  3. My ESP8266 Gateway and nodes.
15 Posts 6 Posters 8.0k Views 5 Watching
  • ErrKE
    ErrKE
    ErrK
    This will be continued as my work progress.
    Hi.
    My gateway has been running for a few weeks now and this week I finally finished my first node.
    It gave me a few burn marks on my fingers and required many hours of soldering, but now it's done!
    To make it easier with the following nodes I've ordered a few of @sundberg84:s Easy/Newbie PCB
    I currently use API 1.6.0-beta.
    My Gateway is a ESP8266 with a NRF24L01+PA+LNA
    First I cut one of my Prototype PCB and then I soldered the NRF24L01.
    After that I started to prepare for all the cables.
    I finally put on the ESP8266 so it will hide the cables.
    When it's done it looks like this:
    Here is when it's in a box. Yes, I know the box is bigger than it needs to be :)
    • ErrKE
      ErrKE
      ErrK
      wrote on last edited by ErrK
      Here is my first node.
      I got my inspiration from @the-cosmic-gate:s 3 in 1 incl battery monitor
      I am using a Arduino Pro Mini 5v because i have not recived my Step Up Boost Module 5V yet.
      The sensors i have connect is a DHT-22 and a HC-SR501 motion sensor.
      This is the top.
      This is the botton.
      The box i use for this i the same i used for my gateway.
      I will make a update when i have build my next node with a PCB from @sundberg84
      • F
        F
        fly3rman
        Gj, but where have you got the fancy "egant" case from?
        • ErrKE
          ErrKE
          ErrK
          @Dimitri-Henning It's from a store in Sweden.
          http://www.biltema.se/sv/Bygg/El/Fast-installation/Kulodosa-2000022310/
            msebbe
            Nice, I also have those boxes from "Biltema" :D
            • sundberg84S
              Yea, so do I! They are perfect because they fit a AA battery case inside perfect!
              • ErrKE
                ErrKE
                ErrK
                Nice that other have the same boxes.
                They are good and cheep :)
                • ErrKE
                  ErrKE
                  ErrK
                  Today i got the PCB that i order from @sundberg84 design.
                  I orderd them from http://smart-prototyping.com/
                  Here is how they looks.
                  Will begin with my next node tomorrow.
                  In the waitng for the delivery i started to solder the pins on the arduino.
                  But i just find that it will not work with the PCB because the pins will then hit the NRF24L01.
                  So i need to start with unsolder them.
                  • sundberg84S
                    Just turn them around or don't solder them at all and use the pins on the cable instead. ☺ good luck. Also don't power the node through fdti. The pcb is build to be powered through the pcb gnd/vcc/raw
                    ErrKE 1 Reply Last reply
                    • sundberg84S sundberg84
                      ErrKE
                      ErrKE
                      ErrK
                      @sundberg84 Thanks for the explanation. I will try that tonight.
                      • ErrKE
                        ErrKE
                        ErrK
                        My first node stoped a few days ago, it was working for 14 days on 4 AA (its a 5v Arduino).
                        I forgot to add the Step Up Module 1-5V to 5V. So now it's up and running again.
                        Now i will try to do some modifications to save power. I have been looking at the guide General Tips for Battery Operationt but i don't find where i shuld do the cutting/desoldering on my board.
                        Here is it.
                        To know if i did the modifications right i want to measure the power with a multimeter, but i don't know how.
                        YveauxY 1 Reply Last reply
                        • ErrKE ErrK
                          Here is it.
                          YveauxY
                          YveauxY
                          @ErrK the power led and voltage converter can be removed to reduce power usage. The led is on the bottom right in your picture (turns on when power is on) and the voltage converter is the small black rectangle with 3 legs on the bottom-center.
                          Instead of removing the LED you can also remove it's current limiting resistor, which is next to the LED, to the left of the t from 'rst' on the right of the board.
                          • ErrKE
                            ErrKE
                            ErrK
                            Thanks @Yveaux i will try that tonight.
                            Hur do i measure how mutch power it use? To find out if i did it right.
                            • ErrKE
                              ErrKE
                              ErrK
                              I think i measure right.
                              Here is how i do.
                              The led:s resistor is gone and the voltage converter is gone.
                              But now it don't start, did i do anything wrong?
                              • ErrKE ErrK
                                Here is how i do.
                                With the voltage regulator removed the Arduino can no longer be powered on the raw pin. You need to supply it with maximum 3.3V on Vcc. 2xAA usually works well.
