  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 165.4k Views 65 Watching
  • johnym30J
    johnym30J
    johnym30
    Either pressing on or off in domoticz, i have always power on the second outpout.
    S 1 Reply Last reply
    • johnym30J johnym30
      stray
      @johnym30 Can you post your sketch?
      • johnym30J
        johnym30J
        johnym30
        wrote on last edited by johnym30
        #183
        This is my sketch
        // MySensor Debug
        // Enables repeater functionality (relays messages from other nodes)
        #define MY_REPEATER_FEATURE
        // Comment line below if you don't want to use the temperature sensor
        #define MY_TRANSPORT_WAIT_READY_MS
        #define MY_PARENT_NODE_ID 2
        #include <Bounce2.h>
        #define RELAY_PIN_1   3  // Arduino Digital I/O pin number for relay
        #define RELAY_PIN_2  5
        #define BUTTON_PIN_1  4  // Arduino Digital I/O pin number for button
        #define BUTTON_PIN_2 7
        #define CHILD_ID_1 8 // Id of the sensor child for 1st relay
        #define CHILD_ID_2 9 // Id of the sensor child for 2nd relay
        // Relay status
        #define RELAY_ON 1
        #define RELAY_OFF 0
        // Source of state change (used when printing debug information)
        #define CHANGE_STATE_SOURCE_RADIO 0
        #define CHANGE_STATE_SOURCE_SWITCH 1
        Bounce debouncer1 = Bounce();
        int oldValue;
        bool state1;
        Bounce debouncer2 = Bounce();
        int oldValue2;
        bool state2;
        MyMessage msg(CHILD_ID_1, V_LIGHT);
        MyMessage msg2(CHILD_ID_2, V_LIGHT);
        void presentation() {
          sendSketchInfo("Double Relay & Button", "0.2");
          present(CHILD_ID_1, S_LIGHT);
          present(CHILD_ID_2, S_LIGHT);
          // Setup the button
          pinMode(BUTTON_PIN_1, INPUT);
          // Activate internal pull-up
          digitalWrite(BUTTON_PIN_1, HIGH);
          // Setup the button
          pinMode(BUTTON_PIN_2, INPUT);
          digitalWrite(BUTTON_PIN_2, HIGH);
          debouncer1.attach(BUTTON_PIN_1);
          debouncer1.interval(5);
          debouncer2.attach(BUTTON_PIN_2);
          debouncer2.interval(5);
          // Set the initial values of oldValue/oldValue2 variables from status of physical switches
          //  if this is not done the loop() will detect status change and switch the relays on or off
          debouncer1.update();
          debouncer2.update();
          oldValue = debouncer1.read();
          oldValue2 = debouncer2.read();
          setRelayState(RELAY_PIN_1, RELAY_OFF);
          pinMode(RELAY_PIN_1, OUTPUT);
          digitalWrite(RELAY_PIN_2, RELAY_OFF);
          pinMode(RELAY_PIN_2, OUTPUT);
          state1 = loadState(CHILD_ID_1);
          setRelayState(RELAY_PIN_1, state1);
          state2 = loadState(CHILD_ID_2);
          setRelayState(RELAY_PIN_2, state2);
           Example on how to asynchronously check for new messages from gw
          // Get the update value
          int value1 = debouncer1.read();
          int value2 = debouncer2.read();
          if (value1 != oldValue) {
            send(msg.set(state1 ? false : true), true); // Send new state and request ack back
            // Write some debug info
            printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_1, value1);
          oldValue = value1;
          if (value2 != oldValue2) {
            send(msg2.set(state2 ? false : true), true); // Send new state and request ack back
            printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_2, value2);
          oldValue2 = value2;
          if (message.isAck()) {
        #ifdef MY_DEBUG
            Serial.println(F("This is an ack from gateway"));
          else if (message.type == V_LIGHT && message.sensor == CHILD_ID_1) {
            // Change relay state
            state1 = message.getBool();
            // Store state in eeprom
            saveState(CHILD_ID_1, state1);
            printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_1, state1);
          else if (message.type == V_LIGHT && message.sensor == CHILD_ID_2) {
            state2 = message.getBool();
            saveState(CHILD_ID_2, state2);
            printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_2, state2);
        // Set status of a relay pin
        void setRelayState(byte relayPin, bool value) {
          digitalWrite(relayPin, value ? RELAY_ON : RELAY_OFF);
        // Print debug info, centralized in one place to minimize memory usage and have only one #ifdef MY_DEBUG for all state change messages
        void printStateChangedDebug(int source, int sensorID, bool value) {
        #ifdef MY_DEBUG
          Serial.print(F("Sensor value changed, source="));
          Serial.print(source == CHANGE_STATE_SOURCE_RADIO ? F("Radio") : F("Physical switch"));
          Serial.print(F(", Sensor="));
          Serial.print(sensorID);
          Serial.print(F(", New status: "));
          Serial.println(value);
          This is my sketch
          // MySensor Debug
          // Relay status
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue;
          bool state1;
          int oldValue2;
          bool state2;
            // Setup the button
            // Setup the button
            oldValue = value1;
            oldValue2 = value2;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
          stray
          @johnym30 Can't see anything wrong with the sketch that causes the 2 outputs toggle at the same time. However, I have 2 remarks:
          1. Don't you need to set the pins to output before you set them low?
          2. You are not updating your gateway when you toggle the output with the switch.
          johnym30J 1 Reply Last reply
          • S stray
            johnym30J
            johnym30J
            johnym30
            @stray the think is that the first relay is working normal and i see the updates in domoticz when i turn it on or off.It is just the second relay that gives me power either it is on or off in domoticz.That is why i am thinking maybe the second relay is broken
            • E
              E
              Eawo
              hmm im having a hard time fitting these modules behind my lamp buttoms couse its swedish standar 70mm holes and the nrfmodule sticks out to much anyone know a good mod?
              dpressleD 1 Reply Last reply
              • E Eawo
                dpressleD
                dpressleD
                dpressle
                @Eawo Here you go
                • johnym30J
                  johnym30J
                  johnym30
                  Hi everyone.Its me again!!!!
                  Everything seems to be working just fine when i am using domoticz interface, but when i am using the hardware switches the icons in domoticz update from off to on but my lights wont turn on. If i turn my hardware switch to off, the state in domoticz stays to on.What am i doing wrong????
                  My sketch below .
                   * Script for double SSR relay board by Aproxx
                   * https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
                   * https://forum.mysensors.org/topic/3671/ac-dc-double-solid-state-relay-module
                   * Control 2 circuits either from controller or from physical buttons connected on pins 4 & 7
                   * Optional DS18b20 is connected on pin 8
                   *  HISTORY :
                   * xx/xx/2016 original version by Aproxx
                   * 08/02/2016 upgraded to MySensors 2.0 by mr_const
                   * 08/30/2016 changes by Nca78 :
                   *        - fixed initialization of physical buttons/debouncer status
                   *        - centralized pin status change for relays in setRelayState method
                   *        - centralized debug information for state changes in one method + added debug info when changed by physical switches
                   *        - added #ifdef MY_DEBUG before each Serial.print (saves prog memory when not in debug mode) and F() macros for debug strings (saves RAM when in debug mode)
                   *        - added #define USE_TEMP_SENSOR to make temperature sensor optional (not used if line is commented)
                   *        - put back #define for repeater feature
                   *        - add #define TEMPERATURE_ROUNDING for custom temperature rounding
                  // MySensor Debug
                  //#define MY_DEBUG
                  //#define MY_REPEATER_FEATURE
                  #define RELAY_PIN    3  // Arduino Digital I/O pin number for relay
                  #define BUTTON_PIN   4  // Arduino Digital I/O pin number for button
                  #define CHILD_ID 8 // Id of the sensor child for 1st relay
                  // Relay status
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  // Temperature sensor definitions
                  #ifdef USE_TEMP_SENSOR
                  #include <OneWire.h>
                  #define ONE_WIRE_BUS 8
                  #define CHILD_DSB_ID 13 // Id of the sensor child for temperature sensor
                  #define TEMPERATURE_ROUNDING 10.f   // Change value to change rounding of temperature value: 10.f for 0.1°C change, 5.f for 0.2°C change, 2.f for 0.5°C change
                  Bounce debouncer = Bounce();
                  int oldValue;
                  bool state;
                  int oldValue2;
                  bool state2;
                  MyMessage msg(CHILD_ID, V_LIGHT);
                  MyMessage msgTemp(CHILD_DSB_ID, V_TEMP);
                  OneWire oneWire(ONE_WIRE_BUS);
                    present(CHILD_ID, S_LIGHT);
                    present(CHILD_DSB_ID, S_TEMP);
                    sensors.begin();
                    // Setup the button
                    pinMode(BUTTON_PIN, INPUT);
                    digitalWrite(BUTTON_PIN, HIGH);
                    // Setup the button
                    debouncer.attach(BUTTON_PIN);
                    debouncer.interval(5);
                    debouncer.update();
                    oldValue = debouncer.read();
                    setRelayState(RELAY_PIN, RELAY_OFF);
                    pinMode(RELAY_PIN, OUTPUT);
                    state = loadState(CHILD_ID);
                    setRelayState(RELAY_PIN, state);
                    static float prevTemp = 0;
                    debouncer.update();
                    int value = debouncer.read();
                    if (value != oldValue) {
                      send(msg.set(state ? false : true), true); // Send new state and request ack back
                      printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID, value);
                    oldValue = value;
                    oldValue2 = value2;
                    float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(0) * TEMPERATURE_ROUNDING)) / TEMPERATURE_ROUNDING;
                    if (temperature != -127.00f && temperature != 85.00f && prevTemp != temperature) {
                  #ifdef MY_DEBUG
                      Serial.print("Sent temperature: ");
                      Serial.println(temperature);
                      prevTemp = temperature;
                  #ifdef MY_DEBUG
                    else if (message.type == V_LIGHT && message.sensor == CHILD_ID) {
                      state = message.getBool();
                      saveState(CHILD_ID, state);
                      printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID, state);
                  #ifdef MY_DEBUG
                  • johnym30J
                    johnym30J
                    johnym30
                    #189
                    Anyone has the hardware switches working??? I can't make them work!!!! Help please!!!!!
                      I doubt anyone can help you without debug logs from your node and gateway.
                      You can also look at the logs yourself using this tool to see where messages get stuck or lost.
                      • E
                        E
                        Eawo
                        How do I wire if I have ''2 buttons on the same lamp'' and also want to connect '' 1buttom to 1lamp'' to the same module how do I wire 2button 1 lamp?
                          johnym30J
                          johnym30J
                          johnym30
                          @hek the think is that the switch works using Domoticz, but when i use the pins for the hardware switch , i get the icons updated in domotics to on or off but my lights stay off
                          Boots33B 1 Reply Last reply
                            Boots33B
                            Boots33B
                            Boots33
                            wrote on last edited by Boots33
                            #193
                            @johnym30 It might be the way the code is written in your receive function.
                            When you toggle the hardware switch a message is sent to your controller with the new state, so Domoticz will get this and change the icons accordingly. The message you sent also asks for an ack back, it is this returning ack that is used to switch the relay.
                            The first If statement in your present code captures the ack and does a serial print but then does nothing else, so your ack is ignored by the rest of the code. So your relay will not be switched.
                            I see no reason why you need to test for an ack so try the following code and see if it helps
                             switch (message.sensor) {
                              case CHILD_ID:
                                state = message.getBool();          // Change relay state
                                saveState(CHILD_ID, state);        // Store state in eeprom
                                break;
                              case CHILD_ID_2:
                                saveState(CHILD_ID_2, state2);     // Store state in eeprom
                                break;
                            You might also like to move the the lines that set oldvalue to new value. They probably should be inside the relevant if statement. In the original relay with button actuator code they are outside but that is using push buttons not toggle switches.
                                oldValue = value;
                                oldValue2 = value2;
                            The other thing you should note is that as the code relies on an ack from your gateway to switch the relay your hardware switches will not work if the gateway is not available. You will need to further modify the code to ensure the switches work at all times.
                            • Boots33B Boots33
                                case CHILD_ID:
                                  break;
                                case CHILD_ID_2:
                                  break;
                                  oldValue = value;
                                  oldValue2 = value2;
                              johnym30J
                              johnym30J
                              johnym30
                              @Boots33 Thanks they are working now!!!!!!!
                              Unfortunately i dont know about coding, i am more of a hardware guy, so i will just have to live with that.Hoping that in the future someone will write something and share it with us.
                              Thank you once more.
                                Boots33B
                                Boots33B
                                Boots33
                                #195
                                @johnym30 There are only a few changes to be made to make the hardware switches more reliable. @hek showed in this post some code that could be used.
                                First you will need to add a line near the top of your sketch to allow the node to execute the loop part of the sketch even if no transport uplink is established. This code needs to be placed before #include <MySensors.h>
                                #define MY_TRANSPORT_WAIT_READY_MS 3000     //set how long to wait for transport ready.
                                The number at the end of the line is used to set how long to wait in milliseconds. I have found that my nodes will usually connect within 3 seconds.
                                Then you need to modify the code in the loop part of your sketch.
                                    state =  !state;                                                  // Toggle the state
                                    send(msg.set(state), false);                          // send new state to controller, no ack requested
                                    setRelayState(RELAY_PIN, state);                // switch the relay to the new state
                                    oldValue = value;
                                    state2 =  !state2;                                         // Toggle the state
                                    send(msg2.set(state2), false);                 // send new state to controller, no ack requested
                                    setRelayState(RELAY_PIN_2, state2);     // switch the relay to the new state
                                    oldValue2 = value2;
                                • folkestorpF
                                  folkestorpF
                                  folkestorp
                                  @Boots33 Will you please upload your complete code. It is difficult to see the finale solution then I read all the posts.
                                  • folkestorpF folkestorp
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    #197
                                    @folkestorp I have no node to try it on but the code will look like this. perhaps you can test it and let us know if it works. I have just placed it in the original code of a few posts up
                                     *  HISTORY :
                                    // MySensor Debug
                                    //#define MY_DEBUG
                                    // Relay status
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValue;
                                    bool state;
                                    int oldValue2;
                                    bool state2;
                                      sensors.begin();
                                      // Setup the button
                                      // Setup the button
                                      debouncer.update();
                                      debouncer.update();
                                        oldValue = value;
                                        oldValue2 = value2;
                                    #ifdef MY_DEBUG
                                      case CHILD_ID:
                                        break;
                                      case CHILD_ID_2:
                                        break;
                                    #ifdef MY_DEBUG
                                    • folkestorpF
                                      folkestorpF
                                      folkestorp
                                      @Boots33 I have test your code without temp sensor. It works perfect. Thank you!!!
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @folkestorp great. Thanks for reporting back.
                                        • X
                                          X
                                          XerOps
                                          I got a problem. I connected the board directly to ä powersource but the adapter doesnt output 5V . The part before just output 230 v just fine. Any one has any sugestions on whatsapp im missing?
                                          Nca78N 1 Reply Last reply
