  3. Motion Sensor triggering on its own
39 Posts 19 Posters 31.6k Views 13 Watching
  • ErrKE ErrK
    @Maciej-Kulawik Thanks.
    Today my second node started to do this too.
    I have tried to change the HC-SR501 and the problem seams to be on the node and not on the sensor.
    Can i see how you fixed this in the sketch?
    Maciej Kulawik
    @ErrK In my case PIR switches into HIGH for some seconds (depending on potentiometer), so reading after 100ms will give the same value.
    @ErrK Unfortunately my solution is not 100% reliable. For 2 of my nodes it works well, but for 3rd node (the same hardware, the same sketch, only PCB is a little bi different - previous version, but difference only in dimension) - pir is false triggerring almost each minute (sometimes with 2 minutes delay with false triggering). And I checked - it is not caused by NRF sending. I have no idea whats going on.
    • rvendrameR
      rvendrameR
      rvendrame
      @Maciej-Kulawik , how are you powering the node? I had once a PIR false-triggering due power instabilities...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • fifipil909F
        fifipil909F
        fifipil909
        i'm wanted to share my experience also with those sensor.
        I had a lot of issue with false trigger when running on 3.3V. In my case the power was definitely the issue.
        it's looks like sleeping the radio/mcu cause some noise on the voltage line.
        I solve 100% of my false trigger issue when doing a small sleep, before enabling the sleep with interrupt.
        gw.sleep(500);
        gw.sleep(INTERRUPT,RISING, SLEEP_TIME);
        • rvendrameR rvendrame
          Maciej Kulawik
          @rvendrame I'm powering all with 2xAA baterries. On PIR I removed regulator. The problem with false trigerring is independent from voltage level. It is the same if I put old baterries (2,8V) or brand new (3,2V).
          @fifipil909 I also suspect that it is somehow connected to powering noises and mcu sleeping. In my one case PIR is triggering each minute - and sleep time is also one minute.
          • rvendrameR
            rvendrameR
            rvendrame
            @Maciej-Kulawik , maybe if you try to power the PIR with +5V for a while and watch the results? Don't forget to keep all GNDs inter-connected...
            Alexa / Google Home
            • SweebeeS
              SweebeeS
              Sweebee
              I'm also having this issue at 3V. It gets triggered if there is a (little) voltage drop. All my pirs only wake with an interrupt and no timer, then it works fine. But with a sleep timer it won't work the normal way.
              At 5V everything works fine.
              Maybe @fifipil909 's solution works.
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                I was testing the below sensor with 3.3v and it was reporting false status. It worked well with 5v. Although the site claims it works between 3 to 5 volts.
                Maybe power issues
                  Maybe power issues
                  Maciej Kulawik
                  @ahmedadelhosni All those PIRs are built using the same chip. All all have 3,3v regulator onboard, so they always work with 3,3v. I don't understand why powering directly with 3,2v from battery makes so trouble.
                  Maybe this LDO regulator adds some additional stabilisation/filtering on power line, when powered with greater voltage...
                  rvendrameR ahmedadelhosniA 2 Replies Last reply
                  • M Maciej Kulawik
                    rvendrameR
                    rvendrameR
                    rvendrame
                    @Maciej-Kulawik It can be that the on-board LDO needs more than 3.3v to activate. It maybe even dropping the voltage from batteries, and doing nothing but disturbing :-) Maybe it worth to remove it when running the circuit with 3V from batteries.
                    Alexa / Google Home
                      Maciej Kulawik
                      @rvendrame But I work only with pirs with ldo removed (and diode).
                      rvendrameR 1 Reply Last reply
                      • M Maciej Kulawik
                        rvendrameR
                        rvendrameR
                        rvendrame
                        @Maciej-Kulawik if so, your PIR looks to need at least 3.3V, so the ~3V from 2xAA is not enough and it is causing instabilities (probably the same as reported by others here).
                        Alexa / Google Home
                        • M Maciej Kulawik
                          ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          @Maciej-Kulawik I didnt know that info. Thanks.
                          • L
                            L
                            LastSamurai
                            Did you guys get them working? I tried to power the pir sensor via the "H" pad directly with 3.3V from a boost converter (via a coin cell). Now I get random readings that I didn't have when using a stable 3.3V source. Any ideas how to solve this?
                            I haven't (yet) removed the voltage regulator on board. Perhaps that might help...
                            • ChakkieC
                              ChakkieC
                              Chakkie
                              wrote on last edited by Chakkie
                              #31
                              I have the same issue first when I tried to power the PIR with the VCC from the arduino mini pro 3.3V. It seems like the PIR does not work with 3.3V. Now I power the PIR directly from the 9V battery. Problem solved.
                              Raspberry Pi 2
                              Domoticz
                              RFXCOM
                              ZWAVE Aeon stick
                              Coming soon Arduino mysensors GW
                              • fifipil909F
                                fifipil909F
                                fifipil909
                                False detection is only due to power stability issue.
                                Personnaly i remove the regulator and power the PIR without any boost on the VCC pin. Even below 2v the PIR continue working without any a single issue.
                                Did you try to do a small delay before sleeping with interupt ? See my post a bit upper.
                                For me it solve all my false trigger issue.
                                • m26872M
                                  m26872M
                                  m26872
                                  I know this thread's about hc-501. But I guess one can apply some of my hc-505 (mini-pir) experiences from here:
                                  https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                                  • F
                                    F
                                    Fabien
                                    wrote on last edited by Fabien
                                    #34
                                    Same problem here every time m node wake-up I have a false trigger. With delay (@fifipil909) it's not better
                                    • L
                                      L
                                      LastSamurai
                                      Mhm I still have strange results from my PIR sensor (doesn't even seem to be the wake up that influences them).
                                      I have the pir with diode and voltage regulator removed powered by a boost converter with the low pass filter and a pull down resistor. Using a clean 3.3V worked though, but I really want to use batteries (with sometimes less than 3V). Directly powering the sensor with the 2.x V did not work either.
                                      For one of the guys with working sensors: what is your exact setup? None of the tipps I found seem to work. I would really love to get one sensor running. Only idea I still have is to try with another sensor.
                                      Here is the code I am currently using:
                                      #ifdef DEBUG
                                      // Initialize motion message
                                        DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                        gw.begin();
                                        gw.sendSketchInfo("Motion Sensor Test", "24052016");
                                        gw.present(CHILD_ID, S_MOTION);
                                        // Read digital motion value
                                        DEBUG_PRINT("Got tripped: ");
                                        DEBUG_PRINTLN(tripped);
                                        gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                        DEBUG_PRINTLN("Sleeping till next interrupt");
                                        //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                        // Sleep until interrupt comes in on motion sensor. Won't wake up otherwise
                                        gw.sleep(500);
                                        gw.sleep(INTERRUPT, CHANGE, 0);
                                        //gw.sleep(INTERRUPT, RISING, 0);
                                      • L
                                        L
                                        LastSamurai
                                        Does anyone have an idea how to get the pir sensor running with a coin cell? Or perhaps if that doesn't work with 2 aa's? See my post above
                                        • L
                                          L
                                          Luca Fabbriani
                                          Sorry for necroposting on my first forum post but I have the exact same issue at the moment. I power PIR sensors from the same 3.3V switching regulator that powers an esp12 module. I took off the anti-inversion diode and the linear regulator, added a 470uF and 100nF capacitor on the sensor supply input. This has been done to two sensors, one is working flawlessly the other one has a false trigger once every half an hour.
                                          Adding HF and LF bypass capacitors with some improvement told me that was a supply instability issue but it's not solving the problem completely. My suspect is that the polarity inversion diode that I took off had a role in the play improving the supply voltage stability.....I'll try to put back the diode and I'll let you know.
                                          cheers
                                          Luca
                                          12.5k
