  3. Real Time Clock with Display Example
displayrtc
12 Posts 7 Posters 7.4k Views 2 Watching
    Put together a new example inspired by @gregl for the RTC module.
    Also added a display to show date, time and temperature.
    http://www.mysensors.org/build/display
    https://codebender.cc/sketch:48371
    cadetC 1 Reply Last reply
    • greglG
      greglG
      gregl
      Nice Hek.
      Can you explain the values here?
      (0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE)
      I know the 0x27 is the i2c address - but the others are foreign to me, and i cant find the doco/wiki for that lib...or at least that version of the lib!
      • korttomaK
        korttomaK
        korttoma
        I was thinking the same thing as @GREGL
        I'm using the following to initialize my LCD:
        LiquidCrystal_I2C lcd(0x27,20,4);
        lcd.init();
        Don't think I'm using the same Lib either.
        • Tomas
        • greglG
          greglG
          gregl
          wrote on last edited by gregl
          I was just poking around on codebender and found the lib..but none of the examples use all these params.
          IIRC ,I use a different lib...as my i2c lcd controllers are pretty old..byvac from memory.
            Found the new liquidcrystal library while searching my display Funduino/1602.
            The parameters are:
            addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
            https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
            Example:
            http://jaredstemen.blogspot.se/2014/01/getting-funduino-1602-lcd-to-print.html
            • korttomaK
              korttomaK
              korttoma
              Tried the lib out in my setup and it seems to be working just fine so I think I will use that one to so that I can be on the same page as @hek
              • Tomas
              hekH 1 Reply Last reply
              • korttomaK korttoma
                @korttoma
                I has been checked in to master.
                https://github.com/mysensors/Arduino/tree/master/libraries/LiquidCrystal
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  wrote on last edited by bjornhallberg
                  These OLED displays seem pretty cool also if the quality is ok and the library doesn't eat up too much space:
                  https://www.youtube.com/watch?v=mMiMNTv25Bw
                  A lot more information being displayed in a much smaller package. Price is similar to the 16x2 LCD and they run on 3.3-5V apparently. Available as I2C also.
                  • greglG
                    greglG
                    gregl
                    Hey maybe i can use this with the microview http://forum.mysensors.org/topic/48/idea-s-microview/
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      I have a couple of these (I2C) and they are great.
                      I have tried to use them together with a temp sensor but I failed doing so.
                      I was able to compile and upload the sketch but due to a lack of patience I did not investigate why it failed.
                      My gut feeling is that the problem was the use of too many string values...
                      Fulltime Servoy Developer
                      • R
                        R
                        Rek
                        I have a couple of these OLED displays on order, will see if I can get them working with the sensors.
                          cadetC
                          cadetC
                          cadet
                          wrote on last edited by cadet
                          @hek said in Real Time Clock with Display Example:
                          Hi
                          Can you modify code for adding temp sensor to GW.
                          And may be display day of week.
                          Thank you.
