  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.6k Views 35 Watching
  • AWIA AWI
    @flopp I had exactly the same problem with a solar powered node. I solved it by moving the battery measurement around in the sketch. The analog measurement is sensitive..
    F
    F
    flopp
    @AWI
    Ok I will try to put it somewhere else and also with some delay before reading analog.
    • AWIA AWI
      F
      F
      flopp
      Do you use voltage divider or direct from battery to analog input?
      I use direct from battery.
      AWIA 1 Reply Last reply
      • F
        F
        flopp
        Updated electric sketch with Connectors. This is useful if the battery gets empty then you need to disconnect Arduino so the battery can get charged.
        P 1 Reply Last reply
        • F flopp
          AWIA
          AWIA
          AWI
          @flopp a voltage divider as I use a rechargeable Li -cell (3.7 v)
          • F flopp
            P
            P
            pettib
            @flopp Maybe i miss something but I think the connector should be mounted between the battery and the Vin on the step-up. You mounted it on the A0, it´s just the voltage check port.
            In the original lamp there was what i think is a charge regulator between the solar cell and the batteri, did you keep that one or you just put the solar cell to the battery ?
            Thanks for a nice idé to use this lamp.
            F 1 Reply Last reply
            • P pettib
              F
              F
              flopp
              Thanks, I was to quick when adding the connectors
              I removed the small IC, YX8108. Below is a schematic for YX8108
              • F flopp
                P
                P
                pettib
                @flopp Is it the led or the solar cell that is working as light sensor ? If i remove the led and measure on the pins there is always power, even if it´s in daylight. So it should be possible to get the power to the step-up Vin from the LED pin, This way we can keep the on/off switch and the (YX8018) Mine is marked HW012.
                • P pettib
                  F
                  F
                  flopp
                  Solar.
                  First I used the YX8108 but I noticed as long as there is power out from solar(sunshine) the LED doesn't get any power, when the power is low(~0,3V) the LED gets power.
                  • F flopp
                    Solar.
                    P
                    P
                    pettib
                    @flopp I found this link. https://ez.analog.com/community/university-program/blog/2014/11/14/hacking-an-led-solar-garden-light
                    The strange thing is that i can´t get the power on the led pin to go low. But i will remove the IC anyway. I made one light 2 days ago but the battery was empty just the day after and i was not able to get it fully charged again. Maybe some bad connection. I will try a new one today.
                    • P pettib
                      F
                      F
                      flopp
                      @pettib
                      Did you remove the power from battery to Arduino when you tried to charge it again?
                      I tried to charge r battery for 1-2 days when I had arduino connected, didn't work. After I removed it and out the "lamp" in the sun for 5 hours I could connect the Arduino again and then I was on track again.
                      • F flopp
                        @pettib
                        P
                        P
                        pettib
                        @flopp I think it´s was some bad connections. The new one is working very good.
                        • P pettib
                          F
                          F
                          flopp
                          @pettib
                          Nice
                          • F flopp
                            update
                            I've let it be outdoor in the sun during 2-3 days now and it works well.
                            yesterday I took one of them and placed it in the garage, totally black whole day not even a lamp.
                            red line is when I moved it to the garage.
                            it is sending every 10 second. After ~20 hours the battery was to low to be able to run Pro Mini
                            dougD
                            dougD
                            doug
                            @flopp
                            Hi I know its a bit off topic but what controller are you using to create the graph?
                            • dougD doug
                              @flopp
                              AWIA
                              AWIA
                              AWI
                              @doug Not my turn :blush: but the Graphs are std. Domoticz..
                              • P
                                P
                                punter9
                                wrote on last edited by punter9
                                #35
                                side thought
                                why not write your sleep setting as a variable on the arduino side that is dependent on battery voltage?
                                if v>(full charge) sleep x hours
                                if v>(half charge) sleep for y hours
                                if v<(close to terminal voltage) sleep for z hours/days
                                • P punter9
                                  side thought
                                  F
                                  F
                                  flopp
                                  @punter9 said:
                                  side thought
                                  I don't see that it is needed. It will be no problem to send data every 30 min even when the sun is not shining. During a grey day I had vintage around 1.0-1.2.
                                  The idea is useful if you think/know that the solar will not charge your battery
                                  • F flopp
                                    @punter9 said:
                                    side thought
                                    P
                                    P
                                    punter9
                                    #37
                                    @flopp
                                    sure is, It looks like this sketch already has already picked a set single point sleep time that achieved the discharge gradient being less than the charge gradient looking at the angles on the 7 day graph.
                                    My question is why wouldn't you write an algorithm for your sleep setting so you don't have to mess with it if you get a cloudy week etc? You have variable charge gradients depending on weather so why not have a simple variable discharge gradient?
                                    A simple one would be case A - sunny day discharge gradient B- very cloudy day discharge gradient C- emergency charge/top off battery
                                    you could write an equation based off your existing data but honestly you probably wouldn't get much out of it past the simple set listed above that cover 99% of conditions you will see.
                                    • P punter9
                                      @flopp
                                      F
                                      F
                                      flopp
                                      @punter9 said:
                                      @flopp
                                      My question is why wouldn't you write an algorithm for your sleep setting so you don't have to mess with it if you get a cloudy week etc? You have variable charge gradients depending on weather so why not have a simple variable discharge gradient (or complex if you want to make an algorithm off the charted data) ?
                                      At the moment I don't need it. But if I see that the battery gets drained to much, because of bad weather, I may be use your idea.
                                      • P
                                        P
                                        punter9
                                        ha you are on it! caught me editing!
                                        anyways I love your idea, I can guarantee I am looking for these little lights to be on sale every time I go out. This maxes out the clever scale.
                                        • F
                                          F
                                          flopp
                                          wrote on last edited by flopp
                                          #40
                                          The "lamp"(silver) that I run out of battery seems to be damaged, two days ago it stopped sending data, last reported voltage was 1.13V which is good enough to work.
                                          Maybe the battery got damaged, it is a NiMh and I think they have some kind of memory?
                                          But why doesn't it get damage when you use the lamp as a lamp?
                                          Normally the lamp is charging the battery during the day and when it is dark it power on a LED which will lit until the battery is empty or maybe until the IC(YX8018) measure a low voltage.
                                          Today I change my second "lamp"(black) to a 1.2v AAA NiMh2 800mAh. I think this will help to not getting to low voltage during night.
                                          The battery that was included was mounted in the lid, I removed it and placed the new battery in the stick.
                                          I also made the stick little bit shorter, but don't make it too short because then you will measure the moisture at the top of the soil.
                                          The black round stick is 9 cm and the whole thing, when put togehter, is 28 cm from top(solar) to bottom(tip)
                                          gbgent_ncG 1 Reply Last reply
