  3. I can get the WaterMeterPulseSensor working.
8 Posts 2 Posters 1.9k Views 2 Watching
  • ZwollenaarZ
    ZwollenaarZ
    Zwollenaar
    wrote on last edited by Zwollenaar
    Dear all,
    i am working to get the Water Pulse meter on Arduino to send the data to Domoticz. (through an RFXtrx322e)
    i am rather new to this, but the site looked easy to get this working, but apparently its i bit harder than i thought.
    So i am in need of your help.
    I use:
    • Arduino IDE 1.6.7 (linux 64Bit)
    • Mysensors 1.5 Library
    • Arduino UNO R3
    • RFM69HW (rev2) 433MHz (connected through a 3,3V regulator, including 4,7uF capacitor)
    i loaded the sketch, and i only get 'radio init fail'
    In MyConfig.h i enabled
    #define RFM69_FREQUENCY RF69_433MHZ
    i am not sure about enabling, cause till now it did'nt matter
    //#define MY_SIGNING_FEATURE
    In MyTransportRFM69.h i changed: false in to true
    bool isRFM69HW=true
    What did i miss, or do i need to change/check.
    Thanx in advance.
      Hi @Zwollenaar, welcome to MySensors!
      Could you post your sketch and how you wired the radio? It would help in troubleshooting.
      • ZwollenaarZ
        ZwollenaarZ
        Zwollenaar
        The code would be as i got it from the site, and its wired like this
        Only then for an UNO R3, that would look like:
        Wire setup
        But with the only differences
        • it has an 5V to 3,3V regulator and 4.7uF capacitor (instead of directly to 3.3V on the UNO board (wich also doesńt work...))
          (3.3V is supplied to the RFM69HW board, i got that checked / measured)
        • GND between ANA and SCK is also connected to ground.
         * Version 1.0 - Henrik Ekblad
         * Version 1.1 - GizMoCuz
         * Use this sensor to measure volume and flow of your house watermeter.
         * You need to set the correct pulsefactor of your meter (pulses per m3).
         * The sensor starts by fetching current volume reading from gateway (VAR 1).
         * Reports both volume and flow back to gateway.
         * Unfortunately millis() won't increment when the Arduino is in
         * sleepmode. So we cannot make this sensor sleep if we also want
         * to calculate/report flow.
         * http://www.mysensors.org/build/pulse_water
        #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
        #define SENSOR_INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
        #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
        #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
        #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
        #define CHILD_ID 1                              // Id of the sensor child
        unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
        MyMessage flowMsg(CHILD_ID,V_FLOW);
        MyMessage volumeMsg(CHILD_ID,V_VOLUME);
        MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
        double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
        volatile double flow = 0;
        boolean pcReceived = false;
        unsigned long newBlink = 0;
        double oldflow = 0;
        double volume =0;
        double oldvolume =0;
        unsigned long lastSend =0;
        unsigned long lastPulse =0;
          gw.begin(incomingMessage);
          // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
          pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
          gw.sendSketchInfo("Water Meter", "1.1");
          // Register this device as Waterflow sensor
          gw.present(CHILD_ID, S_WATER);
          pulseCount = oldPulseCount = 0;
          gw.request(CHILD_ID, V_VAR1);
          lastSend = lastPulse = millis();
          attachInterrupt(SENSOR_INTERRUPT, onPulse, FALLING);
          gw.process();
          unsigned long currentTime = millis();
          if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
            lastSend=currentTime;
            if (!pcReceived) {
              //Last Pulsecount not yet received from controller, request it again
              return;
            if (!SLEEP_MODE && flow != oldflow) {
              oldflow = flow;
              Serial.print("l/min:");
              Serial.println(flow);
              // Check that we dont get unresonable large flow value.
              // could hapen when long wraps or false interrupt triggered
              if (flow<((unsigned long)MAX_FLOW)) {
                gw.send(flowMsg.set(flow, 2));                   // Send flow value to gw
            // No Pulse count received in 2min
            if(currentTime - lastPulse > 120000){
              flow = 0;
            // Pulse count has changed
            if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
              oldPulseCount = pulseCount;
              Serial.print("pulsecount:");
              Serial.println(pulseCount);
              gw.send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
              double volume = ((double)pulseCount/((double)PULSE_FACTOR));
              if ((volume != oldvolume)||(!SLEEP_MODE)) {
                oldvolume = volume;
                Serial.print("volume:");
                Serial.println(volume, 3);
                gw.send(volumeMsg.set(volume, 3));               // Send volume value to gw
          if (SLEEP_MODE) {
            gw.sleep(SEND_FREQUENCY);
          if (message.type==V_VAR1) {
            unsigned long gwPulseCount=message.getULong();
            pulseCount += gwPulseCount;
            flow=oldflow=0;
            pcReceived = true;
        void onPulse()
          if (!SLEEP_MODE)
            unsigned long interval = newBlink-lastBlink;
            if (interval!=0)
              if (interval<500000L) {
                // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                return;
              flow = (60000000.0 /interval) / ppl;
            lastBlink = newBlink;
          pulseCount++;
        ZwollenaarZ 1 Reply Last reply
        • ZwollenaarZ Zwollenaar
          Wire setup
          double oldflow = 0;
          double volume =0;
            gw.process();
              if (!pcReceived) {
                return;
                oldflow = flow;
                flow = 0;
                  oldvolume = volume;
            if (SLEEP_MODE) {
              flow=oldflow=0;
              pcReceived = true;
          void onPulse()
            if (!SLEEP_MODE)
              if (interval!=0)
                  return;
            pulseCount++;
          ZwollenaarZ
          ZwollenaarZ
          Zwollenaar
          This post is deleted!
            The wiring instructions say "NOTE: The NSS, MOSI and SCK are not 5V tolerant on RFM69. You will need to use a level converter if you're using a 5V Arduino." The Uno is 5V. So you might have fried your radio :( Except that everything looks fine to me but I haven't tried the RFM69 myself.
              ZwollenaarZ
              ZwollenaarZ
              Zwollenaar
              @mfalkvidd
              i have the RFM69 HW connected through a 3,3V regulator (including capacitor), so there was never 5V on de Radio board.
              iĺl add it to the first post aswell.
                @mfalkvidd
                @Zwollenaar The signals (pin 2, 10, 11, 12, 13) from the Uno are also 5V.
                • ZwollenaarZ
                  ZwollenaarZ
                  Zwollenaar
                  ouch, i need to look in to that, but then it might me true the board is damaged...
                  (Some other sketches seem to report data to the serial monitor, but i am not sure if the RFM69HW module is working.)
