuY 1 Reply Last reply
                                  • tbowmoT tbowmo
                                    YoshuY
                                    YoshuY
                                    Yoshu
                                    @tbowmo
                                    Nothing new appears in device manager or the usual ding.
                                    tbowmoT 1 Reply Last reply
                                    • YoshuY Yoshu
                                      @tbowmo
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Yoshu Does the same device work on another machine, running win10 / linux?
                                      • YoshuY
                                        YoshuY
                                        Yoshu
                                        I have not had the opportunity to try another machine yet. unfortunately I had only just given into the windows 11 upgrade messages days before deciding to set up my gateway.
                                        • YoshuY Yoshu
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @Yoshu you could boot linux off a usb, and check there..
