  3. Battery button sensor
mysensor
18 Posts 10 Posters 6.8k Views 13 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/26/Battery-button-sensor
    • hekH Offline
      hekH Offline
      Great projects!
      Do you have a forum user?
      • Pierre PP Offline
        Pierre PP Offline
        Pierre P
        Oh YES it is a great project !
        No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
        • Ivan ZI Offline
          Ivan ZI Offline
          Ivan Z
          Yes I have
          • bjornhallbergB Offline
            bjornhallberg
            wrote on last edited by bjornhallberg
            Great idea for a compact button sensor such as a snailmail notifier or some such.
            Any thoughts on hardware debouncing ICs, such as MAX6816, MAX6817, MAX6818? Not to be a backseat driver here :) but something like that would be cool for a dedicated button sensor.
            • Ivan ZI Offline
              Ivan ZI Offline
              Ivan Z
              wrote on last edited by Ivan Z
              I wanted to make the most cheap device. And not set hardware debouncing.
              But set external pull-up resistors to reduce power consumption
              Sostware debouncing by delay in interrupt
              • scalzS Offline
                scalzS Offline
                Cool. Are the 6 buttons onboard, I don't think so??? does it need to wire them external?
                Is it a reset button on the pic? Maybe I am too curious lol, I can't read your schem (I don't have diptrace). A schematic img could be useful.
                anyway, thx for share :) I have a more complex actuator in design progress, but your can be useful too and is simple :)
                • Ivan ZI Offline
                  Ivan ZI Offline
                  Ivan Z
                  Shem in PDF https://www.openhardware.io/download/56b1cc6b3363a1515ea71115/design/Btn1.pdf
                  • scalzS Offline
                    scalzS Offline
                    oki I see :) so one onboard button, others are external. cool, can be useful. thx
                    • AnticimexA Offline
                      AnticimexA Offline
                      Anticimex
                      I see you use CERN OHL but I do not find the required files in the repo.
                      Where do you store those?
                      According to the CERN OHL 1.2 howto, you need to provide the following documentation with your project:
                      LICENSE.PDF
                      cern_ohl_v_1_2_howto.pdf
                      PRODUCT.TXT
                      CHANGES.TXT
                      Please check the howto closely for how to use the license, or pick another license.
                      • Ivan ZI Offline
                        Ivan ZI Offline
                        Ivan Z
                        Append license info
                        Debug device
                        sam debug photo
                        3_1455300763873_IMG_7113.JPG 2_1455300763873_IMG_7101.JPG 1_1455300763873_IMG_7099.JPG 0_1455300763873_IMG_7096.JPG image url)
                        • rvendrameR Offline
                          rvendrameR Offline
                          rvendrame
                          @Ivan-Z , how much do you expect for battery life (assuming a regular 250mA CR2032, in the scenario of a single button, regular daily usage in house lighting.
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          • Ivan ZI Offline
                            Ivan ZI Offline
                            Ivan Z
                            Update
                            • Error. Reversed MISO and MOSI
                            • Append Capacitor C1 on RESET
                            • Change diode component size to SOD-123
                            • Append Pad for external LED
                            Calculate battery life
                            Capacity rating of battery (mAh) = 250
                            Current consumption of device during sleep (mA) = 0.02
                            Current consumption of device during wake (mA) = 18
                            Number of wakeups per hour = 1
                            Duration of wake time (ms) = 20
                            Estimated battery life is: 440.51 days, or 1.21 years.
                            The device wakes up only when pressed button
                            • S Offline
                              Samuel235
                              This is pretty similar to what I'm currently doing, here. However, mine is just a light switch node, yours is more versatile by the looks of things. Looking pretty nifty though, nice work!
                              MySensors 2.1.1
                              • zeblongZ Offline
                                zeblongZ Offline
                                zeblong
                                @Ivan-Z Добрый день. Я тут новичек но мне ваше устройство хотелось бы попробовать. Я верно понимаю что тут не хватает документации что бы просто заказать производство плат (или изделий целиком)? Можете ли/хотите ли вы выложить их?
                                S 1 Reply Last reply
                                • zeblongZ zeblong
                                  Samuel235
                                  @zeblong
                                  As per the forum user guidelines, point 6 at the following link, https://forum.mysensors.org/topic/610/forum-user-guidelines, states;
                                  "6. As this is an English-speaking community, we require that posted content be in the English language, so that it can be well received and properly monitored."
                                  Please communicate using English spoken language, if anything it will help you get a response that is relevant.
                                  MySensors 2.1.1
                                  • zeblongZ Offline
                                    zeblongZ Offline
                                    zeblong
                                    @Samuel235
                                    Sorry. I will write in English.
                                    I want order manufacture this device. But manufacturer said to me that he need gerber and bom files. I want know can I get this files from Ivan? May be I can get this files from design files? What programm need to this?
                                    • zeblongZ zeblong
                                      @Samuel235
                                      Samuel235
                                      @zeblong, you can generate these from the board files, however i'm leaving this one for @Ivan-Z to discuss with you as this is his device and he knows all details regarding this.
                                      MySensors 2.1.1
