  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 165.4k Views 65 Watching
  • laster13L
    laster13L
    laster13
    thanks, I'll try. You say that your lamps are powered by electrical socket .
    Is mounting possible on simple sockets with neutral wire? (non commandées)?
    • tonnerre33T
      tonnerre33T
      tonnerre33
      wrote on last edited by tonnerre33
      #142
      Sure you can use an electrical socket without switch control.
      But caution, max current is 2A ! It is ok for lamps but you can't supply a receiver which consumes more than 460VA per relay ( = 460W for resistive receiver).
      I didn't see protection for relays, be careful ;)
      • laster13L
        laster13L
        laster13
        I am trying to test a montage which I am not sure about and besides when I plug the pcb on the socket the lamp remains on. I invite you to read my post on the Domoticz forum.
        http://easydomoticz.com/forum/viewtopic.php?f=20&t=2680&p=25219#p25219
        I am sorry for my english, I use the traducer of google
        tonnerre33T 1 Reply Last reply
        • Richard_SkeR
          Richard_SkeR
          Richard_Ske
          Hi All,
          This is my first post on this site!!
          Yes this is a really good project but for the UK controlling a light inside of a wall switch you would need to do the following.
          Re-wire the ceiling rose as in the UK there is a live feed from the rose that is switched by the switch and then returns to the rose to the "switched live" See http://www.diydoctor.org.uk/project_images/lights_and_switches/ceilingroseb2.jpg
          Put an extra cable up to the ceiling rose with the return cable from the board that goes to the switched live and add an extra terminal in the ceiling rose to link the neutral to the other side of the lamp fitting.
          If the back box is metal, it would need to be changed to a plastic box , I wouldn't myself want to mount the board in an earthed metal box!!
          As other contributors have noted there isn't any fusing on the live and neutral feeds if the SSR were to fail short because of a short circuit in the lamp or ceiling rose then there could be a large current going through board that could potentially cause a fire, safety is always the first thought with any mains electrical circuit.
          I could see this board being used in a plastic box inline to a table lamp etc. but it would need a lot of work to re-wire your house if you intended to use it behind a wall switch.
          • laster13L laster13
            tonnerre33T
            tonnerre33T
            tonnerre33
            @laster13 Yes your schema is correct.
            The sketch has been modified by Nca78, you can try it first.
            The problem does not come from the unused switch, because i use this node without switch.
            • E
              E
              Eawo
              I'm going to do these for my light switches but what should I use for in wall on off switch without relay?
              • HilltanH
                HilltanH
                Hilltan
                The link to to DirtyPCBs is broken, got a new one?
                • HilltanH Hilltan
                  tonnerre33T
                  tonnerre33T
                  tonnerre33
                  @Hilltan Hello, i think this link will be ok : http://dirtypcbs.com/store/details/885/mysensors-v3-3-2-light-switch
                  For information, a few members have too many PCB of this node that's why if you are living in Vietnam or asia, Nca78 can send you PCB and if you are in france, i can send too (contact by pm for terms).
                  I use this node since 20 days ago, and it's working well ;)
                  • johnym30J
                    johnym30J
                    johnym30
                    Hi everyone.
                    I can not find anywhere Slow Blow Fuse (250v 0.2A). Does anyone has an available link??
                    Thanks in advance.
                    • johnym30J
                      johnym30J
                      johnym30
                      Never mind, got them. thank you!!!
                      • laster13L
                        laster13L
                        laster13
                        @tonnerre33
                        I will be really interested to buy you all the components you would no longer need. NRF, pcb, fuse thermal ... If you agree, can you tell me a list of what you offer thanks
                        • C
                          C
                          chickey
                          If anyone in the UK is after boards/parts i have spares.
                          • Rodolfo VieiraR
                            Rodolfo VieiraR
                            Rodolfo Vieira
                            hello, anyone use this project with home assistant?
                            • proddyP
                              proddyP
                              proddy
                              Thanks for this. One question about the SSR. Does it matter if its a zero crossing relay or not if just switching lamps with fixed amps? That the difference between the G3MB-202P and G3MB-202PL. I'm not sure which to get.
                              Nca78N 1 Reply Last reply
                              • proddyP proddy
                                Nca78N
                                Nca78N
                                @Paul-Derbyshire if you're buying on aliexpress at less than 3$ a relay, you're buying chinese clones like most of us here. I doubt they bothered implementing the zero-crossing function on the chinese clones...
                                • HaMH
                                  HaMH
                                  HaM
                                  I love this project. This is almost exactly what I wanted to do by myself (but I have no knowledge in PCB design). As this project shouldn't require much power, have you ever though about using a dropping capacitor PSU (http://www.circuitsgallery.com/2012/07/transformer-less-ac-to-dc-capacitor-power-supply-circuit2.html) instead of the HLK-PM01 ?
                                  If this is a working solution, it would make your project even cheaper.
                                  An other question on the DS18B20. Wont the proximity with the relays (heat generators) will disturb the temperature reading ?
                                  • HaMH HaM
                                    Nca78N
                                    Nca78N
                                    wrote on last edited by Nca78
                                    #157
                                    Hello !
                                    Transformerless design means there is not isolation between main voltage and low voltage parts. You can get electrocuted with 110/220V when touching the low voltage side. It means it can be used only in the case of a sealed box.
                                    For the temperature sensor the main source of heat is the hlk that heats up a lot. It's purpose is not to sense the temperature in the room, but to monitor the temperature inside the sensor and make sure there is not problem with the hlk overheating.
                                    HaMH 1 Reply Last reply
                                    • Nca78N Nca78
                                      Hello !
                                      HaMH
                                      HaMH
                                      HaM
                                      @Nca78 Thanks for the advice.
                                        A Former User
                                        Would it be possible tot change the relays to one (or two) triacs, keeping it's current features and also allowing it to dim lights?
                                        • rhapenR
                                          rhapenR
                                          rhapen
                                          anyone found the Slow Blow Fuse (250v 0.2A) on aliexpress? if yes please link.
