  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.3k Views 33 Watching
  • Pavel HrudkaP
    Pavel HrudkaP
    Pavel Hrudka
    Hi.
    I just added your binding and I am very happy for it because I have spent quite some time to figure out, how do I integrate mySensors in to Openhab.
    My setup
    RPI2
    did apt-get update && apt-get upgrade
    OpenHab (openHAB runtime has been started (v1.8.1))
    I have NRF24L01+ connected directly to RPI using SPI.
    I am running PiGatewaySerial service and Iam able to see communication when i do
    sudo cat /dev/ttyMySensorsGateway
    for example
    7;255;3;0;15;0
    7;255;0;0;17;1.5.4
    7;255;3;0;6;0
    7;255;3;0;11;Humidity
    7;255;3;0;12;1.0
    7;0;0;0;7;
    7;1;0;0;6;
    My problem is that openHab is unable to access /dev/ttyMySensorsGateway
    I see error in my logs
    2016-03-11 23:30:11.288 [ERROR] [.o.b.m.internal.gateway.Serial] - Unable to find Serial port '/dev/ttyMySensorsGateway'
    java.lang.NullPointerException: null
            at org.openhab.binding.mysensors.internal.gateway.Serial.write(Serial.java:82) ~[na:na]
            at org.openhab.binding.mysensors.internal.MySensorsBinding.execute(MySensorsBinding.java:178) ~[na:na]
            at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
            at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
    I found @BastienVH post and modified /etc/init.d/openhab JAVA_ARGS_DEFAULT section and added at the end of defintion
     -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway"
    and restarted service
    Sadly, there was no change.
    Please can you help?
    Thank you.
    andredtsA 2 Replies Last reply
    • Pavel HrudkaP Pavel Hrudka
      Hi.
      My setup
      RPI2
      for example
      7;255;3;0;15;0
      7;255;0;0;17;1.5.4
      7;255;3;0;6;0
      7;255;3;0;12;1.0
      7;0;0;0;7;
      7;1;0;0;6;
      Thank you.
      andredtsA
      andredtsA
      andredts
      @Pavel-Hrudka
      I use RP2 with internal serial connected directly to ATmega328 chip. So it is also a unconventional serial. And for that to work I had to put the line " -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway" on my start.sh file, before the line that has ".jar"
      Hope it helps
        Hi.
        My setup
        RPI2
        for example
        7;255;3;0;15;0
        7;255;0;0;17;1.5.4
        7;255;3;0;6;0
        7;255;3;0;12;1.0
        7;0;0;0;7;
        7;1;0;0;6;
        Thank you.
        andredtsA
        andredtsA
        andredts
        @Pavel-Hrudka
        On my last post I miss lid you, copping your own line, but actually to use raspberry internal serial you have to add to Openhab's start.sh "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " before the line with the ".jar" because the serial got to start before you run the biddings.
        Hope it helps.
        • Pavel HrudkaP
          Pavel HrudkaP
          Pavel Hrudka
          Hi thank you.
          I solved my issue, but when I wanted to update my post, the thread was locked.
          Here in this post its said that I should create link to virtual port like this
          sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
          Pointing OpenHab binding to this port solved my problem.
          I did try to add command line parameter to /init.d script for OpenHab but that did not work.
          Cheers.
          Pavel
          • FrancoisF
            FrancoisF
            Francois
            Hi I am new to openHAB how do you configure a relay node? I do see the node in the logs but the relay don't what to switch on or off. I have my temp and humidity sensors working already.
            18:38:50.450 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Dimmable device of some kind): node-id=95, sensor-id=0 with type S_DIMMER
             * Example item: 95;0;V_STATUS             - Binary status. (on/off)
             * Example item: 95;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
             * Example item: 95;0;V_WATT               - Watt value for power meters
            Regards
            Francois
            • Mark JeffordM
              Mark JeffordM
              Mark Jefford
              Quick question, trying to integrate the mysprinkler project into openhab.
              getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
              i have the triggering working, just can't configure the runtime.
              any help appreciated.. will do a guide if it get it working :)
              • Harry GomezH
                Harry GomezH
                Harry Gomez
                I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
                2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
                2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
                [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
                [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
                [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
                [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
                [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
                [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
                regards
                Harry
                T 1 Reply Last reply
                • Harry GomezH Harry Gomez
                  regards
                  Harry
                  ted
                  @Harry-Gomez
                  From https://github.com/openhab/openhab/wiki/Serial-Binding
                  If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                  whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
                  Harry GomezH 1 Reply Last reply
                  • T ted
                    @Harry-Gomez
                    Harry GomezH
                    Harry GomezH
                    Harry Gomez
                    I tried that but it did not work - this is how part of the /etc/init.d/openhab looks - any other ideas - i did not needed this with the RPi2 and wheezy
                    JAVA_ARGS_DEFAULT="-Dosgi.clean=true
                    -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0
                    -Declipse.ignoreApp=true
                    -Dosgi.noShutdown=true
                    -Djetty.port=${HTTP_PORT}
                    -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
                    -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
                    -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
                    -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
                    -Djetty.home="${OPENHAB_DIR}"
                    -Djetty.port.ssl=${HTTPS_PORT}
                    -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
                    -Djetty.logs="${OPENHAB_LOG_DIR}"
                    -Djetty.rundir="${OPENHAB_DIR}"
                    -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
                    -Dfelix.fileinstall.filter=.*\.jar
                    -Djava.library.path="${OPENHAB_DIR}/lib"
                    -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
                    -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
                    -Dequinox.ds.block_timeout=240000
                    -Dequinox.scr.waitTimeOnBlock=60000
                    -Dfelix.fileinstall.active.level=4
                    -Djava.awt.headless=true
                    -jar ${LAUNCHER}
                    -configuration ${OPENHAB_WORKSPACE_DIR}
                    -data ${OPENHAB_WORKSPACE_DIR}
                    -console ${TELNET_PORT}"
                      -jar ${LAUNCHER}
                      ted
                      @Harry-Gomez
                      What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
                      Harry GomezH zeblongZ 2 Replies Last reply
                      • T ted
                        @Harry-Gomez
                        Harry GomezH
                        Harry GomezH
                        Harry Gomez
                        @ted
                        Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
                        Thanks!!
                        • FrancoisF
                          FrancoisF
                          Francois
                          wrote on last edited by Francois
                          #32
                          Hi what is the syntax for a relay in openhab using this binding?
                          This in what I get in the log but the light do not switch on or off.
                          2016-03-27 20:37:00.068 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                          2016-03-27 20:37:00.889 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                          2016-03-27 20:37:01.622 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                          2016-03-27 20:37:02.407 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                          2016-03-27 20:37:03.247 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                          This is the syntax that I am use and it is not working. Also try V_LIGHT without any luck.
                          Switch LightSwitch_GF_Study	"Study Light  [%s]"				<light> 	(GF_Study)			{mysensors="41;1;V_BINARY"}
                          andredtsA bklB 2 Replies Last reply
                          • FrancoisF Francois
                            andredtsA
                            andredtsA
                            andredts
                            @Francois
                            Hi, I use {mysensors="12;0;V_STATUS"}. Remember to give your node a ID, because OH does not give one.
                              bklB
                              bklB
                              bkl
                              Hi @Francois
                              The syntax look OK.
                              This is what i have working.
                              Switch  Relay_10_0              "Relay 1"                       <none>                                  {mysensors="10;0;V_STATUS"}
                              Try and turn on debug log for mysensors
                              Add this to logback.xml
                              <logger name="org.openhab.binding.mysensors" level="DEBUG" />
                              • FrancoisF
                                FrancoisF
                                Francois
                                Hi @bkl
                                Are you using the standard relay sketch with this binding or did you change anything in the sketch as I just don't get my relay to work.
                                Here is my log with the above string in my logback.xml.
                                17:28:48.825 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor node found: node-id=15
                                 * Example item: 15;255;I_BATTERY_LEVEL      - Use this to report the battery level 0-100 (%)
                                 * Example item: 15;255;I_SKETCH_NAME        - Sketch name that can be used to identify sensor
                                 * Example item: 15;255;I_SKETCH_VERSION     - Sketch version that can be reported to keep track of the version of sensor
                                17:28:48.827 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                17:28:50.856 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=11,pt=0,l=25,sg=0:Main Bedroom Relay & Butt
                                17:28:50.858 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_NAME"
                                17:28:50.860 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
                                17:28:50.862 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_VERSION"
                                17:28:50.864 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                17:28:50.867 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Binary device (on/off)): node-id=15, sensor-id=1 with type S_BINARY
                                 * Example item: 15;1;V_STATUS             - Binary status. (on/off)
                                 * Example item: 15;1;V_WATT               - Watt value for power meters
                                17:28:51.457 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'LightSwitch_GF_Study' with state 'ON' in rrd4j database (again)
                                17:28:51.460 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                                17:28:51.500 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                                17:28:51.503 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                17:28:51.719 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:29.1
                                17:28:51.722 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Hum_GF_Study = 29.1
                                17:28:51.729 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'Hum_GF_Study' with state '29.1' in rrd4j database
                                17:28:51.760 [INFO ] [runtime.busevents             :26   ] - Hum_GF_Study state updated to 29.1
                                17:28:51.762 [DEBUG] [.b.m.internal.MySensorsBinding:248  ] - internalReceiveUpdate(Hum_GF_Study,29.1) is called!
                                17:28:51.862 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                                17:28:51.864 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                17:28:52.045 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                                17:28:52.075 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                                17:28:52.077 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                17:28:52.252 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                                17:28:52.255 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                17:28:52.448 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                                17:28:52.451 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                17:28:52.648 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                17:28:52.650 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                                17:28:52.654 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                17:28:52.659 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Motion_GF_Study = ON
                                17:28:52.662 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'Motion_GF_Study' with state 'OFF' in rrd4j database (again)
                                • bklB bkl
                                  @BastienVH
                                  Note2: If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                                  skatunS
                                  skatunS
                                  skatun
                                  @bkl
                                  So my question (linux newbie) is what is the best way to attach my Arduino nano to rpi, so that it always find it on reboot or if it is unplugged/replugged.
                                  Is this correct and will this work with the binding?
                                  /etc/udev/rules.d/99-usb-serial.rules"
                                  with my device info:
                                  SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A40360T2", SYMLINK+="ttyUSB99"
                                  • T ted
                                    @Harry-Gomez
                                    zeblongZ
                                    zeblongZ
                                    zeblong
                                    @ted
                                    Hi
                                    I use RASPBIAN JESSIE.
                                    Command minicom -b 115200 -o -D /dev/ttyUSB0 show traffic from serial gateway.
                                    I write -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 to /usr/share/openhab/bin/openhab.sh and /etc/init.d/openhab but still 'Unable to find Serial port '/dev/ttyUSB0''.
                                    Please help me
                                    • zeblongZ zeblong
                                      @ted
                                      Hi
                                      Please help me
                                      Harry GomezH
                                      Harry GomezH
                                      Harry Gomez
                                      wrote on last edited by Harry Gomez
                                      #38
                                      @zeblong
                                      for me I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0\ right at the begining for it to work at usr/share/openhab/bin/openhab.sh - i removed from /etc/init.d/openhab it did not make a difference. below is how it looks for me. also check the output if dmesg for changes in tty. I also use jessie on a RPi3
                                      -Duser.timezone=America/Los_Angeles
                                      -jar ${LAUNCHER}
                                      -console ${TELNET_PORT}" \
                                      ~ $ dmesg |grep tty
                                      [ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x71ef84a5 smsc95xx.macaddr=B8:27:EB:EF:84:A5 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                      [ 0.001288] console [tty1] enabled
                                      [ 0.267235] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
                                      [ 0.919548] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
                                      [ 2.166808] systemd[1]: Starting system-getty.slice.
                                      [ 2.170421] systemd[1]: Created slice system-getty.slice.
                                      [ 3.635870] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
                                      zeblongZ bklB 2 Replies Last reply
                                        @zeblong
                                        -jar ${LAUNCHER}
                                        ~ $ dmesg |grep tty
                                        zeblongZ
                                        zeblongZ
                                        zeblong
                                        @Harry-Gomez
                                        That's all well done. does not work. It may be necessary to install any more bindings or the Java packages?
                                        • zeblongZ zeblong
                                          @Harry-Gomez
                                          Harry GomezH
                                          Harry GomezH
                                          Harry Gomez
                                          @zeblong
                                          Do you have the serial package installed --> org.openhab.io.transport.serial-1.8.2.jar?
                                          Did you add openhab to dialout group -> sudo usermod -a -G dialout openhab
                                          What is the error on you logs?
                                          zeblongZ 1 Reply Last reply
