  3. MQTT Gateway and output controller in one?
2 Posts 2 Posters 1.1k Views 2 Watching
  • Bay101B
    Bay101B
    Bay101
    This is my first post on this forum so I hope it is in the right place.
    At the moment I have two Arduinos that control my room automation setup.
    One is set up as a MySensors MQTT gateway that connects to the broker running on my Pi.
    The other is controlling power point outputs that have a remote control that has been modified to be controlled with the pins on the Arduino, These are currently being controlled over serial to openHAB. Is there any way to combine the MySensors MQTT gatway and the power point controller into one device (With the power point controller being moved from serial to MQTT/MySensors)?
    Current Code on the MQTT Gateway:
    // Set this nodes subscripe and publish topic prefix
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "MySensors-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "MySensors-in"
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 10,0,0,202
    #define MY_IP_GATEWAY_ADDRESS 10,0,0,138
    #define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 201
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    void presentation() {
      // Send locally attech sensors data here
    Current Code on the power point controller:
    int PowerOnPin = 11;
    int PowerOffPin = 12;
      pinMode(PowerOnPin, OUTPUT);
      pinMode(PowerOffPin, OUTPUT);
      Serial.begin(9600);
    //checking for availiable serial data
    //if avaliable it is acted upon
    if (Serial.available() > 0) {
     String input = "";
     while (Serial.available() > 0){
      input += (char) Serial.read();
      delay(5);
     if (input == "ON"){
            TurnOn();
     else if(input == "OFF"){
         TurnOff();
    void TurnOff() {
     digitalWrite(PowerOffPin, HIGH);
     delay(1000);
     digitalWrite(PowerOffPin, LOW);
     delay(1000);
    void TurnOn() {
     digitalWrite(PowerOnPin, HIGH);
     delay(1000);
     digitalWrite(PowerOnPin, LOW);
     delay(1000);
    Thanks :smile: ,
    Bay101
      Yes, it should be possible. Convert the serial node to use MySensors. The relay example should be a good base. Add the converted code to the mqtt sketch and you should be fine.
