  3. #error No forward link or gateway feature activated.
18 Posts 4 Posters 11.6k Views 4 Watching
  • Wilco EliveldW
    Wilco EliveldW
    Wilco Eliveld
    Just started with MySensors, ordered a bunch of nrf24l01+ and now im trying to get things working.
    When i try to upload a sketch in Arduino 1.6.7 i get the following error message.
    In file included from /home/wilco/stack/documents/arduino/libraries/MySensors/MySensor.cpp:21:0:
    /home/wilco/stack/documents/arduino/libraries/MySensors/MySensor.h:285:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    can someone tell me the soluction? i didnt see this in any documentation
    Regards,
      You must either define a radio type or gateway type.
      You probably commented away one of them from the examples.
      Wilco EliveldW 1 Reply Last reply
        Wilco EliveldW
        Wilco EliveldW
        Wilco Eliveld
        Hi
        Where can i find this? can you give me a example?
          There are numerous examples in the "examples" folder under the MySensors library.
            Wilco EliveldW
            Wilco EliveldW
            Wilco Eliveld
            Yes i know, but all the examples are giving the same issues.
            So i miss something
              Hmm.. not sure what you could have done wrong. Have you mixed downloaded versions or something?
                Wilco EliveldW
                Wilco EliveldW
                Wilco Eliveld
                Nope, fresh install of everything.
                But.... im not sure if i must make some changes on MyConfig.H on old movies from youtube i see some settings which are not in MyConfig.H, See also no documentation so i assume it is not needed to make some changes to this file
                  No, all configuration can be controlled from sketch nowadays. So unless you want to change something globally for all sketches (like frequecy etc.) you can just set it in sketch.
                    Wilco EliveldW
                    Wilco EliveldW
                    Wilco Eliveld
                    wrote on last edited by Wilco Eliveld
                    Oke, where can i find those settings? because i dont know which settings are needed to get it working.
                    i ḿ playing with this file
                    https://raw.githubusercontent.com/mysensors/Arduino/development/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
                      You must have done some changes. Latest compiles fine here on my computer.
                        Wilco EliveldW
                        Wilco EliveldW
                        Wilco Eliveld
                        i only did a clone of the repo and copy all libraryś to my librarys dir
                        Gives also:
                        In file included from /tmp/arduino_c2cf6ad24e4a2a0e97af5bb50875ab91/sketch_feb04b.ino:1:0:
                        exit status 1
                        Error compiling.
                          Strange.
                          Just downloaded 1.6.7 (only difference from your setup). The RelayActuator sketch compiles just fine there as well.
                            Strange.
                            Wilco EliveldW
                            Wilco EliveldW
                            Wilco Eliveld
                            @hek said:
                            Strange.
                            i still think i need some parameters/settings somewhere..
                            get a exit status 1 because of the No Forward link message
                            edit:
                            When i use version 1.4 of MySensors i dont have the error message and compiles goes fine
                              The RelayActuator is working as-is. No more configuration is needed to make it compile.
                              • mikeM
                                mikeM
                                mike
                                I am having the same problem did you ever resolve it?
                                • mikeM mike
                                  Wilco EliveldW
                                  Wilco EliveldW
                                  Wilco Eliveld
                                  @mike Hi, no didnt find any fix for this.
                                  But on my Macbook everything works fine, the problem is only on a 32 bits linux machine.
                                  • mikeM
                                    mikeM
                                    mike
                                    @Wilco-Eliveld
                                    I think I found it. while learning Arduino IDE I had several copies of Arduino.exe installed in different locations. Short cuts link to different folder exe's and each folder had it's own librarys.
                                    the compiler was confused as to where to get it's include files. I am still wondering what the logic is as to where it looks. But I cleaned up the other libraries and deleted and re added the short cuts now it works correctly. As always when trouble shooting we spend hours on things that didn't work but only seconds on the actual fix.
                                    • SkysoftS
                                      SkysoftS
                                      Skysoft
                                      On development, I've this problem too...
