  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.8k Views 35 Watching
  • F flopp
    @pettib said:
    @flopp Maybe i miss something but I think the connector should be mounted between the battery and the Vin on the step-up. You mounted it on the A0, it´s just the voltage check port.
    Thanks, I was to quick when adding the connectors
    In the original lamp there was what i think is a charge regulator between the solar cell and the batteri, did you keep that one or you just put the solar cell to the battery ?
    I removed the small IC, YX8108. Below is a schematic for YX8108
    P
    P
    pettib
    @flopp Is it the led or the solar cell that is working as light sensor ? If i remove the led and measure on the pins there is always power, even if it´s in daylight. So it should be possible to get the power to the step-up Vin from the LED pin, This way we can keep the on/off switch and the (YX8018) Mine is marked HW012.
    F 1 Reply Last reply
    • P pettib
      F
      F
      flopp
      Solar.
      First I used the YX8108 but I noticed as long as there is power out from solar(sunshine) the LED doesn't get any power, when the power is low(~0,3V) the LED gets power.
      P 1 Reply Last reply
      • F flopp
        Solar.
        P
        P
        pettib
        @flopp I found this link. https://ez.analog.com/community/university-program/blog/2014/11/14/hacking-an-led-solar-garden-light
        The strange thing is that i can´t get the power on the led pin to go low. But i will remove the IC anyway. I made one light 2 days ago but the battery was empty just the day after and i was not able to get it fully charged again. Maybe some bad connection. I will try a new one today.
        • P pettib
          F
          F
          flopp
          @pettib
          Did you remove the power from battery to Arduino when you tried to charge it again?
          I tried to charge r battery for 1-2 days when I had arduino connected, didn't work. After I removed it and out the "lamp" in the sun for 5 hours I could connect the Arduino again and then I was on track again.
          • F flopp
            @pettib
            P
            P
            pettib
            @flopp I think it´s was some bad connections. The new one is working very good.
            • P pettib
              F
              F
              flopp
              @pettib
              Nice
              • F flopp
                update
                I've let it be outdoor in the sun during 2-3 days now and it works well.
                yesterday I took one of them and placed it in the garage, totally black whole day not even a lamp.
                red line is when I moved it to the garage.
                it is sending every 10 second. After ~20 hours the battery was to low to be able to run Pro Mini
                dougD
                dougD
                doug
                @flopp
                Hi I know its a bit off topic but what controller are you using to create the graph?
                AWIA 1 Reply Last reply
                • dougD doug
                  @flopp
                  AWIA
                  AWIA
                  AWI
                  @doug Not my turn :blush: but the Graphs are std. Domoticz..
                  • P
                    P
                    punter9
                    wrote on last edited by punter9
                    #35
                    side thought
                    why not write your sleep setting as a variable on the arduino side that is dependent on battery voltage?
                    if v>(full charge) sleep x hours
                    if v>(half charge) sleep for y hours
                    if v<(close to terminal voltage) sleep for z hours/days
                    • P punter9
                      side thought
                      F
                      F
                      flopp
                      @punter9 said:
                      side thought
                      I don't see that it is needed. It will be no problem to send data every 30 min even when the sun is not shining. During a grey day I had vintage around 1.0-1.2.
                      The idea is useful if you think/know that the solar will not charge your battery
                      • F flopp
                        @punter9 said:
                        side thought
                        P
                        P
                        punter9
                        #37
                        @flopp
                        sure is, It looks like this sketch already has already picked a set single point sleep time that achieved the discharge gradient being less than the charge gradient looking at the angles on the 7 day graph.
                        My question is why wouldn't you write an algorithm for your sleep setting so you don't have to mess with it if you get a cloudy week etc? You have variable charge gradients depending on weather so why not have a simple variable discharge gradient?
                        A simple one would be case A - sunny day discharge gradient B- very cloudy day discharge gradient C- emergency charge/top off battery
                        you could write an equation based off your existing data but honestly you probably wouldn't get much out of it past the simple set listed above that cover 99% of conditions you will see.
                        • P punter9
                          @flopp
                          F
                          F
                          flopp
                          @punter9 said:
                          @flopp
                          My question is why wouldn't you write an algorithm for your sleep setting so you don't have to mess with it if you get a cloudy week etc? You have variable charge gradients depending on weather so why not have a simple variable discharge gradient (or complex if you want to make an algorithm off the charted data) ?
                          At the moment I don't need it. But if I see that the battery gets drained to much, because of bad weather, I may be use your idea.
                          • P
                            P
                            punter9
                            ha you are on it! caught me editing!
                            anyways I love your idea, I can guarantee I am looking for these little lights to be on sale every time I go out. This maxes out the clever scale.
                            • F
                              F
                              flopp
                              wrote on last edited by flopp
                              #40
                              The "lamp"(silver) that I run out of battery seems to be damaged, two days ago it stopped sending data, last reported voltage was 1.13V which is good enough to work.
                              Maybe the battery got damaged, it is a NiMh and I think they have some kind of memory?
                              But why doesn't it get damage when you use the lamp as a lamp?
                              Normally the lamp is charging the battery during the day and when it is dark it power on a LED which will lit until the battery is empty or maybe until the IC(YX8018) measure a low voltage.
                              Today I change my second "lamp"(black) to a 1.2v AAA NiMh2 800mAh. I think this will help to not getting to low voltage during night.
                              The battery that was included was mounted in the lid, I removed it and placed the new battery in the stick.
                              I also made the stick little bit shorter, but don't make it too short because then you will measure the moisture at the top of the soil.
                              The black round stick is 9 cm and the whole thing, when put togehter, is 28 cm from top(solar) to bottom(tip)
                              gbgent_ncG 1 Reply Last reply
                              • F
                                F
                                flopp
                                #41
                                To have in mind
                                If you use the lamp with silver stick, it is metal, then remember to protect the battery if you but the battery in the stick.
                                Use hot glue at the top around the solar otherwise rain will stay between the solar and the place where it is mounted. I don't get water inside where the electronics are but you never know what will happen after a few month.
                                I have some problem with my black lamp it is rust on the positive connection, today it stopped working because if this, I had to remove the connection and put it back.
                                Recommend to solder the cable instead of using connectors, which I do0_1467323921262_image.jpeg
                                Nca78N 1 Reply Last reply
                                • F flopp
                                  To have in mind
                                  wrote on last edited by Nca78
                                  #42
                                  First, thank you very much for making these tests, I found some similar garden lamps in a local store and thought they were cheap so I bought one to have a look. Seems they were not so cheap as I paid nearly 3$ despite living in a developing country :D
                                  I will make a test with it as soon as I find a step up accepting the 1.xV of the battery, but I'm not sure if it will really work as the battery inside mine is a tiny V80h with a very limited 60mAh capacity, not sure if it will survive the sending of data...
                                  Recommend to solder the cable instead of using connectors, which I do!
                                  I would put some hot glue there too, no ? When all connections are checked and the board is running fine you could even sink the whole electronic in hot glue to solve these problems "forever" ?
                                  • Nca78N Nca78
                                    F
                                    F
                                    flopp
                                    Thank you. $3 is not bad but expensive compared to mine :)
                                    This is what I use as step-up, search for that product you will find cheaper than $1.49
                                    http://www.ebay.com/itm/DC-DC-0-8-3V-to-3-3V-Step-UP-Boost-Power-Board-Module-Converter-Voltage-RF-/282029936915?hash=item41aa4b5113:g:3GAAAOSw1DtXLS7Q
                                    Yes, why not, sounds like a good idea. But keep TX, RX, RESET and GND available to be able to update the sketch
                                    • F flopp
                                      gbgent_ncG
                                      gbgent_ncG
                                      gbgent_nc
                                      @flopp you attached your sensors by two differant methods. Which methods seems to be working the best?
                                      • gbgent_ncG gbgent_nc
                                        F
                                        F
                                        flopp
                                        @gbgent_nc
                                        The sensor itself is connected the same way, A4 and A5 on both. @gbgent_nc if you mean that one is glued, that is difficult to say if it makes any difference. I tried lamp1 and 2 in same soil but they always had ~10% difference, I also tried same sensor both glued in same soil still difference. You have to measure until the flower/vegetable is dry and check your percentage after this you can set an alarm on that percentage. E.g. I have spices with 30% when it is dry and a flower that right now is 20% and not dry, maybe different soil etc.
                                        I recommend to glue the sensor on the arrow, otherwise it is very difficult to remove the lamp from soil, the sensor with stay in soil and you have to dig it out :)
                                        I had a test with a cap connected to my voltage measurement A0, but it didn't make any difference. No need to use Cap.
                                        I use other battery on one "lamp" only to be able to measure many days without sun.
                                        Today I have 3 lamps, yesterday number 3 was put in the soil. I now measure every hour, before every 30 minutes.
                                        • P
                                          P
                                          punter9
                                          I have a couple soil sensors running with simple bolts in the ground. No two sensors will read the same in the same soil, but that is because they are just a relative setup not an accurate setup. Doing what is recommended above is necessary. Determine what % correlates to watering time on the plants. Once this is done it is set and forget.
                                          Also, on your batteries
                                          "The phenomenon itself is very real. If a NiCd battery is repeatedly charged after it has only been partially discharged it will develop a lower voltage and a lower capacity. Fortunately, this effect is reversible by conditioning NiCds."
                                          So I vote to help your poor cheap lamp batteries out by writing logic into your arduino that varies by battery voltage. You can write it in ranges
                                          battery > X volts report every Y minutes
                                          battery > Z volts report every P minutes
                                          battery > .....etc
                                          also to keep your battery in good shape you may consider every so many days ( 2 - 5 ) writing logic that says
                                          every Q days report every 20 seconds (or another interval that will drain battery) until battery voltage = min
                                          then
                                          sleep until battery voltage = max
