  3. Domoticz
  4. Problems getting a RFM69HW gateway to work in domoticz
16 Posts 4 Posters 5.5k Views 4 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    Have anyone had any difficulties getting an gateway using RFM69HW radio to work in domoticz?
    • hekH Offline
      hekH Offline
      The radio driver shouldn't matter. Domoticz isn't aware of how data is transported.
        Cliff Karlsson
        Ok, any ideas of what my problem can be?
        I have tried using 3.3v mini pros+ RFM69H+W.
        I used serial monitor on both gateway and node and all seems to start up and send/recieve data.
        I have used MYScontroller and Gateway starts up and recieves data.
        I have flashed RFM gateway/node sketches from lowpowerlab and everything seems to transfer/recieve correctly.
        I have tried both stable and beta of domoticz and even formatted/reinstalled my rpi controller.
        I am using a powered usb-hub to connect to the gateways to the rpi.
        I have connected the mini pro gateway to the controller using both 3.3v ftdi clone and a genuine arduino ftdi 3.3v
        I have tried several versions of Arduino IDE from 1.6.6 to nightly.
        I have tried mysensors stable 1.5.1, beta 1.6 and beta 2.0
        I have both NRF01 gateway and Rf-link gateway connected and both works perfectly.
        But as soon as I connect a nano/mini pro with RFM radio it never works. A few times I get "gateway ready" and "gateway version 1.6-beta etc."
        Often when I get gateway ready and version to show up correctly, as soon as I start up a sensor with RFM radio I get 5-6 "gateway ready" and "gateway version 1.6-beta etc." repeats in the log.
        But most of the time I get only "gateway ready" and no verison id in the log. And under hardware I only get a "?" in the gateway version info.
        What can I do to troubleshoot my setup?
        • hekH Offline
          hekH Offline
          So, data from your sensors is received by gateway?
            Cliff Karlsson
            Yes If I use mysensors controller sketch on a mini pro with RFM69HW and a random sensor sketch on another mini pro + RFM69H I recieve data when the gateway is connected to the computer and I use the serial monitor in the arduino IDE.
            I have also tried the same thing with the lowpowerlab sketches and I also recieve data in that way.
              Cliff Karlsson
              Can it be something that domotics does not like that I connect 3.3v mini pro's using FTDI->USB adapters supplying 3.3v instead of 5v?
              I forgot to say that often when everything seams to detect correctly, as soon as I power up a sensor I often get some error in domotics complaining of "serial lost" or something like that.
                martinhjelmareM Offline
                martinhjelmare
                @Cliff-Karlsson
                Can you adjust the baud rate in domoticz for the serial connection?
                • hekH Offline
                  hekH Offline
                  Yeah, lowering baudrate could help.
                    Cliff Karlsson
                    In the beta it defaults to 115000 or something witch I believe is correct. It is also possible to change to 4800 baud /mini pro/sensbender or something like that. But I have never got anything to show up when changing that setting.
                      martinhjelmare
                      @Cliff-Karlsson
                      An arduino at 8 MHz will not be able to communicate reliably at 115200 bps with a computer over serial.
                      38400 or perhaps 57600 at the highest should work.
                        Cliff Karlsson
                        i have used RFM69HW adapter on all the recent tries witch should be ok, right?
                        I have also used 868Mhz antennas that I have got from ebay. Could faulty antennas cause something like that?
                        • hekH Offline
                          hekH Offline
                          You'll also have to lower the baudrate in MyConfig.h before compiling/uploading the gateway. No need to touch the sensor node.
                            Cliff Karlsson
                            This post is deleted!
                              Cliff Karlsson
                              Ahhhhhhh!!!!!!!!!!!!, thank you!!!!!! It finally works. 38400 was the other selectable baudrate specified in domoticz and it started working rightaway after selecting the right settings.
                                martinhjelmare
                                @Cliff-Karlsson
                                :thumbsup:
                                • John TolJ Offline
                                  John TolJ Offline
                                  John Tol
                                  wrote on last edited by John Tol
                                  Hi Cliff, could you be so kind to share the full sketch with us? I'm also having trouble getting this RFM69HW to work.
