  3. Motion Sensor triggering on its own
39 Posts 19 Posters 31.5k Views 13 Watching
  • rvendrameR rvendrame
    @Maciej-Kulawik , how are you powering the node? I had once a PIR false-triggering due power instabilities...
    Maciej Kulawik
    @rvendrame I'm powering all with 2xAA baterries. On PIR I removed regulator. The problem with false trigerring is independent from voltage level. It is the same if I put old baterries (2,8V) or brand new (3,2V).
    @fifipil909 I also suspect that it is somehow connected to powering noises and mcu sleeping. In my one case PIR is triggering each minute - and sleep time is also one minute.
    • rvendrameR
      rvendrameR
      rvendrame
      @Maciej-Kulawik , maybe if you try to power the PIR with +5V for a while and watch the results? Don't forget to keep all GNDs inter-connected...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • SweebeeS
        SweebeeS
        Sweebee
        I'm also having this issue at 3V. It gets triggered if there is a (little) voltage drop. All my pirs only wake with an interrupt and no timer, then it works fine. But with a sleep timer it won't work the normal way.
        At 5V everything works fine.
        Maybe @fifipil909 's solution works.
        • ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          I was testing the below sensor with 3.3v and it was reporting false status. It worked well with 5v. Although the site claims it works between 3 to 5 volts.
          Maybe power issues
          http://store.fut-electronics.com/products/pir-motion-sensor-module-adjustable-range
          M 1 Reply Last reply
          • ahmedadelhosniA ahmedadelhosni
            Maybe power issues
            Maciej Kulawik
            @ahmedadelhosni All those PIRs are built using the same chip. All all have 3,3v regulator onboard, so they always work with 3,3v. I don't understand why powering directly with 3,2v from battery makes so trouble.
            Maybe this LDO regulator adds some additional stabilisation/filtering on power line, when powered with greater voltage...
            rvendrameR ahmedadelhosniA 2 Replies Last reply
            • M Maciej Kulawik
              rvendrameR
              rvendrameR
              rvendrame
              @Maciej-Kulawik It can be that the on-board LDO needs more than 3.3v to activate. It maybe even dropping the voltage from batteries, and doing nothing but disturbing :-) Maybe it worth to remove it when running the circuit with 3V from batteries.
              Alexa / Google Home
                Maciej Kulawik
                @rvendrame But I work only with pirs with ldo removed (and diode).
                rvendrameR 1 Reply Last reply
                • M Maciej Kulawik
                  rvendrameR
                  rvendrameR
                  rvendrame
                  @Maciej-Kulawik if so, your PIR looks to need at least 3.3V, so the ~3V from 2xAA is not enough and it is causing instabilities (probably the same as reported by others here).
                  Alexa / Google Home
                  • M Maciej Kulawik
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    @Maciej-Kulawik I didnt know that info. Thanks.
                    • L
                      L
                      LastSamurai
                      Did you guys get them working? I tried to power the pir sensor via the "H" pad directly with 3.3V from a boost converter (via a coin cell). Now I get random readings that I didn't have when using a stable 3.3V source. Any ideas how to solve this?
                      I haven't (yet) removed the voltage regulator on board. Perhaps that might help...
                      • ChakkieC
                        ChakkieC
                        Chakkie
                        wrote on last edited by Chakkie
                        #31
                        I have the same issue first when I tried to power the PIR with the VCC from the arduino mini pro 3.3V. It seems like the PIR does not work with 3.3V. Now I power the PIR directly from the 9V battery. Problem solved.
                        Raspberry Pi 2
                        Domoticz
                        RFXCOM
                        ZWAVE Aeon stick
                        Coming soon Arduino mysensors GW
                        • fifipil909F
                          fifipil909F
                          fifipil909
                          False detection is only due to power stability issue.
                          Personnaly i remove the regulator and power the PIR without any boost on the VCC pin. Even below 2v the PIR continue working without any a single issue.
                          Did you try to do a small delay before sleeping with interupt ? See my post a bit upper.
                          For me it solve all my false trigger issue.
                          • m26872M
                            m26872M
                            m26872
                            I know this thread's about hc-501. But I guess one can apply some of my hc-505 (mini-pir) experiences from here:
                            https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                            • F
                              F
                              Fabien
                              wrote on last edited by Fabien
                              #34
                              Same problem here every time m node wake-up I have a false trigger. With delay (@fifipil909) it's not better
                              • L
                                L
                                LastSamurai
                                Mhm I still have strange results from my PIR sensor (doesn't even seem to be the wake up that influences them).
                                I have the pir with diode and voltage regulator removed powered by a boost converter with the low pass filter and a pull down resistor. Using a clean 3.3V worked though, but I really want to use batteries (with sometimes less than 3V). Directly powering the sensor with the 2.x V did not work either.
                                For one of the guys with working sensors: what is your exact setup? None of the tipps I found seem to work. I would really love to get one sensor running. Only idea I still have is to try with another sensor.
                                Here is the code I am currently using:
                                #ifdef DEBUG
                                #define DEBUG_SERIAL(x) Serial.begin(x)
                                #define DEBUG_PRINT(x) Serial.print(x)
                                #else
                                // Initialize motion message
                                  DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                  DEBUG_PRINTLN("Serial started");
                                  gw.begin();
                                  gw.sendSketchInfo("Motion Sensor Test", "24052016");
                                  gw.present(CHILD_ID, S_MOTION);
                                  // Read digital motion value
                                  DEBUG_PRINT("Got tripped: ");
                                  DEBUG_PRINTLN(tripped);
                                  gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                  DEBUG_PRINTLN("Sleeping till next interrupt");
                                  //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                  // Sleep until interrupt comes in on motion sensor. Won't wake up otherwise
                                  gw.sleep(500);
                                  gw.sleep(INTERRUPT, CHANGE, 0);
                                  //gw.sleep(INTERRUPT, RISING, 0);
                                • L
                                  L
                                  LastSamurai
                                  Does anyone have an idea how to get the pir sensor running with a coin cell? Or perhaps if that doesn't work with 2 aa's? See my post above
                                  • L
                                    L
                                    Luca Fabbriani
                                    Sorry for necroposting on my first forum post but I have the exact same issue at the moment. I power PIR sensors from the same 3.3V switching regulator that powers an esp12 module. I took off the anti-inversion diode and the linear regulator, added a 470uF and 100nF capacitor on the sensor supply input. This has been done to two sensors, one is working flawlessly the other one has a false trigger once every half an hour.
                                    Adding HF and LF bypass capacitors with some improvement told me that was a supply instability issue but it's not solving the problem completely. My suspect is that the polarity inversion diode that I took off had a role in the play improving the supply voltage stability.....I'll try to put back the diode and I'll let you know.
                                    cheers
                                    Luca
                                    • N
                                      N
                                      Natezimmer
                                      This is an issue i've been fighting for awhile as well. In industry, i've encountered PIR modules / old sensors can be susceptible to high freq interference. E.g. I have WiFi on my PI.
                                      1. Ensure the PIR is a 6in+ physical distance from your dev board / any radios. This helps.
                                      2. Ensure no high freq noise can couple on any of the 3 wires connected to the PIR
                                      I did #2 via a PI filter. Inductors + a cap. Ideally i'd have caps at both ends of high and low values for both frequency contents. The signal line itself can couple noise so ideally a ferrite bead + resistor to snub any type of noise. I've had to employ similar strategies with other sensors to deal w/ interference issues.
                                      • W
                                        W
                                        Wikibear
                                        Have this same issue and it makes me crazy... I use a step up converter DCDC 1.8V up to 3.3 input and output 3.3V. If solder from DCDC Out via 220uF direct soldered after stabilizer of HC501 direct on pcb and sometimes it will detect motion where no motion happens. I use two AA accu and i know that they have together 2,4V. Less voltage less current. But i try also with normal AA 3V then i have this issue not so often. But i have. It will much more if the voltage will more less.
