  3. Battery reporting keeps increasing not decreasing
7 Posts 4 Posters 1.9k Views 4 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    I have a normal door sensor based on My Slim node design. It has been running for around 3 months till now but the battery percentage is abnormal.
    At the beginning I remember that the percentage begun as 72% so I thought maybe this is because my max voltage is defined as 3.3v not 3v. After some time, maybe 2 weeks it was 75%. It has been like this for like 2 months. Then I switched my gateway OFF for 3 weeks and switched it back ON now to see the battery voltage percentage and found it to be 80% :)
    The batteries are two AAA 1.5v each.
    Sketch:
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    #define MY_BAUD_RATE 9600 // For 1 MHz
    // Enable debug prints
    #ifdef MY_DEBUG
    #define DEBUG
    #ifdef DEBUG
    #define DEBUG_SERIAL(x) Serial.begin(x)
    #define DEBUG_PRINT(x) Serial.print(x)
    #else
    #if 0
    // Select soft/hardware signing method
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
    // Enable this if you want destination node to sign all messages sent to this node.
    // SETTINGS FOR MY_SIGNING_SOFT
    /// Set the soft_serial value to an arbitrary value for proper security (9 bytes)
    #define MY_SIGNING_SOFT_SERIAL 0x11,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09
    /// Key to use for HMAC calculation in soft signing (32 bytes)
    #define MY_SIGNING_SOFT_HMAC_KEY 0x10,0x20,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A7 //!< Unconnected analog pin for random seed
    #define CHILD_ID 0   // Id of the sensor child
    #define CHILD_ID_BATTERY 1
    //#define BATTERY_FULL 3000 // 3,000 millivolts for 2xAA (DOLA - changed to 5000 as it was tested on a laptop)
    //#define BATTERY_ZERO 1900 // 1,900 millivolts (1.9V, limit for nrf24l01 without step-up. 2.8V limit for Atmega328 without BOD disabled))
    #define VMIN 1900
    #define VMAX 3300
    long readVcc();
    // Initialize motion message
    unsigned int ADCValue;
    double Voltage;
    double Vcc;
    long oldvoltage = 0;
    void presentation()  {
      sendSketchInfo("Door Sensor", "1.0");
      present(CHILD_ID, S_MOTION);
      wait(25);       // Short delay to allow switch to properly settle
      // Read digital motion value
    //  Serial.println(tripped);
    //  send(msg.set(tripped?"OPEN":"CLOSED"));  // Send tripped value to gw (OPENHAB)
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw (Domoticz)
      Vcc = readVcc()/1000.0;
      ADCValue = analogRead(0);
      Voltage = (ADCValue / 1023.0) * Vcc;
    long voltage = readVcc();
    //Serial.println(voltage);
      if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
     //   sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
        oldvoltage = voltage;
    //  Serial.print(Vcc);
    //  Serial.print ( " " );
    //  Serial.println(Voltage);
      sleep(INTERRUPT,CHANGE);
    long readVcc() {
      // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
    #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
      ADMUX = _BV(MUX5) | _BV(MUX0);
    #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
      ADMUX = _BV(MUX3) | _BV(MUX2);
    #else
      while (bit_is_set(ADCSRA, ADSC)); // measuring
      long result = (high << 8) | low;
    Code has lots of unused variables and commented lines and the signing is not compiled in the project. a bit messy and needs to be cleaned up.
    Thanks.
    AWIA 1 Reply Last reply
    • TheoLT
      TheoLT
      TheoL
      I think I remembered some graph on this forum. A battery will report a higher percentage when it's starting lose it's power. So the readings seem to be normal.
      • ahmedadelhosniA ahmedadelhosni
        Sketch:
        #ifdef MY_DEBUG
        #define DEBUG
        #ifdef DEBUG
        #else
        #if 0
        #define VMIN 1900
        #define VMAX 3300
        long readVcc();
        double Voltage;
        double Vcc;
        long readVcc() {
        #else
        Thanks.
        AWIA
        AWIA
        AWI
        @ahmedadelhosni There is a (positive) voltage - temperature relation with Alkaline cells. So for Egypt it could be an explanation..
        0_1460662881157_upload-bb6377e6-f03d-48e6-a268-3054c2521051
        With lithium cells I also found that voltage tends to decrease during a "stress" period and returns slowly to a higher voltage.
        • ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          Impressive and annoying :)
          So is there any workaround to solve this ? looks like it is a normal behavior and reproducible.
            AWIA
            AWIA
            AWI
            @ahmedadelhosni There is nothing to solve ... My Electric car runs 40 km on a load in winter (-2 C) and 80km in summer (22 C). Your sensor could run a few years if well built and using low self discharge batteries.
            A graph of one of my sensors...you can see the temperature effect (although small).
            0_1460663386148_upload-fc93e660-b242-4186-9f75-9ec229380048
              Perpetuum mobile :)
                Perpetuum mobile :)
                AWIA
                AWIA
                AWI
                @hek with the climate temperature rising each year... yes :worried: :smile:
