  3. MyController.org
  4. Buttons that send different signals to the same sensor
Scheduled Pinned Locked Moved MyController.org
3 Posts 3 Posters 1.9k Views 3 Watching
  • mwild95M
    mwild95M
    mwild95
    wrote on last edited by mwild95
    First of all love mycontroller. I love particularly that the front end is angularJS (I am a developer using AngularJS on my day to day)
    My situation is as follows:
    I have an arduino that is hooked up to a 433mhz transceiver. That arduino (through the serial monitor at the moment) takes a bit value and either turns a plug on or off based on the bit value.
    My question is:
    In the mycontrollers enviroment, how would you add functionality to be able to send these various bit values to the same sensor?
    Ideally I would like sections relating to each remote and buttons for on and off?
    Is this possible? Or something that I would need to implement myself?
    -----------------------------UPDATE-----------------------------------------
    Ok so my posting to the forum may have been a little bit premature.
    For anyone that may be new to this and wanted to know the solution...
    In my sketch I registered 4 sensors - one for each remote plug i had.
    In my incomingMessage function (which was passed the node id and binary value) I filter through which node I need to be emitting a signal to, and what signal to emit.
    Simple as that. If anyone would like the sketch let me know!
    B 1 Reply Last reply
    • mwild95M mwild95
      My question is:
      B
      B
      BastienVH
      @mwild95
      Could you share your sketch?
      I'm planning to mysensor-ize my 433 wall plugs and it might be a good starting point :-)
      • J
        J
        jkandasa
        @mwild95 for now with 0.0.3-alpha1 release you can configure with group payload ON/OFF. but there is a request for this feature. I will implement when I get time.
        https://github.com/mycontroller-org/mycontroller/issues/47
        Thank you!
