  3. MyController.org
  4. serial, Ethernet to MQTT
Scheduled Pinned Locked Moved MyController.org
serialethernetmqttbridgeconvertermycontroller
5 Posts 2 Posters 1.5k Views 2 Watching
  • J
    J
    jkandasa
    wrote on last edited by jkandasa
    I have developed a new MQTT bridge to convert from serial, ethernet to mqtt.
    Supports for MySensors.
    You can have more than one serial ports and/or ethernet connections.
    If you are interested in, https://github.com/mycontroller-org/2mqtt
    Thanks!
    YveauxY 1 Reply Last reply
    • J jkandasa
      Thanks!
      YveauxY
      YveauxY
      @jkandasa nice, but MySensors comes default with an MQTT gateway. Could you explain why you created this, what the advantages are?
      J 1 Reply Last reply
      • YveauxY Yveaux
        J
        J
        jkandasa
        @Yveaux Some people keep wants to use serial or ethernet for security reason. They do not want to use WiFi.
        But still, they can enjoy the benefits of MQTT
        • experiment different controllers via MQTT
        • can have the serial gateways on the different places and connected to a controller (everything connected via MQTT)
        • J jkandasa
          YveauxY
          YveauxY
          @jkandasa said in serial, Ethernet to MQTT:
          Of course, but MySensors MQTT gateway runs just as fine when connected over cabled ethernet, as when connected over wifi 😉
          • YveauxY Yveaux
            J
            J
            jkandasa
            @Yveaux said in serial, Ethernet to MQTT:
            I do not know that :)
            Now on this tool, I do not see much benefit from ethernet to MQTT ;)
            Still, it is good from serial to MQTT.
