  3. NRF24L01+ range of only few meters
81 Posts 21 Posters 52.7k Views 25 Watching
  • VooDooXV
    VooDooXV
    VooDooX
    Have you tried changing #define RF24_DATARATE in MyConfig.h from RF24_250KBPS to RF24_1MBPS or RF24_2MBPS?
    That helped in my case. But you have to recompile gateway and node(s).
    • HenryWhiteH HenryWhite
      @Anduril said:
      @HenryWhite yeah I have caps at all my nrfs. Will try with a different power source, as mine is attached to my pc usb as well. At least for testing it should work on batteries.
      If that doesn't help try exchanging the Gateway Radio module.
      AndurilA
      AndurilA
      Anduril
      @HenryWhite I tried with my ESP on battery and only get few meters range, too.
      Also changing radio did not change anything. But my radios are from the same seller, even if my second batch was ordered months after the first. So maybe still same typ of radios.
      I will check for @VooDooX hint and change datarates. I will report back...
      • petewillP petewill
        @epierre my notes are in inches so forgive me not converting it here. My thinking was to make a full wavelength antenna using the existing pcb antenna. A full wavelength antenna for 2.4GHz is 4.92 in. I measured the existing pcb antenna on the nRF and it was 1.64 in. So, 4.92 - 1.64 = 3.28 in. (or 8.3312 cm). I'm not claiming to be an expert at all (an other people have said this shouldn't work) but it has worked well for me so I keep doing it. :) Others have reported success too so hopefully it will help you.
        (thanks for your help @mfalkvidd)
        @nunver Have you changed the PA level to MAX in myconfig.h?
        epierreE
        epierreE
        epierre
        wrote on last edited by epierre
        #23
        @petewill when you solder you are at the end of the existing antenna, so you should add both length right ? and yes using imperial unit is well... non international ;-)
        z-wave - Vera -> Domoticz
        petewillP 1 Reply Last reply
        • epierreE epierre
          petewillP
          petewillP
          petewill
          @epierre Yep, 1.64 + 3.28 = 4.92in is that what you're referring to?
          • Igor KatkovI
            Igor KatkovI
            Igor Katkov
            I also have a poor range. With all the tricks:
            • pairs of electrolytic+ceramic capacitors
            • short leads
            • max out emittance power
            • lowered KBS to 250
            • increased retries and delays
            • free of wifi interference freq
            • lowered payload to 4 bytes
            • powered usb hub for gateway
            • laptop USB powered arduino for sensor
            • what I did not try - is separate step down regulator for radio
            I got 10m at most through couple of walls. These are plain wood frame + drywall + insulation walls.
            Even that was only possible with max power output on both sides and 250KB/s speed + 4bytes payload. I'm not sure if mysensor serial protocol allow to change payload size. I had to go down to roots of nrf24 programming to debug my poor reception.
            Payload size was the greatest impactor by the way I had to make my own test hardware+software to do these range tests (simple echo server, sending time back, thus 4 bytes payload)
            I've almost give up on nrf24 and ordered 4 hopeRF 483MHz transceivers for testing.
            • Igor KatkovI Igor Katkov
              • short leads
              @Igor-Katkov did you get better results with higher output power? I am no radio expert, but most stuff I have read says that higher output often results in worse signal to noise ratio.
              Igor KatkovI 1 Reply Last reply
                Igor KatkovI
                Igor KatkovI
                Igor Katkov
                @mfalkvidd Yes, a few more meters with PA_MAX.
                Here is my best performing code
                  radio.setPALevel(RF24_PA_MAX);
                  radio.setDataRate(RF24_250KBPS);
                  radio.setPayloadSize(4);
                  radio.setChannel(2);
                  radio.setRetries(15, 15);
                Full code https://gist.github.com/ikatkov/6df540838bd4d3ea8b57
                mfalkviddM vgaV 2 Replies Last reply
                  @Igor-Katkov interesting. Thanks for sharing!
                  • Igor KatkovI
                    Igor KatkovI
                    Igor Katkov
                    It appears that I was quite foolish expecting FTDI adapter board to power my nrf24 :-(
                    datasheet says it can provide at most 50mA.
                    I'll try 2AA batteries and a step up regulator
                    AWIA YveauxY 2 Replies Last reply
                      N
                      N
                      nunver
                      @petewill Yes, I did increase PA level to Max. I don't understand how I could change the payload size, though. Mysensors have a certain format.
                        AWIA
                        AWIA
                        AWI
                        @Igor-Katkov powering the radio from a switching regulator is no guarantee for radio performance. Most of these (small) regulators have a high voltage ripple around their switching frequency.
                        You have no need for it either... The radio should work perfectly when powered by two cells.
                        N 1 Reply Last reply
                        • AWIA AWI
                          N
                          N
                          nunver
                          @AWI It does not sound right to me having to use battery power where there is AC. There should be a way to get clean enough power for these little devices?
                          AWIA 1 Reply Last reply
                          • N nunver
                            AWIA
                            AWIA
                            AWI
                            @nunver sure, use a standard regulated power supply (phone charger) of 5v for the Arduino and make sure the radio gets a stable supply from a regulator. What always works is using one of those nrf24 adapter plates (look in the shop) for a stable radio.
                            • Igor KatkovI
                              Igor KatkovI
                              Igor Katkov
                              I was/am trying to make a battery powered wireless sensor so there would be no AC if I can avoid it.
                              I intended to use the step up regulator to 3v3 to extend sensor life on a pair of AA batteries. I think voltage would drop fairly quickly below nrf24 lower limit.
                                YveauxY
                                YveauxY
                                Don't count on that ftdi chip being genuine for only a few $$. I doubt if that data sheet applies to your unit...
                                  AWIA
                                  AWIA
                                  AWI
                                  wrote on last edited by AWI
                                  #36
                                  @Igor-Katkov Your AA batteries will be as good as dead before these drop below the nrf24 minimum voltage (1.9V). See below the graph for one cell. If the arduino survives depends on hardware/ fuse-settings.
                                  0_1455694674730_upload-9c67f65a-394a-4e60-a5fb-e25d0d8d2ba3
                                  • Igor KatkovI
                                    Igor KatkovI
                                    Igor Katkov
                                    wrote on last edited by Igor Katkov
                                    #37
                                    OK, so I tried with AA cells, no regulators.
                                    Plain and simple. TMRh20 lib.
                                    Not any better.
                                    I then tried with a chunk of bare copper wire 83mm long, soldered to the end of that curly PCB antenna - not any better either.
                                    Not sure what might I've done wrong. Layout is pretty simple
                                    image of nrf24 transmitter
                                    Voltage with load is 3.1V, current never goes above 19.2mA
                                    image of multimeter
                                    I tried with direct line of sight, range has doubled to say 20m, but again - nothing to write home about.
                                    • Igor KatkovI
                                      Igor KatkovI
                                      Igor Katkov
                                      [Update for future generation]
                                      I think I found my issue. It was the large transceiver see image below, with power amplifier and external antenna.
                                      Once I replaced both receiver and transmitter with identical units, range got significantly better.
                                      60m clear sight and almost whole house through multiple walls.
                                      For whatever reason small unit can't hear ACK from the PA unit. I tried to reduce power on the PA end to
                                       radio.setPALevel(RF24_PA_MIN);
                                      but it did not seem to have any effect. My best guess now is that oscillator on the PA unit is slightly off. PCB antenna unit is battery powered.
                                      Power source to arduino UNO that drives PA unit is good, 5V less that 2mV ripple. The transceiver is powered via 3V3 output (onboard regulator) of UNO though, could it be the problem?
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        Yes. But depends on which onboard regulator is used on your UNO.
                                        Also have an look here: http://forum.mysensors.org/topic/3168/long-range-transmission/27
                                          petewillP
                                          petewillP
                                          petewill
                                          I have had issues with my NRF radio like the one you mention here. I'm not sure about range issues but it totally stopped my Z-Wave network from communicating. It was easier for me to just use one of the smaller radios instead of doing further troubleshooting. I know there are some other threads (that I can't think of off the top of my head) where users have found that shielding it has helped. Also, as @Oitzu said, try powering it from a separate 3.3v source instead of from the Uno.
