  3. Codebender on ipad hiding code
8 Posts 3 Posters 2.1k Views 3 Watching
    When helping people troubleshooting, I find it immensely valuable to look at the MySensors "build" examples. However, viewing the examples on the build pages, presents a large message in Safari on ipad:
    The message makes it impossible to view the last 9 rows of the code.
    I have tried the Download link ut that doesn't work very well either:
    The only sensible way I have found is to open both the build page (so I can refer to it if I answer) and find the sketch on github so I can read the code.
    Does anyone know a better way?
    H 1 Reply Last reply
      Yeah, the message is a bit intrusive .. I suggest you create an issue on codebender.
        H
        H
        HarryDutch
        @mfalkvidd
        Use Chrome on your iPad and your problem is solved!
        • H HarryDutch
          @mfalkvidd
          @HarryDutch great idea, thanks! I actually deleted Chrome yesterday, because I wasn't able to find a way to prevent the Youtube app from opening links in Chrome. Will have to decide which of the problems I want to live with...
          @hek I'll do that!
            @hek I'll do that!
            H
            H
            HarryDutch
            @mfalkvidd
            In Youtube you have an option to enable/disable Youtube links to open in Chrome.
            • H HarryDutch
              @mfalkvidd
              @HarryDutch where? I tried to find instructions online and found something that said that it was possible in Settings->Youtube but that setting is not available (not even before I uninstalled Chrome).
                H
                H
                HarryDutch
                @mfalkvidd
                When you open YouTube itself then look at the uppper right corner where you should see 3 dots. Tapping these dots will give you the all available options.
                  Found it! Thanks a million!
