  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 70.5k Views 37 Watching
  • YveauxY
    YveauxY
    FYI, I measured power comsumption on the Mogan when sleeping with and without regulator.
    The power consumption was significantly less with the voltage regulator, then when directly powered from 3xAAA (regulator removed).
    Therefore, my Molgan hack board design targets to use the PIR with regulator (3xAAA input) and the ATmega+nRF powered directly from 2xAAA.
    • T tomkxy
      @Yveaux Unfortunately, I still get false triggers. Do you also use a sensebender? Any ideas, what I can try. I tapped into as you suggested to the second battery.
      dynamiteD
      dynamiteD
      dynamite
      wrote on last edited by dynamite
      #62
      @tomkxy I Will put mine for a test run online tonight in the closet. If no trigger than it should be ok.
      Edit: did something wrong when removing led from pro mini so some debugging is required.... No testing tonight :cry:
      • T
        tomkxy
        I googled a bit regarding PIR false alarms and found a couple of links. Apart from small bugs - which I have not in the room - air vents could trigger false alarms. Thus, I put back the plastic dome and now have sind 4 hours no false alarms. I am now convinced that my false alarms a most probably triggered by placement and may be air vents.
        http://de.actmeters.com/advice/five-causes-of-pir-false-alarms/
        https://www.youtube.com/watch?v=h0bp91xy5vY
        http://www.hkvstar.com/technology-news/how-to-install-pir-sensor-minimize-the-false-alarm.html
        YveauxY 1 Reply Last reply
        • T tomkxy
          YveauxY
          YveauxY
          @tomkxy of course you should always mount the fresnel cover. It focuses the incoming IR on the sensor and forms a barrier. Without the cover the sensor will always be more sensitive and have a much smaller field of view, increasing sensitivity even more.
          If an unmodified Molgan doesn't suffer from false triggers, a modified one also shouldn't.
          This is one more confirmation of the importance of describing your setup accurately :smirk:
          • T
            tomkxy
            I made a couple of additional modifications based on posts here and google results:
            • put a short wait before the node goes to sleep -> based on reports from that forum
            • read the motion pin twice with a small wait in between
            • put a small alu foil between the radio and the PCB -> there are some reports in the internet that RF interference could cause false triggers
            I had a close look at the sensor today and everything looked okay so far. However, I was moving into the room in and out. Let's see what the result tomorrow will be.
            • T TimO
              @tomkxy Nice write up! Do you have an idea on the accuracy of the humidity sensor within the case?
              tomkxy
              I did some comparison measure regarding temp and humidity. I place an open Sensebender just beside the modded Molgan. The humidity measured at the Molgan was about 11% lower than the humidity measured by the open Sensebender. With respect to temp the Molgans temp was about 6% lower than the temp measured by the open Sensebender.
              T 1 Reply Last reply
              • T tomkxy
                TimO
                @tomkxy Thank you for reporting back!
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  Ok, so if I as a complete beginner want to use a the original pir and control the lights all I need to do is:
                  Tap the power from the regulator U1 and power a 3.3v mini-pro (keeping the 3 batteries)
                  Remove Resistor R17 and connect the solderpoint nearest the chip to an arduino input and I can then basicly be able to run the standard motion sketch ? (After removing the photodiode and bridging the connectors?)
                  I can connect the the other solderpoint to an arduino output and if uploading a sketch witch puts that output HIGH the leds will turn on?
                  If I am fine with 30secs of triggertime I do not have to do anything more?
                  Are all my assumptions correct?
                  dynamiteD rollercontainerR 2 Replies Last reply
                    dynamiteD
                    dynamiteD
                    dynamite
                    @Cliff-Karlsson correct!:smile:
                      rollercontainerR
                      rollercontainerR
                      rollercontainer
                      @Cliff-Karlsson
                      Excellent summarized! Perfect HowTo!
                      Voted Cliff-Karlson for Documentation Team :-D
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Haha, right. Last question, if I also want the sensor to report battery-usage. Is there any way to accomplish that without soldering any more resistors?
                          YveauxY
                          YveauxY
                          @Cliff-Karlsson Yes, there is!
                          Use my Vcc library!
                          dynamiteD 1 Reply Last reply
                          • YveauxY Yveaux
                            Use my Vcc library!
                            dynamiteD
                            dynamiteD
                            dynamite
                            @Yveaux @Cliff-Karlsson but in the scheme of cliff he is taken the power after the power regulator. So you are not
                            Measuring the battery with your VCC library.
                            • dynamiteD dynamite
                              YveauxY
                              YveauxY
                              @dynamite You're right then. I didn't read his howto, just answered how to read battery voltage without voltage divider ;-)
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                Ok, but if I measured right when talking the power from the regulator you could get 3v or ~4.5v witch i guess is directly from the batteries. If I connect the 4.5v to the power input on the same side as the tx/rx can I still not use the vcc library?
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  How would a sketch for this PIR look like? I tried combining the PIR and RelayActuator but my skills are not enough.
                                  This is what I have came up with:
                                   * Version 1.0 - Henrik Ekblad
                                   * Motion Sensor example using HC-SR501
                                   * http://www.mysensors.org/build/motion
                                  // Enable debug prints
                                  //#define MY_RADIO_NRF24
                                  #define MY_RADIO_RFM69
                                  #define RELAY_1  9  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                  #define SECONDARY_CHILD_ID 4
                                  void before() {
                                      pinMode(pin, OUTPUT);
                                  // Initialize motion message
                                  void presentation()  {
                                    sendSketchInfo("Light/Motion Sensor ikea", "1.0");
                                    present(CHILD_ID, S_MOTION);
                                      present(sensor, S_LIGHT);
                                    // Read digital motion value
                                    Serial.println(tripped);
                                    send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                    if (message.type==V_LIGHT) {
                                       // Change relay state
                                       // Store state in eeprom
                                       // Write some debug info
                                       Serial.print(message.sensor);
                                  But it does not complie after the last part is added. And I would also like to get the vcc -stuff into the same sketch. Could someone post a working sketch for this?
                                    dynamiteD
                                    dynamiteD
                                    dynamite
                                    @Cliff-Karlsson you can only use the VCC sketch if you by pass the voltage regulators. So power the arduino from two batteries by a separate wire.
                                      void before() {
                                      dynamiteD
                                      dynamiteD
                                      dynamite
                                      @Cliff-Karlsson the receive routine is out of the repeat loop
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        Ok, tried placing it in the loop to but with the same result. In the RelayActuator it looks like it really is placed outside the loop: RelayActuator
                                        What would the prefered way be to connect the power to the a 3.3v arduino for the best battery time?
                                        4.5v from the PIR regulator --> Arduino RAW (using 3 batteries)
                                        3v from the PIR regulator --> Arduino VCC (3batteries)
                                        And how would I power it from only 2 batteries? would not the PIR or leds need higher voltage than 3v ?
                                          YveauxY
                                          YveauxY
                                          @Cliff-Karlsson see here: https://forum.mysensors.org/topic/3756/multisensor-pir-based-on-ikea-molgan/58
