💬 AC-DC double solid state relay module
Sorry the shop I bought mine from doesn't sell a single fuse anymore ...
I don't know if these fuses will fit on the board but they are the closest specced having some leads :
https://www.aliexpress.com/item/10-pcs-lot-T250mA-250V-TE5-Slow-Blow-Subminiature-Fuse-UL-VDE-RoHS-Approved-250mA/32712347448.htmlI think it would be better for next revision of this board or future boards powered from main to use a fuse holder...
Thank you to all for your rapid answer.
@Amster
I saw the fuse in Mouser website, I think the same one is the following:I also called they and they told me that only after I will put the order they check the real availability in the various site they have and if present they send me, but if not present I have to wait 10 Week as this is the Factory Lead Time.
And more of this the shipping will cost 20€, so a total of 39,80€ for 10 little fuse I think is too much.I think I will go for the one you suggest. It's cheap, with free shipping and it seems not to big to don't fit in the board.
Now I will have to wait about 1 month before all parts arrive, then I will let you know if fuse will fit or not.
Thank you again for your attention and a big hello from Italy.
I bought here in Ukraine circular-shaped slow-blow fuses and soldered them almost normally (here is their datasheet http://www.rcscomponents.kiev.ua/datasheets/5rt.JPG), so far everything is ok.
And here is my board instance:
Very nice project. I would like to have access to few more pins to add some functionality like motion sensor, and light sensor. Of course those would be outside of the wall :)
Hello, I would not advise to use this board with sensors accessible to fingers. The spacing between main voltage and low voltage traces is too narrow at some points on the board and a short circuit is possible. It is fine/safe to use only in a closed box or connected to wall switches as they are designed to be safe with main voltage.
I think that woundn't be so risky becouse o think about mounting it not behind light buttons, but in this box just below ceiling(where wires crossing their paths), this box is placed more than 2 meters above floor level.
Still a bit, no ?
Anyway if you have requirement for a board that would be both easy to solder and safe even outside of electrical box, can you send them to me by private message ? I'm working on such a board and I'm opened to any improvement ideas of use cases that would not be filled by currently available boards. -
I've just thought about little node that could be mounted in almost every room, and be barely visible. This box below ceiling is quite good place for this. I have plan to do something like dome(3d printed) instead of flat box cover to fit electronics there. As i told in previous messages i would like to have node that could turn on/off light, read temperature, movement, and light level by LDR.
Hello.
I would like to ask whether it is normal that the switch does not work if the server domoticz off? I want to use the switch only crash server :flushed: now i cant@okos said:
Hello.
I would like to ask whether it is normal that the switch does not work if the server domoticz off? I want to use the switch only when I have a server crash and now does not work.:flushed:That's a problem of MySensors, if you don't have physical switches connected directly on your node you are depending on a functionnal gateway/controller to run... That's why I'm going more toward the "upgraded" livolo-style wall switch now, even if the radio is down you can still maintain basic functionality of the switch. This board can do it but you need to have neutral wire in the switch box which I don't have :(
Hello.
I would like to ask whether it is normal that the switch does not work if the server domoticz off? I want to use the switch only crash server :flushed: now i cant -
@okos Unfortunately current mysensors version won't allow to 'boot' your code before their module connects to a controller. This is a main reason I moved to ESP8266 hardware.
Thanx for the answers
This is not good news from the switch does not work without a server. Mr.const, Do you use esp8266 in domoticz to control the light?edit: hek, I not noticed your post.
What changes adding this?#define MY_TRANSPORT_DONT_CARE_MODE #define MY_PARENT_NODE_ID 0``` -
You can disable this behaviour by defining:
#define MY_TRANSPORT_DONT_CARE_MODE #define MY_PARENT_NODE_ID 0 -
