  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 116.6k Views 58 Watching
  • S Offline
    shabba
    Hi all.
    Hands up I have not read the whole thread so apologies! I was just wondering on status of RFM69? I am about to embark on an upgrade of all my node from rf24 -> rfm69 and 1.5 -> 2.0 and would like to also add OTA while I am at it.
    Thanks!
    • F Fabien
      I try to add new hex file in MYSController 1.0 but after clicking "reload repo", it tells me 2107-15-31 is not a valid date specification. I don't have the ability to select firmware after this. And after a reboot the "reload repo" is garyed.
      Arduino ide 1.6.7
      csv :
      Type,Name,Version,File,Comments
      10,Blink,1,Blink.ino.hex,blinking example
      20,TimeReporter,1,TimeReporter.ino.hex,TimeReporter demo
      30,SenseBender,1,SensebenderMicro.ino.hex,Sensebender micro
      Another 'bug". It always ask me to download a "new" version ... I install it but ask me again (1.0 beta)
      I think this issue is related to the last arduino IDE version.
      rubyanR Offline
      rubyanR Offline
      rubyan
      @Fabien You have two or more blank lines in your firmware_config.csv. This causes the error message. If you remove them and click on Reload Repo the error will be gone.
      • abmantisA abmantis
        Yeah, the bootloader works well with the v2.0 release.
        The major issue it has currently is that sometimes it takes quite a long time to flash a sketch. It seems that when the wireless connection is not perfect, it stops for 2 or 3 seconds multiple times. Like, send 10 packages, stop 3 seconds, send 5 packages, stop again.
        yd kimY Offline
        yd kimY Offline
        yd kim
        @abmantis
        I have same problem. Did you solve the problem?
        abmantisA 1 Reply Last reply
        • yd kimY yd kim
          @abmantis
          abmantisA Offline
          abmantisA Offline
          abmantis
          @yd-kim What problem?
          yd kimY 1 Reply Last reply
            yd kimY Offline
            yd kimY Offline
            yd kim
            @abmantis
            You did post following 2months ago and I have same problem too.
            If you solve the problem, please share it.
            Thanks.
            • yd kimY yd kim
              @abmantis
              Thanks.
              abmantisA Offline
              abmantisA Offline
              abmantis
              @yd-kim Ah that! Nope, unfortunately it stills takes a long time to flash. We probably need an updated bootloader.
              • AndurilA Offline
                AndurilA Offline
                Anduril
                @abmantis DO you have the serial upload working? I never got it working and gave up some day. I am using the old bootloader which is uploading ota much faster than the new. Maybe you can also test and confirm this?
                yd kimY abmantisA 2 Replies Last reply
                • AndurilA Anduril
                  yd kimY Offline
                  yd kimY Offline
                  yd kim
                  @Anduril
                  I did some thest.
                  1.3Pre.hex in 1.0.0Beta : it works with serial upload but take too long time(about an hour) to use OTA or fail.
                  1.1 (?) which is in 0.1.2 folder : it takes about 10 minutes and works well but doesn't work with Serial upload which is normal way to upload firmware in Arduino.
                  Thank you for all help.
                  dpressleD 1 Reply Last reply
                  • yd kimY yd kim
                    @Anduril
                    I did some thest.
                    dpressleD Offline
                    dpressleD Offline
                    dpressle
                    i couldn't get the 1.3pre work with serial upload, its interesting to see you could.
                    • T tekka
                      @Mickey Ok, I see, this is something related to the internal checksum, need to adjust that. In short: the bootloader doesn't hand over to the sketch
                      M Offline
                      M Offline
                      Mickey
                      Has this adjusted already?
                      • T tekka
                        @Lorenzo not finalized, need to revise the stk500 code
                        kalinaK Offline
                        kalinaK Offline
                        kalina
                        wrote on last edited by kalina
                        #131
                        Hi @tekka, can you help me?
                        I want to start exchanging between my MDMSGate device and MYSController via Ethernet. But I don't use Ethernet Shield W5100 in my MDMSGate, I use microcontroller PIC18F67J60 instead. I have uploaded to the PIC18F67J60 firmware which converts TCP/IP packets to serial and conversely.
                        In atmega328P I use the serial gateway sketch. So, I can't connect MYSController to my MDMSGate. Can you explain me, how MYSController exchanges with gateway generally? In an exchange through CP2102 (as a serial gateway mode) everything works well.
                        • kk02067K Offline
                          kk02067K Offline
                          kk02067
                          In the "firmware_config.csv" file, on the first line it says:
                          I know that it is there to explain how to add new lines to the file.
                          But I don't know what "Type" is used for.
                          The two examples have the numbers 10 and 20. I added a 30 and it seems to work but I would like to know what it's for.
                          • AndurilA Anduril
                            abmantisA Offline
                            abmantisA Offline
                            abmantis
                            @Anduril Haven't tried serial yet. The old bootloader seemed indeed a bit faster. I also noticed that if I touch pin 10 with my finger, it gets really fast! It just sends the packages continuously without stoping. As soon as I stop touching pin 10, it pauses.
                            The gw and the node were like 1 meter, so it is not a distance problem. Also tried moving them closer and apart.
                            L yd kimY 2 Replies Last reply
                              L Offline
                              L Offline
                              Lorenzo
                              This post is deleted!
                                yd kimY Offline
                                yd kimY Offline
                                yd kim
                                @abmantis Interesting. Can you let me know a little bit further detail?
                                You mean Arduino pro mini pin 10? That pin is connected to CSN on NRF24L01.
                                I'm keen to find the issue why it get slow.. It took 20-30minutes to upload new firmware....
                                • yd kimY yd kim
                                  abmantisA Offline
                                  abmantisA Offline
                                  abmantis
                                  wrote on last edited by abmantis
                                  #136
                                  @yd-kim Yes, just touch Arduino's pin 10. Dunno if it is a particularity with this Arduino or radio. It updates the node in about 20 seconds!
                                  • T tekka
                                    J Offline
                                    J Offline
                                    Jan Hicl
                                    wrote on last edited by Jan Hicl
                                    #137
                                    Hi @tekka, I'm having the very same issue as @Mickey so I just wanted to ask if there is any workaround to that or if happen to make the adjustment to the bootloader. Thanks a lot! Original comment
                                    T 1 Reply Last reply
                                    • J Jan Hicl
                                      T Offline
                                      T Offline
                                      tekka
                                      @Jan-Hicl This has been fixed - did you try the most recent version from github?
                                      J 1 Reply Last reply
                                      • T tekka
                                        J Offline
                                        J Offline
                                        Jan Hicl
                                        Hi @tekka and thanks for getting back to me! I tried the latest version however with no success. The node that I update is still marked as "Booting" even though I upload Blink.hex. Strangely enough, the led is blinking as it's supposed to blink and if I request presentation the node replies with correct sketch name but then it goes back to Booting. I'm using Arduino IDE 1.8.1, AVRdude v6.1 and MYScontroller v1.0.0 beta (build 3314). I'm using Arduino mini pro, 3V3, 8MHz. I have 5 different nodes but all of them with the same behavior so it does not seem as an HW issue.
                                        Here is my log from the upload of Blink.hex: http://pastebin.com/9grgHb27 Would you have any idea how could I fix that? Thanks!
                                        • J Jan Hicl
                                          T Offline
                                          T Offline
                                          tekka
                                          wrote on last edited by tekka
                                          #140
                                          @Jan-Hicl The blink sketch is somewhat special - it only blinks the built-in LED until the watchdog kicks in and resets the node. What happens if you upload one of your sketches? Please post the full debug log + source. Thanks
                                          12.2k
