  3. Motion Sensor triggering on its own
39 Posts 19 Posters 31.6k Views 13 Watching
  • ErrKE
    ErrKE
    ErrK
    Thanks @Jan-Gatzke it did not work for me this time.
    I'm using a 5v Arduino Pro mini and when i measure the power on the HC-SR501 i get 3.71v.
    When i measure the power on the VCC i get 3.69v and when i measure the RAW i get 5.43v.
    Here you can se how everything is wired, I use the Easy/Newbie PCB by @sundberg84.
    First i used the 5v cable to the raw on the PCB and then it did't work.
    When I change to connect to the PWR then it works. Don't know why. Maybe @sundberg84 know why?
    • sundberg84S
      sundberg84S
      Hi @ErrK.
      Work your way backwards with the multimeter. Are you powering with 5v there shouldnt be a drop to 3v. Check volt over arduino and then vcc output. As i said work you way backwards in the circuit.
      I suspect a faulty hardware somewhere, measure the input and output on the voltage regulator on the arduino.
      • ErrKE ErrK
        @Maciej-Kulawik Thanks.
        Today my second node started to do this too.
        I have tried to change the HC-SR501 and the problem seams to be on the node and not on the sensor.
        Can i see how you fixed this in the sketch?
        Maciej Kulawik
        @ErrK In my case PIR switches into HIGH for some seconds (depending on potentiometer), so reading after 100ms will give the same value.
        @ErrK Unfortunately my solution is not 100% reliable. For 2 of my nodes it works well, but for 3rd node (the same hardware, the same sketch, only PCB is a little bi different - previous version, but difference only in dimension) - pir is false triggerring almost each minute (sometimes with 2 minutes delay with false triggering). And I checked - it is not caused by NRF sending. I have no idea whats going on.
        • rvendrameR
          rvendrameR
          rvendrame
          @Maciej-Kulawik , how are you powering the node? I had once a PIR false-triggering due power instabilities...
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • fifipil909F
            fifipil909F
            fifipil909
            i'm wanted to share my experience also with those sensor.
            I had a lot of issue with false trigger when running on 3.3V. In my case the power was definitely the issue.
            it's looks like sleeping the radio/mcu cause some noise on the voltage line.
            I solve 100% of my false trigger issue when doing a small sleep, before enabling the sleep with interrupt.
            gw.sleep(500);
            gw.sleep(INTERRUPT,RISING, SLEEP_TIME);
            • rvendrameR rvendrame
              Maciej Kulawik
              @rvendrame I'm powering all with 2xAA baterries. On PIR I removed regulator. The problem with false trigerring is independent from voltage level. It is the same if I put old baterries (2,8V) or brand new (3,2V).
              @fifipil909 I also suspect that it is somehow connected to powering noises and mcu sleeping. In my one case PIR is triggering each minute - and sleep time is also one minute.
              • rvendrameR
                rvendrameR
                rvendrame
                @Maciej-Kulawik , maybe if you try to power the PIR with +5V for a while and watch the results? Don't forget to keep all GNDs inter-connected...
                Alexa / Google Home
                • SweebeeS
                  SweebeeS
                  Sweebee
                  I'm also having this issue at 3V. It gets triggered if there is a (little) voltage drop. All my pirs only wake with an interrupt and no timer, then it works fine. But with a sleep timer it won't work the normal way.
                  At 5V everything works fine.
                  Maybe @fifipil909 's solution works.
                  • ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    I was testing the below sensor with 3.3v and it was reporting false status. It worked well with 5v. Although the site claims it works between 3 to 5 volts.
                    Maybe power issues
                      Maybe power issues
                      Maciej Kulawik
                      @ahmedadelhosni All those PIRs are built using the same chip. All all have 3,3v regulator onboard, so they always work with 3,3v. I don't understand why powering directly with 3,2v from battery makes so trouble.
                      Maybe this LDO regulator adds some additional stabilisation/filtering on power line, when powered with greater voltage...
                      rvendrameR ahmedadelhosniA 2 Replies Last reply
                      • M Maciej Kulawik
                        rvendrameR
                        rvendrameR
                        rvendrame
                        @Maciej-Kulawik It can be that the on-board LDO needs more than 3.3v to activate. It maybe even dropping the voltage from batteries, and doing nothing but disturbing :-) Maybe it worth to remove it when running the circuit with 3V from batteries.
                        Alexa / Google Home
                          Maciej Kulawik
                          @rvendrame But I work only with pirs with ldo removed (and diode).
                          rvendrameR 1 Reply Last reply
                          • M Maciej Kulawik
                            rvendrameR
                            rvendrameR
                            rvendrame
                            @Maciej-Kulawik if so, your PIR looks to need at least 3.3V, so the ~3V from 2xAA is not enough and it is causing instabilities (probably the same as reported by others here).
                            Alexa / Google Home
                            • M Maciej Kulawik
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @Maciej-Kulawik I didnt know that info. Thanks.
                              • L
                                L
                                LastSamurai
                                Did you guys get them working? I tried to power the pir sensor via the "H" pad directly with 3.3V from a boost converter (via a coin cell). Now I get random readings that I didn't have when using a stable 3.3V source. Any ideas how to solve this?
                                I haven't (yet) removed the voltage regulator on board. Perhaps that might help...
                                • ChakkieC
                                  ChakkieC
                                  Chakkie
                                  wrote on last edited by Chakkie
                                  #31
                                  I have the same issue first when I tried to power the PIR with the VCC from the arduino mini pro 3.3V. It seems like the PIR does not work with 3.3V. Now I power the PIR directly from the 9V battery. Problem solved.
                                  Raspberry Pi 2
                                  Domoticz
                                  RFXCOM
                                  ZWAVE Aeon stick
                                  Coming soon Arduino mysensors GW
                                  • fifipil909F
                                    fifipil909F
                                    fifipil909
                                    False detection is only due to power stability issue.
                                    Personnaly i remove the regulator and power the PIR without any boost on the VCC pin. Even below 2v the PIR continue working without any a single issue.
                                    Did you try to do a small delay before sleeping with interupt ? See my post a bit upper.
                                    For me it solve all my false trigger issue.
                                    • m26872M
                                      m26872M
                                      m26872
                                      I know this thread's about hc-501. But I guess one can apply some of my hc-505 (mini-pir) experiences from here:
                                      https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                                      • F
                                        F
                                        Fabien
                                        wrote on last edited by Fabien
                                        #34
                                        Same problem here every time m node wake-up I have a false trigger. With delay (@fifipil909) it's not better
                                        • L
                                          L
                                          LastSamurai
                                          Mhm I still have strange results from my PIR sensor (doesn't even seem to be the wake up that influences them).
                                          I have the pir with diode and voltage regulator removed powered by a boost converter with the low pass filter and a pull down resistor. Using a clean 3.3V worked though, but I really want to use batteries (with sometimes less than 3V). Directly powering the sensor with the 2.x V did not work either.
                                          For one of the guys with working sensors: what is your exact setup? None of the tipps I found seem to work. I would really love to get one sensor running. Only idea I still have is to try with another sensor.
                                          Here is the code I am currently using:
                                          #ifdef DEBUG
                                          // Initialize motion message
                                            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                            gw.begin();
                                            gw.sendSketchInfo("Motion Sensor Test", "24052016");
                                            gw.present(CHILD_ID, S_MOTION);
                                            // Read digital motion value
                                            DEBUG_PRINT("Got tripped: ");
                                            DEBUG_PRINTLN(tripped);
                                            gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                            DEBUG_PRINTLN("Sleeping till next interrupt");
                                            //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                            // Sleep until interrupt comes in on motion sensor. Won't wake up otherwise
                                            gw.sleep(500);
                                            gw.sleep(INTERRUPT, CHANGE, 0);
                                            //gw.sleep(INTERRUPT, RISING, 0);
                                          12.5k
