  3. Upgrade Ethernet GW -> 1.4 (wiznet)
w5100unowiznet
18 Posts 4 Posters 7.7k Views 2 Watching
  • M Offline
    M Offline
    mitekg
    After 1.4 release, i tryed ti upgrade my EthGW (Wiznet W5100) to 1.4 but got some problems
    latest version from git is not works for me (no blinks and eth communication with vera)
    but old dev version http://pastebin.com/6YFrs6HT works partly:
    blinks and inclusion starts and stops from vera interface (with old version), but no lib version and new devices shows in vera after that.
    p.s.: nrf communications works fine.
    Help plz.
    Thank you
    H 1 Reply Last reply
    • M mitekg
      Help plz.
      Thank you
      H Offline
      H Offline
      @mitekg
      I have a hard time verifying the ethernet code on 1.4 with W5100 right now. I've ordered both ethernet shield and module on Aug 18 but nothing has arrived. :(
      Recently did some re-work on the gateway-code in development-branch that I would like to verify with Vera. @Damne tested it successfully though (even though has no vera).
      https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/EthernetGateway
      • M Offline
        M Offline
        mitekg
        @hek
        ive tried dev version. compilation error..
        • HoffanH Offline
          HoffanH Offline
          Hoffan
          Same for me.. Compilation Error :(
          • H Offline
            H Offline
            Did you replace the whole MySensors-library folder?
            M 1 Reply Last reply
            • H hek
              M Offline
              M Offline
              mitekg
              @hek Yes, MySensors-library was replaced
              • HoffanH Offline
                HoffanH Offline
                Hoffan
                I did not :)
                • HoffanH Hoffan
                  I did not :)
                  M Offline
                  M Offline
                  mitekg
                  @Hoffan compilation success?
                  Evrthing works?
                  IDE version
                  thx?
                  • HoffanH Offline
                    HoffanH Offline
                    Hoffan
                    The Develepment Version looks like working Good for me
                    • M Offline
                      M Offline
                      mitekg
                      thx! ill try today.
                      And what about IDE 1.0.5. or 1.5.7?
                      HoffanH 1 Reply Last reply
                      • M mitekg
                        thx! ill try today.
                        HoffanH Offline
                        HoffanH Offline
                        Hoffan
                        @mitekg
                        1.5.7
                        • M Offline
                          M Offline
                          mitekg
                          1.5.7 + latest dev version
                          lib,,...\EthernetGateway.ino
                          Compilation, . error:
                          Arduino: 1.5.7 (Windows 7), Board: "Arduino Nano, ATmega328"
                          In file included from EthernetGateway.ino:57:0:
                          GatewayUtil.h: In function 'void parseAndSend(MySensor, char*)':
                          GatewayUtil.h:187:31: error: 'mSetRequestAck' was not declared in this scope
                          mSetRequestAck(msg,ack?1:0);
                          In file included from EthernetGateway.ino:53:0:
                          C:\Users\Dima\Documents\Arduino\libraries\MySensors/MySensor.h:248:10: error: 'boolean MySensor::sendRoute(MyMessage&)' is protected
                          boolean sendRoute(MyMessage &message);
                          GatewayUtil.h:193:26: error: within this context
                          ok = gw.sendRoute(msg);
                          enabled in File > Preferences.
                          • M mitekg
                            H Offline
                            H Offline
                            @mitekg
                            You don't seem to have updated everything (in the library folder) or forgot to restart Arduino IDE afterwards.
                            • M Offline
                              M Offline
                              mitekg
                              @hek
                              test it twice!
                              clean installation (unpack in new dir) of 1.5.6. + latest dev version from git.
                              • H hek
                                @mitekg
                                M Offline
                                M Offline
                                mitekg
                                This post is deleted!
                                • M Offline
                                  M Offline
                                  mitekg
                                  @hek
                                  sorry!!
                                  Im stupid man! compiled :+1:
                                  Continue testing!
                                  • M Offline
                                    M Offline
                                    mitekg
                                    @hek , @Hoffan everything is work properly on master version!
                                    thank to ALL!
                                    • J Offline
                                      J Offline
                                      jmmorgan
                                      I have a similar problem. I upgraded from 1.3 to 1.4 and my Wiznet gateway does not work. I can ping version 1.3 from my PC and it see the gateway. When I ping 1.4 from my PC it says that the destination address can not be found. I have downloaded the latest Ethernet gateway sketch, but it did not help. Has any other file change that could effect this.
                                      John
                                      12.1k
