  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.2k Views 9 Watching
  • T Tag
    gui is looking great!,
    have been playing with the software and found the following:
    in resources/nodes, all my nodes (mysensors 15,x) are shown as "down" while they are sending data...is this a setup issue?
    and for the weather forcast only N/A is shown and not the value from the sensor.....
    rest looks great! really like the dashboard feature!
    J
    J
    jkandasa
    Thank you for the report and allocated time to test MyController.
    MyConttroller was looking I_HEARTBEAT_RESPONSE. From your question I understand that we should make up when we receive any message from node. I will work on it.
    These are all the weather station mapping icons from https://erikflowers.github.io/weather-icons/
              value:"day-sunny",
              value:"day-cloudy",
              value:"day-thunderstorm",
              value:"na",
              value:"na",
              value:"na",
    Source:https://github.com/mycontroller-org/mycontroller/blob/development/src/main/package/www/services/common_services.js#L286
    we have to update this mapping based on our community members feedback.
    Thank you!
    T 1 Reply Last reply
    • A
      A
      anarro
      +1 I want to beta test, (and if you want.. colaborate to translate at lenguage Spanish..)
      Good job!
      J 1 Reply Last reply
      • A anarro
        Good job!
        J
        J
        jkandasa
        Good job!
        Thank you! Spanish already available. Kindly send request to https://www.transifex.com/mycontrollerorg/gui-angularjs/language/es_AR/
        • J jkandasa
                    value:"day-sunny",
                    value:"day-cloudy",
                    value:"na",
                    value:"na",
                    value:"na",
          Thank you!
          Tag
          Just tested the common services script, works like a charm, best thing is, forecast is Sunny!! :)
          • J
            J
            jkandasa
            Hello every one thank you for your support and feedback on beta test. In another couple of days I'm going to release 0.0.3-alpha1 to public. Kindly report your issues, if you face any. I will try to fix it before release.
            Also update your locale. https://www.transifex.com/mycontrollerorg/multi-locale/dashboard/
            Demo server updated till commit #523. demo.mycontroller.org
            • A
              A
              anarro
              wrote on last edited by anarro
              #26
              After update (and stop/start) I show this:
              Pd.
              I copied all files and folders..
              sorry, excuse my ignorance..
              Thanks!
              Antoni.
              • A anarro
                Pd.
                Thanks!
                Antoni.
                J
                J
                jkandasa
                Pd.
                Thanks!
                Antoni.
                you have to extract bindle zip file. call mycontroller/bin/start.sh . If you were using old version of MyController.org server. stop it first.
                Refresh your browser.(clear cache).
                A 1 Reply Last reply
                • J jkandasa
                  Pd.
                  Thanks!
                  Antoni.
                  A
                  A
                  anarro
                  #28
                  @jkandasa, I deleted the cache and work fine!!, now let's testing..
                  Pd.
                  For the next release, how do we do the updates?... first we need save the file "./conf/mycontroller.property", and data base file (which)?
                  thanks you!!
                  Antoni.
                  • A anarro
                    Pd.
                    thanks you!!
                    Antoni.
                    J
                    J
                    jkandasa
                    Pd.
                    thanks you!!
                    Antoni.
                    Note: MyController.org going to support upgrade and restore from 0.0.3-alpha1 version.
                    You can take a backup via GUI and keep safe backup file. Extract new release on different location, point out backup up file and do restore. that's it.
                    • J jkandasa
                      Pd.
                      thanks you!!
                      Antoni.
                      A
                      A
                      anarro
                      #30
                      @jkandasa, This version is awesome !!, his work is spectacular.
                      Antoni.
                      • A
                        A
                        anarro
                        When I click on "Backup" option its show this:
                        Thank you,
                        Antoni.
                        • A anarro
                          Thank you,
                          Antoni.
                          J
                          J
                          jkandasa
                          wrote on last edited by jkandasa
                          #32
                          Thank you,
                          Antoni.
                          Yes, you will face this issue, when MyController.org server unable to access given backup location.
                          A 2 Replies Last reply
                          • J jkandasa
                            Thank you,
                            Antoni.
                            A
                            A
                            anarro
                            This post is deleted!
                            • J jkandasa
                              Thank you,
                              Antoni.
                              A
                              A
                              anarro
                              @jkandasa said:
                              Thank you,
                              Antoni.
                              Yes, where this option is set ?, as I fix it?
                              • A anarro
                                @jkandasa said:
                                Thank you,
                                Antoni.
                                J
                                J
                                jkandasa
                                @anarro said:
                                @jkandasa said:
                                Thank you,
                                Antoni.
                                • A
                                  A
                                  anarro
                                  Hi Sr!,
                                  I think it would require a button to return to the previous window in the backups, it is possible?, you think the same?
                                  Antoni.
                                  • A anarro
                                    Hi Sr!,
                                    Antoni.
                                    J
                                    J
                                    jkandasa
                                    @anarro said:
                                    Hi Sr!,
                                    Antoni.
                                    hi, If you click on backup menu on top. it will take you!
                                    • J jkandasa
                                      @anarro said:
                                      Hi Sr!,
                                      Antoni.
                                      A
                                      A
                                      anarro
                                      @jkandasa,
                                      Yes, I had seen, but.. I think it was more intuitive (personal opinion.)
                                      • A anarro
                                        @jkandasa,
                                        J
                                        J
                                        jkandasa
                                        @anarro said:
                                        @jkandasa,
                                        Thank you for the feedback. Ok I will add Back button.
                                        • hoegaarden_bierH
                                          hoegaarden_bierH
                                          hoegaarden_bier
                                          Some typos in English language when adding a widget:
                                          Do a search on ' grpahica' => 'graphical'
