S_MULTIMETER Help
Hi
I am building a sensor to monitor a small solar/battery combination and am trying to use the Multimeter device to measure current in and out of the battery. I am using a 5amp ASC712 to read the current and then send the result to my Domoticz server.
I am getting the data back to Domoticz ok but it is not formatting as i would of hoped. The device is being shown as type Current, CM113. For example if I send 1.250 the Domoticz device will only show 1.2A . As the ASC712 can read current flow in both directions I can also send negative numbers when the battery is discharging, so if I send -2.350 the Domoticz device shows 2.3A and ignores the negative number.
I am thinking this may be a limitation of S_MULTIMETER ?
Interestingly using V_VOLTAGE results in showing three decimal places but V_CURRENT shows only one decimal place.
any help would be much appreciated.
Thanks I will give that a try. I guess I could use two V_CURRENT devices, one for charging and one for discharging but an all in one would be better.
