  3. Dual Gateways
Dual Gateways
3 Posts 3 Posters 1.4k Views 3 Watching
  • L
    L
    lafleur
    Is it possible to have a single GW with MQTT and a normal GW for Vera or two GW that talk to the same sensors??
    tbowmoT 1 Reply Last reply
    • L lafleur
      tbowmoT
      tbowmoT
      tbowmo
      @lafleur
      I don't think that you can with a 328p as a gateway.
      There are other options though. You could run nodered between your GW and vera/MQTT. @Anticimex is doing something in that area (not MQTT though) where he "shares" one GW between Vera and domoticz.
      • AnticimexA
        AnticimexA
        Anticimex
        Indeed, I use node-red for this. It also has nodes for MQTT but I have not looked into MQTT at all. My setup is a single rf24 based gw which through node-red interfaces with Vera, domoticz, myscontroller and on occasion, mycontroller. It can also push notifications to pushbullet, mail or other endpoints (through add on nodes in node-red). From a controller perspective, node-red uses serial nodes, which in turn become tcp ports through socat that the controllers connect to believing they interface with an ethernet gw.
