  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @FotoFieber
    Well sensebender GW supports rfm69 with ethernet ;)
    FotoFieberF alexsh1A 2 Replies Last reply
    • tbowmoT tbowmo
      @FotoFieber
      FotoFieberF
      FotoFieberF
      FotoFieber
      @tbowmo
      Yes, that is really nice. :+1:
      My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
      • tbowmoT tbowmo
        @FotoFieber
        alexsh1A
        alexsh1A
        alexsh1
        @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
        tbowmoT 1 Reply Last reply
        • alexsh1A alexsh1
          tbowmoT
          tbowmoT
          tbowmo
          #104
          @alexsh1
          you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
          Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
          and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
          alexsh1A 1 Reply Last reply
          • tbowmoT tbowmo
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
            • tbowmoT
              tbowmoT
              tbowmo
              @alexsh1
              You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
              • tbowmoT tbowmo
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                #107
                @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                Waiting for an ethernet board now, it has stuck in the post
                • F
                  F
                  Fabien
                  @tbowmo : Did you try to use this board with platformio ?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    No, platformio is still on my bucketlist.. There is just not hours enough for everything :)
                    F 1 Reply Last reply
                    • tbowmoT tbowmo
                      @Fabien
                      F
                      F
                      Fabien
                      @tbowmo Ok I will install arduino IDE to upgrade it to 2.1.1
                      Please post here iwhen you have more information. I think I will try but I have no experience with this architecture.
                      • delivereathD
                        delivereathD
                        delivereath
                        Has anyone designed a case for the sensebender gateway ?
                        • delivereathD delivereath
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @delivereath
                          I designed one in freecad for the GW and a nrf24l01 with lna/pa and external antenna.
                          But I still have some fine tuning to do before releasing it, as the lid locking mechanism didn't turn out like expected.
                          • scalzS
                            scalzS
                            wrote on last edited by scalz
                            #113
                            Tea time..
                            Here is my custom box for your RFM69 Sensebender GW ! Beautiful board though ;)
                            No nail no screw :)
                            Last final minor check and i release the files, sure! (i've done one for nrf too in case..)
                            alexsh1A F 2 Replies Last reply
                            • scalzS scalz
                              Tea time..
                              No nail no screw :)
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @scalz beautiful box!!!
                              Looking forward to print it too as soon as you publish it, but mine will be with nrf24l01+. Having been running both networks, I'm so much in favour of rfm69. It just works. No more caps to stabilise power or any other rf issues.
                              I have decided to use Moteino Mega with a built-in antenna as rfm69 gateway though - it is very small and goes inside into an RPi box. And has got more memory than atmega328p
                              • scalzS scalz
                                Tea time..
                                No nail no screw :)
                                F
                                F
                                Fabien
                                @scalz Yeah ! I will print this one.
                                • scalzS
                                  scalzS
                                  #116
                                  Little gift.. :)
                                  Custom box for the NRF non PA version:
                                  A bit enlarged for NRF.
                                  And here the 3d preview for both versions with my little cheat for bicolor as i've still not added this feature to my printer
                                  You can see i've added a little slot near usb on the NRF version, it's for the leds indication in case box wouldn't be white (no need for white box, you can see it by transparency). I'll do the same for rfm69, and put variant stl with it or not.
                                  Next Nrf PA version, and that'll be fine ;)
                                    Thank you @scalz!
                                      Thank you @scalz!
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @scalz Please share the STL files!
                                      • scalzS
                                        scalzS
                                        @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
                                        Here it is : http://www.thingiverse.com/thing:2084269
                                        • scalzS
                                          scalzS
                                          #120
                                          I'm proud to say enclosure files have been integrated in the MySensors Sensebender GW project and git.
                                          So you can find the files here at Mysensors.
                                          Enjoy :)
