  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • K
    K
    Komaandy
    Yes i did swap the radios, but what seems to be the problem is the arduino itself.
    When swapping the arduinos ( both arduino pro mini 3,3 volt) both flashed with the same sketch one works and the other just doesnt.
    I just swapped the arduinos on the breadboard and left everything else in place...
    Thats really strange, given the fact that BOTH transmit good readings when connected to the arduino-serial-monitor ...
    • R
      R
      ryanbrown204
      Do you have a schematic that you could post?
      • R ryanbrown204
        #43
        @ryanbrown204 welcome to the MySensors community!
        This is a long thread with a lot of different people posting, so it is a bit hard to guess which schematic you are looking for. Could you clarify?
        R 1 Reply Last reply
          R
          R
          ryanbrown204
          @mfalkvidd the schematic for the original 3-in-1 Humidity Temp and Motion. I would like to try me hand at building the first version and then adding the additions.
          • R ryanbrown204
            @ryanbrown204 temperature: https://www.mysensors.org/build/temp
            Motion: https://www.mysensors.org/build/motion
            See the first post in this thread for the modifications Konrad did.
            • F
              F
              fulljionslly
              This post is deleted!
              • F
                F
                fulljionslly
