  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.5k Views 4 Watching
  • freedomoticF freedomotic
    @barduino
    any news about your simulator?
    barduinoB
    barduinoB
    barduino
    @freedomotic
    Actually yes.
    I did a major refactor recently (here) and in a last minute update it ended up on the development branch of the 1.5 library, here
    This is intented to be used with at least 2 arduinos, a normal gateway and a fake sensors arduino mocking signals. It should support all the 24 sensors from lib 1.4.1.
    Not sure how you could take this and adapt to your situation since i'm using the MySensors library and it wont run without the radios.
    Cheers
    • freedomoticF
      freedomoticF
      freedomotic
      @barduino
      My plugin is based on serial protocol so I need to generate some "serial" strings as the gateway does. Now I'm using a serial data port emulator to write manually these strings. If I read your fake frames from serial (without using a gateway) maybe I could solve the problem
      Freedomotic Iot & Smart Spaces framework
      http://www.freedomotic.com
        The MySensors project could perhaps support you by donating a couple of radios and arduino boards so you can make the necessary tests properly. Please contact me.
        • freedomoticF
          freedomoticF
          freedomotic
          Hi @hek
          thanks for your offer.
          • freedomoticF
            freedomoticF
            freedomotic
            a new version of our plugin is available on the marketplace.
            More info on http://freedomotic.com/content/plugins/mysensors
            • freedomoticF
              freedomoticF
              freedomotic
              Hi all
              finally the first Release Candidate version of Commander is available.
              You can download it from http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc1.zip/download
              We ask your help: try it and share your feedback here or filling out the form at https://goo.gl/CC65By
              Share your experience about Freedomotic: only 5 minutes of time to answer our survey at https://goo.gl/Iq8C6e
              Thanks in advance
              • freedomoticF
                freedomoticF
                freedomotic
                Hi
                we are looking for Swedish translators for our project. If you want to give us a hand please reply.
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Hi all
                  Freedomotic 5.6 Commander RC2 is out and can be downloaded from
                  http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc2.zip/download
                  We fixed some bugs and in particular included the first draft of a web client.
                  After starting Freedomotic go to http://localhost:8090 in your browser and digit admin/admin as username/password.
                  You can access from another pc in your network by changing in the previous URL "localhost" with the ip of the machine running Freedomotic.
                  The web client doesn't have all features included in the java frontend but they can run at the same time.
                  If you want to use only the web client please remove the folder "frontend-java" under plugins/devices.
                  We need your help in different areas:
                  • testing (not all browsers are 100% html5-compatible)
                  • functionality
                  • usability/UX
                  • graphics/layout
                  So report your comments/issues on https://goo.gl/CC65By
                  If you want to contribute take a look at the source code https://github.com/freedomotic and at our tracking system http://freedomotic.myjetbrains.com/youtrack/issues
                  Stay tuned!
                  • freedomoticF
                    freedomoticF
                    freedomotic
                    Hi all,
                    we moved our issues tracker to github.
                    Take a look at https://github.com/freedomotic/freedomotic/issues
                    freedomoticF 1 Reply Last reply
                      Hi all,
                      freedomoticF
                      freedomoticF
                      freedomotic
                      Hello
                      in this video https://youtu.be/G98U2Q3cCVc you can see our Telegram bot plugin in action.
                      We need your feedback to improve it.
                      • freedomoticF
                        freedomoticF
                        freedomotic
                        Hi all
                        Freedomotic 5.6 Commander RC4 is out and can be downloaded from https://sourceforge.net/projects/freedomotic/files/latest/download?source=recommended
                        We fixed some bugs and introduced new functionalities.
                        If you want to contribute take a look at the source code https://github.com/freedomotic and https://github.com/freedomotic/freedomotic/issues
                        Stay tuned!
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          Hi all
                          we are working on a new web client for our domotic framework.
                          Here some screenshots
                          It's a WIP so we need any help to complete it.
                          The code is available at https://github.com/freedomotic/fd-vue-webapp/
