  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • sundberg84S sundberg84
    @shabba - PCB only.
    I recommend using 3dhubs.com and find a local 3d printer for the case.
    Files (.stl) attached in the project.
    J
    J
    johmei
    @sundberg84
    Hi, do you have any local Swedish printing services to recommend?
    Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
    • J johmei
      @sundberg84
      @johmei - sorry, I wish i had any good recommendations for local PCB service.
      The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
      Good luck with your build! Images are always appreciated! ;)
      • J
        J
        johmei
        @sundberg84 - Thanks, but I was thinking about 3D printing services for boxes, cases and mounts in very small series (maybe even singles)?!
        Regarding images we'll see if I manage to get any AC stuff going anytime soon. I have a lot of respect for AC and probably want to get to know the Arduino platform a bit more first. Got my first couple of regular DC nodes running yesterday and they have been running really well for 12 hours now (impressed of the small nrf24+ radio range). So many ideas to explore. =)
        Actually ordered a set of your newbie PCBs a few days after my In wall AC PCB order so there will be a lot your autograph around my house..
        • J johmei
          @johmei - haha, I hope they will help you some in your quest for HA. About 3d printing I use 3dhubs.com and have tried different once and been satisfied. Go for one at your location if you want to pick up. I use one in Kalmar with shipping I can recommend.
          • J
            J
            johmei
            Can't help myself but have to see if I can get a AC node going. question regarding capacitors: C1 is specified as 10uF in the circuit diagram but the BOM states 0,1, 1,0, 4,7 uF capacitors. What is the recommendation from the creator? Thanks
            • J johmei
              @johmei - you are right and the BOM is updated.
              C1 should be a 10uF in my schematics, but its optional. Its recommended to have one higher and one 0.1uF capacitor with the voltage regulator since they can help avoiding spikes and drops.
              • S
                smilvert
                @sundberg84 Which housing are you using to this project? Can't find the stl-file. Does the 3dBoxWRelay.stl from the smd-project work here as well?
                • S smilvert
                  @smilvert - No, Im not sure.
                  I have not made a 3d box to the new version - let me have a look at that. Im working all weekend but i will look into it asap.
                  • J
                    J
                    johmei
                    Looking at the images and schematics(V4.1) it looks like the 18B20 and LE33 are soldered in the wrong way?! old images or am I looking at this wrong?
                    Still waiting for slow blow fuses so not ready to test yet.
                    • J johmei
                      @johmei - some parts was supposed to be soldered from the bottom side, so it depends :)
                      Keep it in mind when you are building. I might have to make this more clear somehow on the PCB as well.
                      • J
                        J
                        johmei
                        Ok, I was reffering to the pictures of the assembled board. My half done Node (no AC) works well with the two components "the other way". confised Traced the PCB connections before testing with 5VDC. =) As long as everyone double checks what they are doing it is no problem.
                        • J johmei
                          @johmei - "everyone doublecheck what they are doing" = that is a problem ;)
                          I will make a note on the page and change whats needed for next rev, thanks for notising!
                          • J
                            J
                            johmei
                            After quite a bit of abuse from resoldering components as I completely screwed up the order of things to get soldered I got the first couple of AC nodes running. These will be discarded once I get new Mini Pros to make fresh nodes without messing them up too much with my hot soldering iron. Been running them for 12 hours yesterday and everything seems fine. Great work on designing the PCBs @Sundberg84!
                            One tip is to cool the thermal cutoffs well while soldering. I broke the first one cooling it with pliers + aligator clip. Next I used water soaked paper around components and legs with great results. Just be mindful not to soak "the wrong components".
                            <blockquote class="imgur-embed-pub" lang="en" data-id="a/DBln7"><a href="//imgur.com/DBln7"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
                            • J johmei
                              @johmei - thank you! All tips for future revisions are appreciated! Let me know if I can do anything better and good luck with your nodes!
                              • J
                                J
                                johmei
                                I think the nodes seem to run really well with minimal produced heat. Do you think there will be a 3D case design for the latest version PCB? Unfortunately I have no knowledge in 3D design to contribute.
                                • J johmei
                                  @johmei - sorry, its been on my list as you probably see above.
                                  I will try to make one asap!
                                  • sundberg84S
                                    Finally I made the changes to the silk-screen so the orientation of the LE33 and Dallas temp sensor is right.
                                    Project updated and sent new revision to PCB manufacturer. The right revision if you want to buy should be Rev 4 which is the latest files (PCB Rev 4.1)
                                    • T
                                      The-Holgi
                                      wrote on last edited by The-Holgi
                                      #58
                                      i´have purchased the in wall pcb rev.3.1.
                                      Now i´m want to cut up the right part of the pcb and powering the pcb with 5V power adapter.
                                      Why is the VCC pin (lower arrow) with the arduino GND pin (upper arrow) connectet?
                                      The GND pin lower side is connectet to arduino VCC pin, is that a mistake?
                                      I´m think the print vcc and ground are reversed.
                                      • T The-Holgi
                                        @the-holgi Hi - hmm, this is an old revision and there might be misstakes as you describe. The current version is 4.1. Im traveling with work and dont have the documentation with me - but it should be quite easy to figure out if vcc and gnd are reversed by probing it with a multimeter. This PCB was not made to cut like this, but it might work - you have to try.
                                        • Y
                                          Y
                                          yoshida
                                          Just FYI: I have ordered 20pcb in January, and even though they are 4.1rev (pcbway), the le33a voltage regulator's silk screen still points to the wrong direction (flat side outwards). Also the second picture here mentions 4.1 rev, but I think this is an older rev. flat side outwards will connect the le33a Vin 5V leg to the Vin for the NRF2.4 in the 4.1 rev. Or the other way is that the orientation is good, but then it should be on the other side of the board :) So if it would be on the same side like the capacitors, it would be ok. (I have realized this after the third node built up wrongly.. :) )
                                          Do you know if the le33a gets 5V to the 3v3 leg, will it survive? Other components?
