  3. Controlling Relay Actuator
17 Posts 6 Posters 7.8k Views 5 Watching
  • P Offline
    P Offline
    PostaanErik
    Looking for some help with relay actuator and serial gateway.
    Having setup multiple arduino's with NRF's all working well when sending data to the gateway.
    For some reason no way to send anything to a sensor from the gateway with Domoticz or MYSController
    Does anyone recognize an issue in the screenshot?
    Using different Arduino's with different NRF's + Caps, 3.3v measured ( but according to serial log there is communication )
    Thanks for the support!
    • P Offline
      P Offline
      PostaanErik
      Sorry..the last 2 blue lines in the picture are send via MYSController, but no result in serial output of the sensor or a relay ticking....( relay is working when pressing physical button )
      • AndurilA Offline
        AndurilA Offline
        Anduril
        Could you please post your actuator sketch? Sounds like the node is not handling the incoming traffic.
        • P Offline
          P Offline
          PostaanErik
          Im using the default example sketch 1.5.3:
           * The ArduinoGateway prints data received from sensors on the serial link.
           * The gateway accepts input on seral which will be sent out on radio network.
           * The GW code is designed for Arduino Nano 328p / 16MHz
           * Wire connections (OPTIONAL):
           * - Inclusion button should be connected between digital pin 3 and GND
           * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
           * LEDs (OPTIONAL):
          #define NO_PORTB_PINCHANGES
          #include <MySigningNone.h>
          #include <MyTransportRFM69.h>
          #include <MyTransportNRF24.h>
          #include <MyHwATMega328.h>
          #include <MySigningAtsha204Soft.h>
          #include <MySigningAtsha204.h>
          #include <MyParserSerial.h>
          #include <stdarg.h>
          #include <PinChangeInt.h>
          #include "GatewayUtil.h"
          #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
          #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
          #define RADIO_ERROR_LED_PIN 4  // Error led pin
          #define RADIO_RX_LED_PIN    6  // Receive led pin
          #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
          MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
          //MyTransportRFM69 transport;
          // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
          //MySigningNone signer;
          //MySigningAtsha204Soft signer;
          //MySigningAtsha204 signer;
          // Hardware profile
          MyHwATMega328 hw;
          // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
          // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
          #ifdef WITH_LEDS_BLINKING
          MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
          #else
          MySensor gw(transport, hw /*, signer*/);
          char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
          int inputPos = 0;
          boolean commandComplete = false;  // whether the string is complete
          void parseAndSend(char *commandBuffer);
          void output(const char *fmt, ... ) {
             va_list args;
             va_start (args, fmt );
             vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
             va_end (args);
             Serial.print(serialBuffer);
            gw.begin(incomingMessage, 0, true, 0);
            setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
            // Add interrupt for inclusion button to pin
            PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
            // Send startup log message on serial
            serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
            gw.process();
            checkButtonTriggeredInclusion();
            checkInclusionFinished();
            if (commandComplete) {
              // A command wass issued from serial interface
              // We will now try to send it to the actuator
              parseAndSend(gw, inputString);
              inputPos = 0;
            SerialEvent occurs whenever a new data comes in the
           hardware serial RX.  This routine is run between each
           time loop() runs, so using delay inside loop can delay
           response.  Multiple bytes of data may be available.
          void serialEvent() {
            while (Serial.available()) {
              // get the new byte:
              char inChar = (char)Serial.read();
              // if the incoming character is a newline, set a flag
              // so the main loop can do something about it:
              if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                if (inChar == '\n') {
                  inputString[inputPos] = 0;
                  commandComplete = true;
                } else {
                  // add it to the inputString:
                  inputString[inputPos] = inChar;
                  inputPos++;
              } else {
                 // Incoming message too long. Throw away
                  inputPos = 0;
          • P Offline
            P Offline
            PostaanErik
            just enabled led blinking for the gateway. When pressing relay sensor button: RX and TX blink on serial gateway + serial out:
            send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
            read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:0
            This is an ack from gateway
            Incoming change for sensor:1, New status: 0italicised text
            When controlling with Domoticz or MYSController....nothing send to the serial gateway, no TX, RX
            :( Spending hours without any progress
            Is there something i did not configure? Just using the example sketch for the serial gateway and enabled Led's in myconfig
            • A Offline
              A Offline
              ahmedadelhosni
              Please post your actuator sketch not the GW. As said above, maybe you are not handling the incoming data to the actuator correctly.
              • P Offline
                P Offline
                PostaanErik
                Im using the example RelayWithButtonActuator:
                 * Version 1.0 - Henrik Ekblad
                 * Example sketch for a "light switch" where you can control light or something
                 * else from both HA controller and a local physical button
                 * (connected between digital pin 3 and GND).
                 * This node also works as a repeader for other nodes
                #include <Bounce2.h>
                #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                #define RELAY_ON 1
                #define RELAY_OFF 0
                Bounce debouncer = Bounce();
                int oldValue=0;
                bool state;
                MyMessage msg(CHILD_ID,V_LIGHT);
                  gw.sendSketchInfo("Relay & Button", "1.0");
                 // Setup the button
                  pinMode(BUTTON_PIN,INPUT);
                  // Activate internal pull-up
                  debouncer.attach(BUTTON_PIN);
                  debouncer.interval(5);
                  gw.present(CHILD_ID, S_LIGHT);
                  pinMode(RELAY_PIN, OUTPUT);
                  state = gw.loadState(CHILD_ID);
                  gw.process();
                  debouncer.update();
                  // Get the update value
                  int value = debouncer.read();
                  if (value != oldValue && value==0) {
                      gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                  oldValue = value;
                  if (message.isAck()) {
                     // Change relay state
                     state = message.getBool();
                     // Store state in eeprom
                     gw.saveState(CHILD_ID, state);
                     // Write some debug info
                     Serial.print(message.sensor);
                • S Offline
                  I have read alot of reports here lately with this issue in both Domoticz and Vera (pushing button works, but not sending from controller to relay). I dont know why but i tried it myself with 2.0b and exact the same behaivour. It works with my 1.4 relays but not 2.0...
                  I have no more info at this time but will try to figure something out when i have the time...
                  • S Offline
                    Have not been able to test this (@ work), but according to Domoticz github it looks like Domoticz sends V_STATUS to update a Lightning2.
                    In the sketch we have message.type == V_LIGHT
                    MySensors github:
                    S_LIGHT, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT
                    Domoticz github:
                    SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck);
                    MySensors Github RelayWityButtonAcc
                    Im not that good in understanding coding, but this would be the first im going to experiment with tonight.
                    • B Offline
                      B Offline
                      BartE
                      wrote on last edited by BartE
                      V_LIGHT and V_STATUS are complementary to each other they are both are defined as 2.
                      There are however a couple of remarks regarding your code.
                      1. when the button is pressed only a message is sent to the GW the relay is not toggled
                      2. when a state change request is received there is no status update sent to the gatewat
                      3. a minor issue debouncer.update() return true when a change change was detected so you do not have to remember the old state.
                      All three comments I've processed in the sketch below you might want to try this
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      bool state;
                       // Setup the button
                        gw.process();
                        // Get the update value and if push button was release toggle the relay and send an update to the gw
                        if (debouncer.update() && debouncer.read() != 0) {
                            state = state ? true : false;
                           // Send new state to the GW
                           gw.send(msg.set(state?false:true));
                      • S Offline
                        Sorry about that... yea see that they are the same now. Spared me some time there BartE - tnx. He is using the standard sketch and this has been working great ever since... strange.
                        • B BartE
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          bool state;
                           // Setup the button
                            gw.process();
                          martinhjelmareM Offline
                          martinhjelmare
                          @BartE
                          Regarding 1.
                          I think the point is to wait for the acknowledge from the controller before changing relay state, after the press of the button.
                          • S Offline
                            and regarding 2 - why send a statusupdate to controller when the status comes from the controller? The ack should be enough?
                            • S Offline
                              So, recreated this now - all standard sketch (2.0b) except I used pin 5 instead of pin4 for relay (due to PCB pinout layout, should not matter).
                              Everything works great both from Domoticz and Myscontroller but there was some small issues...
                              1. Power - my pro mini was just a little to weak to trigger the relay... :( It needs 5v but my pin 5 was only giving 4.7V and some tries resulted in a unsuccessful relay switch even if the logs told me so.
                              2. Radio - at some points i had the radio to close to the gw, so it didnt get the ACK and therefore i got the error "Error sending command, check device/hardware" message in Domoticz .
                              This is from Myscontroller, sending a on command with ack:
                              Correct seriallog node when incoming command from controller
                              read: 0-0-4 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                              send: 4-4-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                              Incoming change for sensor:1, New status: 1
                              What i dont know if why it works one way (command) but not the other (ack). I guess my GW radio is stronger, bigger or better powered.
                              • B Offline
                                B Offline
                                BartE
                                @sundberg84 your right the ack should be enough
                                @martinhjelmare this should be enough, but when for some reason your network is down you'r not able to control the devices locally
                                • martinhjelmareM Offline
                                  martinhjelmare
                                  Yes, good point.
                                  Maybe one could have a timeout event that compares button state with relay state, and after three failed comparisons, turns off the waiting for the acknowledge, as a sign of network failure.
                                  • S Offline
                                    @BartE, @martinhjelmare - this is sometime we should work with in the standard sketch.
                                    I have one relay on the edge and sometimes its having really hard to get that ack back from the controller and it never changes. It would be good if the relay made the switch, send the on/off to controller and waited for the ack. If you dont recieve it you send again and tries for some times.
