  3. new serial gateway
new serial gateway
5 Posts 4 Posters 1.8k Views 3 Watching
  • parachutesjP
    parachutesjP
    parachutesj
    I had to replace my arduino on the serial gateway and it seems, none of the nodes will connect now.
    Do I need to reset them somehow?
    Thanks and regards,
    SJ
    • sundberg84S
      Most likely no, depends. - what does your log say, and what controller do you use?
        What does the debug log say. Did you previously change frequency in MyConfg.h?
        parachutesjP 1 Reply Last reply
          parachutesjP
          parachutesjP
          parachutesj
          @hek @sundberg84
          I did not see anything in the log. I had to restart the nodes and then they found the "new" gateway
          • A
            A
            Adam McCartney
            i had this issue the other day too when i restarted my gateway and controller (Ethernet Gateway powered by RPi Domoticz Controller).
            I had to go and find and restart each of my nodes. it was rather annoying.
            Is there a way to broadcast somekind of remote restart command? even if the Nodes dont broadcast to the gateway, maybe the Nodes can listen for a restart command?
