  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.6k Views 35 Watching
  • NeverDieN NeverDie
    Interesting project. To what degree, if any, has corrosion been a problem after you switched to soldered connections? Obviously the operating environment (near the ground outdoors) can be intrinsically humid.
    Also, can someone please post a larger photo of how the sensor is attached at the base? The area of interest on the photo provided is miniscule, and it's too grainy if I try to enlarge it to a better size:
    NeverDieN
    NeverDieN
    By the way, I notice this guy has a rather interesting soil moisture sensor that appears to go beyond measuring mere electrical conductance: https://www.tindie.com/products/Power_Modules/fdr-100mhz-plant-soil-sensor-mineral-transparency/
    mrwombleM 1 Reply Last reply
    • AWIA
      AWIA
      AWI
      @flopp Can you please include the pictures in your posting as the "tinypic.com" is rather intrusive, thanks...
        F
        F
        flopp
        wrote on last edited by flopp
        #63
        I have not checked how the sensor look like now, but I have only run it for 6 months. I have always used soldered connections.
        1_1479545970922_20160606_131714652_iOS.jpg 0_1479545970922_20160606_131710115_iOS.jpg
        NeverDieN 1 Reply Last reply
        • AWIA
          AWIA
          AWI
          @flopp Just copy the area's of intrest with a "snipping tool" (screen print) and copy in the post. Or, use one of the less intrusive services of the big cloud names...
            mrwombleM
            mrwombleM
            mrwomble
            @NeverDie
            Interesting, but would make the project a little pricey.
            • F flopp
              NeverDieN
              NeverDieN
              #66
              @flopp
              Perfect! Thanks a bunch. I like it. Very clever.
              I think you were wise to cover the insulated wire with the silicon. Despite the appearance of being waterproof, I've noticed that regular wire insulation isn't waterproof/vaporproof, and regular wires used outdoors don't survive well (especially "copper" wires from China, which tend to have a high iron content and thus literally rust their way to failure). I don't know that silicon is sufficient, but if it isn't it might at least slow down the degradation process. It takes some effort to put these things together, so plainly you want them to last as long as possible.
              Nice work!
              Nca78N 1 Reply Last reply
                @flopp
                Nice work!
                Nca78N
                Nca78N
                wrote on last edited by Nca78
                #67
                Silicon is water proof, but not vapor proof. Else, it would not cure ;)
                • F
                  F
                  flopp
                  #68
                  I have put glue on top of the soldering
                  • F
                    F
                    flopp
                    #69
                    WARNING!!!
                    I opened one of my items which didn't worked since many weeks ago.
                    I putted it on a table and should just open the stuff when I saw some brown water coming out from the pole.
                    My first guess was that it was water mixed with mud but the smell was strange. It can be that the battery has leaked.
                    If you will build this item please seal the battery to 100%. I just put the battery in the pole but unfortunately water came in and what I think destroyed the battery!
                    Be careful
                    • F
                      F
                      flopp
                      #70
                      Just wanna update you all how the battery has been since start.
                      No restart since 1st September.
                      A few days ago we moved the plant indoor and I forgot to take out the sensor, I moved the sensor outdoor the day after
                      • HuczasH
                        HuczasH
                        Huczas
                        @flopp is your code should work with new version of gateway 2.1.1?
                        Just maked using this tutorial my gateway https://www.mysensors.org/build/raspberry and I'm getting nothing in debug...
                        pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
                        mysgw: Starting gateway...
                        mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: !TSM:INIT:TSP FAIL
                        mysgw: TSM:FAIL:CNT=1
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:FAIL:RE-INIT
                        In node I used your newest code for gw2.0 - is this because version mismatch or something different in my setup?
                        Could you update your code to work with new version?
                        F 1 Reply Last reply
                        • HuczasH Huczas
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:FAIL:PDT
                          F
                          F
                          flopp
                          @Huczas
                          I don't use 2.1, yet. I only use 1.5.1.
                          I don't have any knowledge of 2.x, so I cannot update the code, sorry
                          HuczasH 1 Reply Last reply
                          • F flopp
                            @Huczas
                            HuczasH
                            HuczasH
                            Huczas
                            @flopp just release that @mrwomble was posting that updated code sorry. @mrwomble can you help?
                            • H
                              H
                              hiddenuser
                              Hello All,
                              Wondering if any one of the successful implenters would be able to share their soil moisture graphs,both for a day and over months..
                              • D
                                D
                                dmonty
                                To solve the battery discharge memory issue, could a second battery be added with logic to alternate between batteries and fully discharge one at a time?
                                  Charge memory is a thing of the past, lithium batteries don't have it (if I understood what you meant).
                                    NeverDieN
                                    NeverDieN
                                    #77
                                    @gohan said in Solar Powered Soil Moisture Sensor:
                                    Except that, if I'm not mistaken, he's presently re-using the NiCd's that came with the original solar garden light.
                                    [Edit: correction: I think maybe (?) he switched to Nimh. I didn't think those had a memory problem. Do they? ]
                                    [Edit2: Maybe he'll "upgrade" to a supercap. :) A soil moisture meter would be a good application for one. ]
                                      NiMh still have some charge memory but not as bad as the NiCd. I got the moisture sensors yesterday I have to test them the next days.
                                      https://www.aliexpress.com/item/Soil-Moisture-Sensor/32532715392.html
                                      • R
                                        R
                                        ricorico94
                                        I started building this great idea of solar powered soil moisture sensor. Not integrated yet in a solar light as above, but still on my desk.
                                        I tested the sensor in salted water and I get a report of 78% moisture : based on your experience, is it normal ? Then I pushed the sensor in a very humid plant pot and read 71%. I would have expected mroe differenc ecompared to salted water.
                                        So, would you advise to caliber ? I guess I could modify the calculation formula in the script..
                                        Precisely, is it possible with Mysensor technology and Domoticz to push to a sensor a new setting (for instance to caliber using Domoticz each different sensor) ?
                                        And another question.. Is it possible to ask Domoticz to show the result of moisure reading in the Weather or Measures category rather than in the Temperature menu ?
                                        br,
                                        Ricorico94
