  3. Message.GetString() Error
7 Posts 4 Posters 3.2k Views 4 Watching
  • G
    G
    gloob
    wrote on last edited by gloob
    I have a problem with the Message.GetString() function.
    I send a RGB value in HEX format to the node and when reading out the message content I get a strange behavior.
    The serial console tells me the following
    read: 0-0-16 s=0,c=1,t=40,pt=0,l=6,sg=0:FF9A00
    But when I try to read the message value I get:
    HEX: FF9A00de
    In the code I do the following:
    String hexstring = message.getString(); //here goes the hex color code coming from through MySensors (like FF9A00)
    Serial.print("HEX: "); Serial.println(hexstring);
    I don't think that this is an issue of the controller or the Arduino sketch.
    does somebody have an idea how to solve this?
    Thanks.
    Stefan
    barduinoB 1 Reply Last reply
    • sundberg84S
      Hi Stefan!
      Which version do you run? We had an issue in early 1.6 which has been solved.
      If you run 1.6 this will go away if you download latest 2.0
      • G
        G
        gloob
        Currently I am using the latest stable version from the website:
        link text
        Should be version 1.5
        Do I need to do any changes in the controller, when I'm using the 2.0 version?
        Do I need to update the gateway as well?
        I'm right that the development tree is the version 2.0 you are talking about?
        • sundberg84S
          I dont think this was an issue in 1.5.... hmm, sorry - cant help you then. I hope someone else knows.
          • G
            G
            gloob
            I did now include a
            hexstring.substring(0,6)
            To only get the first 6 characters.
            • G gloob
              HEX: FF9A00de
              Thanks.
              Stefan
              barduinoB
              barduinoB
              barduino
              This post is deleted!
                wrote on last edited by hek
                Use:
                char *hextstring =  message.getString();
                Even though it's called getString we actually not use the String class (which isn't recommended to use on these small embedded systems)
