  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 165.4k Views 65 Watching
  • S
    Samuel235
    @aproxx, Could i ask what trace width and what clearance you used for the AC portion of this device? Also, what current did you base these settings on, what current do you expect to be flowing through the AC traces?
    MySensors 2.1.1
    • S
      shabba
      Just a thought : Why not use RAW instead of VCC so a 3.3V mini can be used as thus no logic conversion needed for RFM69? The SSR works find below 3v as it happens. Also means no need for the voltage changer. Could also look at getting the 3.3V HLMs also I guess.
      • okosO
        okosO
        okos
        How many pieces got ordering paying $ 14 http://dirtypcbs.com/index.php ?
        mr_constM 1 Reply Last reply
        • mr_constM
          mr_constM
          mr_const
          Hi @approx, there is 4k7 resistor placeholder under arduino, near 100nf capacitor, but you didn't mention it in a project description - is this resistor optional?
          S 1 Reply Last reply
          • mr_constM mr_const
            Samuel235
            @Konstantin-Kolesnichenko, I would highly recommend the pullup resistor.
            Please see https://wp.josh.com/2014/06/23/no-external-pull-up-needed-for-ds18b20-temp-sensor/ for more information regarding this resistor.
            MySensors 2.1.1
            • okosO okos
              mr_constM
              mr_constM
              mr_const
              @okos I got 11 pieces for one order.
              @Samuel235 thank you, soldered one :)
              • the cosmic gateT
                the cosmic gateT
                the cosmic gate
                anybody who's got a complete kit for sale ? Want to test build one (single relay is enough)
                (or maybe nicer: a 3in1 solution : Motion detection , relais , DHT of other temp sensor)
                There's more than meets the eye
                • mr_constM
                  mr_constM
                  mr_const
                  Is somewhere there present source for this module with temperature module support?
                  • badmannenB
                    badmannenB
                    badmannen
                    this looks like a great project. Have anyone made a complete shopping / whish-list on Alibaba for all the components needed? ( I´m lookin for safest version possible =)
                    Many thanks,
                    Henrik
                    rPi 3 - UNO R3 - Mini - Nano - custom
                    Nca78N 2 Replies Last reply
                    • badmannenB badmannen
                      Many thanks,
                      Henrik
                      Nca78N
                      Nca78N
                      @badmannen I have ordered nearly everything on aliexpress but I had to buy from many different sellers to have everything, I don't know if they are all reliable, I will know in 3-4 weeks and then post the links for the items I received.
                      I took some 250mA fuses as no one was selling 200mA slow fuses on aliexpress, and also some 77°C temp fuses instead of the 73° because they were less than half the price. I'll grill one or two to make sure they are real temp fuses when I receive them ;)
                      Not sure if I order the PCBs from DirtyPCB now or if I wait to received my previous (and first order there) to be sure they will reach my mailbox...
                        Many thanks,
                        Henrik
                        Nca78N
                        Nca78N
                        wrote on last edited by Nca78
                        #31
                        @badmannen I have just received my temp fuses, 1 of the 10 is dead, I tested one that was ok to make sure it was a temp fuse. I used the thermometer function on my multimeter and heated at the same time with my soldering iron at lowest temperature possible (200°C).
                        Heated until thermometer reached 50°C, fuse was still ok.
                        Heated again a bit longer and I heard some noise when thermometer went over 60°C. I stopped and checked: the fuse was blown. Given that multimeter thermometer is not extremely precise and has some lag to increase the temperature, I think the claim of 77°C cut off is probably right or at least not far from reality. And at least I'm sure these are temp fuses. I'm not testing another one as I have only 8 left now and I'm nearly sure I'll burn a few when soldering :D
                        [edit] 77° fuses not sold anymore :(
                        http://www.aliexpress.com/item/10pcs-lot-RY77-TF-77-Degree-Celsius-77C-10A-250V-Temperature-Thermal-Fuse/32577243105.html
                        I will order that next, from same seller, look like the same fuses, just 72°C which should be fine in our case.
                        http://www.aliexpress.com/store/product/20pcs-lot-RY72-TF-72-Degree-Celsius-72C-10A-250V-Temperature-Thermal-Fuse/1021664_32660871006.html
                        badmannenB 1 Reply Last reply
                        • Sacha TelgenhofS
                          Sacha TelgenhofS
                          Sacha Telgenhof
                          Hi @aproxx , very nice module! Just one question: after studying the board I still not quite understand how an existing light switch needs to be connected. There are 3 connecters, one for AC and two relays. Where do I connect the light switch to?
                          Cheers! Sacha
                          rhapenR 1 Reply Last reply
                          • Nca78N Nca78
                            badmannenB
                            badmannenB
                            badmannen
                            wrote on last edited by badmannen
                            #33
                            @Nca78 Thanks alot for the detailed info! really appreciate it. keep it coming pros and cons if any if you notice something
                            //Henrik
                            Nca78N 1 Reply Last reply
                            • SoloamS Soloam
                              Hello all, I finished my version of this idea! Thank you to @aproxx for the help! I used a ATMEGA328, this wil make it a bit cheaper. https://www.openhardware.io/view/83
                              I need some help validating the layout, most important the 220v traces and the capacitors used in the layout!
                              Thank you all
                              dpressleD
                              dpressleD
                              dpressle
                              Thank you all
                              Is there any news on this design?
                                //Henrik
                                Nca78N
                                Nca78N
                                //Henrik
                                You're welcome. I ordered 72°C fuses as in my previous link. Seller agreed to add one to replace the broken 77°C I received last week.
                                I received the varistors, ssd relays and regulators, all correctly packaged in padded envelopes. Not tested yet, I will update this post later if I see a problem, but I'm not sure how I can efficiently test the varistors...
                                http://www.aliexpress.com/item/Varistor-10D391K-10D-391K-VDR-10K391-Metal-voltage-dependent-resistor-50pcs-bag/1912418587.html
                                http://www.aliexpress.com/item/10pcs-bag-New-original-solid-state-relay-G3MB-202P-DC-AC-PCB-SSR-In-5VDC-Out/32260339179.html
                                http://www.aliexpress.com/item/Free-shipping-10pcs-lot-LE33CZ-LE33ACZ-TO-92-new-original/32591811172.html
                                dpressleD 1 Reply Last reply
                                • Nca78N Nca78
                                  //Henrik
                                  dpressleD
                                  dpressleD
                                  dpressle
                                  @Nca78 How is the LE33 working for you? i couldn't make it drive the NRF...
                                  Nca78N mr_constM 2 Replies Last reply
                                  • dpressleD dpressle
                                    Nca78N
                                    Nca78N
                                    #37
                                    As I said I didn't have time to test the last batch of components yet.
                                    It's suprising as the LE33 is supposed to allow up to 100mA current, that should be enough for the NRF. Not sure I will use them any as I have some 3.3V nanos and also some 3.3V HLKs so I could bypass it.
                                    I will test anyway and keep you updated.
                                    [edit] All components (slow blow fuses, capacitors,...) received, I'm just waiting for the PCBs now. And for some time to test :)
                                    • tonnerre33T
                                      tonnerre33T
                                      tonnerre33
                                      can we install this module in a wall ?
                                      Can we command shutters ?
                                      Thx
                                      • mr_constM
                                        mr_constM
                                        mr_const
                                        I updated source file for this module, so it supports MySensors 2.0 now and sends temperature data too. You can pick it at my github page. Total size for 'Arduino Pro or Pro Mini w/ ATmega328 (5V, 16 MHz)'
                                        Program size: 13 396 bytes (used 44% of a 30 720 byte maximum) (2,78 secs)
                                        Minimum Memory Usage: 614 bytes (30% of a 2048 byte maximum)
                                          Matt
                                          Hi Approx
                                          Thanks for the effort here. I have all the bits except for the PCBs which were shipped a week ago so not far off.
