  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • DickD
    DickD
    Dick
    DHT22 2x with LDR working node but I want the RelayWithButtonActuator integrate in it. Who can help me with that?
    This is what I have and working but without the RelayWithButtonAcuator.
    #include <DHT.h>
    #define CHILD_ID_HUM1 0
    #define CHILD_ID_HUM2 1
    #define CHILD_ID_TEMP1 3
    #define CHILD_ID_TEMP2 4
    unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
    DHT* dht[2];
    byte sensorPin[2] = {3, 4};
    float lastTemp[2] = {0.0, 0.0};
    float lastHum[2] = {0.0, 0.0};
    boolean metric = true;
    //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
    //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
    gw.begin();
    for (int i = 0; i < 2; i++)
    dht[i] = new DHT;
    dht[i]->setup(sensorPin[i]);
    gw.sendSketchInfo("Humidity", "1.0");
    gw.present(CHILD_ID_HUM1, S_HUM);
    gw.present(CHILD_ID_HUM2, S_HUM);
    gw.present(CHILD_ID_TEMP1, S_TEMP);
    delay(dht[i]->getMinimumSamplingPeriod());
    float temperature = dht[i]->getTemperature();
    if (isnan(temperature))
    Serial.print(F("Failed reading temperature from DHT"));
    Serial.println(i);
    else if (temperature != lastTemp[i])
    lastTemp[i] = temperature;
    if (!metric)
    temperature = dht[i]->toFahrenheit(temperature);
    //gw.send(msgTemp.set(temperature, i));
    Serial.print(F("T"));
    Serial.print(i);
    Serial.print(F("= "));
    Serial.println(temperature);
    float humidity = dht[i]->getHumidity();
    if (isnan(humidity))
    Serial.print("Failed reading humidity from DHT");
    Serial.println(i);
    else if (humidity != lastHum[i])
    lastHum[i] = humidity;
    //gw.send(msgHum.set(humidity, 1));
    Serial.print(F("H"));
    Serial.print(i);
    Serial.println(humidity);
    gw.sleep(SLEEP_TIME); //sleep a bit
      I think you'll find https://forum.mysensors.org/topic/2597/combining-mysensors-examples and https://forum.mysensors.org/topic/888/combining-sketches useful.
      DickD 1 Reply Last reply
        DickD
        DickD
        Dick
        @mfalkvidd
        Thankt you for the reply, I used the instructions already but After 1 week of testing all solutions and nothing worked, I ask for help. I know, I lerned a lot by experimenting but Now I want a solution so I can try to understand what went wrong, ha ha.
        • DickD
          DickD
          Dick
          is somebody interested in challanging my problem?
          BartEB 1 Reply Last reply
          • DickD Dick
            BartEB
            BartEB
            BartE
            @Dick please note: i did not test it on an actual node but this combination should work
            #include <DHT.h>
            #include <Bounce2.h>
            // RelayWithActuator stuff
            #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
            #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
            #define CHILD_ID 5   // Id of the sensor child
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            bool state;
            MyMessage msg(CHILD_ID,V_LIGHT);
            #define HEARTBEAT       10
            unsigned int     timer = 0;
            #define SLEEP_TIME      3000
            DHT* dht[2];
                dht[i] = new DHT;
              gw.sendSketchInfo("HumidityAndRelay", "1.0");
               // Setup the button and Activate internal pull-up
              pinMode(BUTTON_PIN,INPUT_PULLUP);
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              gw.present(CHILD_ID, S_LIGHT);
              pinMode(RELAY_PIN, OUTPUT);
              state = gw.loadState(CHILD_ID);
              timer = 0;
              gw.process();
              timer++;
              if (timer > (SLEEP_TIME / HEARTBEAT))
                // Reset timer again and for the next timed loop
                timer = 0;
                    Serial.println(i);
                    if (!metric)
                    Serial.print(i);
                    Serial.println(i);
                    Serial.print(i);
              // Get the button update state (true if a change was detected)
              if (debouncer.update() && debouncer.read() == 0) {
                  gw.send(msg.set(state?false:true), true); // Send new state and request ack back
              gw.wait(HEARTBEAT); //sleep a bit
              if (message.isAck()) {
                 // Change relay state
                 state = message.getBool();
                 // Store state in eeprom
                 gw.saveState(CHILD_ID, state);
                 // Write some debug info
                 Serial.print(message.sensor);
            • BartEB BartE
              #include <DHT.h>
              #define RELAY_ON 1
              #define RELAY_OFF 0
              bool state;
              DHT* dht[2];
                  dht[i] = new DHT;
                timer = 0;
                gw.process();
                timer++;
                  timer = 0;
                      Serial.println(i);
                      if (!metric)
                      Serial.print(i);
                      Serial.println(i);
                      Serial.print(i);
              DickD
              DickD
              Dick
              @BartE
              It works fine but the relay does not stay ON after changing the status from "0" to "1".
              Another thing is that the light messuring part is missing, it was the the script I posted. I will try to get it implemented in yours. So If you know how to change the behaviour of the relay, I should appreciate it.
              • DickD Dick
                @BartE
                BartEB
                BartEB
                BartE
                wrote on last edited by BartE
                @Dick how does relay exactly response to the button?
                If you press the button (and keep it down) is the relay turned on?
                or is it switched on when you release the button again?
                The button can be "reversed" connected (on = off and off - on)
                You can play a bit with this line
                if (debouncer.update() && debouncer.read() == HIGH) {
                or
                if (debouncer.update() && debouncer.read() == LOW) {
                and how is the button wired? Does is connect to ground or to Vcc (5 volt) ?
                This sketch requires connection to ground (with internal PULL-UP)
                About the light measuring ?? i just did copy your example from the first post and copied the RelayWithSwitch example in it. (Please notice the message part of sending humidity and temperature are still commented out as in the posted sketch)
                The part i did add my self is the timer stuff (so keeping the switched being probed while the DHT sensor is only probed twice a minute)
                Cheers BartE
                • BartEB BartE
                  or
                  Cheers BartE
                  DickD
                  DickD
                  Dick
                  @BartE The button connect to gnd to switch. if connected to gnd the relay switch for a second and than again in rest, also if I keept the switch to gnd so it is momentory.
                  Also about the light sensor integration as stated in my last meassage, I was experimenting I only get an error BOLTED in my script "no matching function for call to 'MyMessage::MyMessage(int, mysensor_data, mysensor_data)'"
                  #include <DHT.h>
                  #define CHILD_ID_LIGHT 0
                  #define LIGHT_SENSOR_ANALOG_PIN 0
                  #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
                  #define BUTTON_PIN A1 // Arduino Digital I/O pin number for button
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  bool state;
                  MyMessage msg(CHILD_ID,V_LIGHT, V_LIGHT_LEVEL);bolded text
                  int lastLightLevel;
                  DHT* dht[2];
                  dht[i] = new DHT;
                  gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                  timer = 0;
                  gw.process();
                  timer++;
                  timer = 0;
                  Serial.println(i);
                  if (!metric)
                  Serial.print(i);
                  Serial.println(i);
                  Serial.print(i);
                  int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                  //Serial.println(lightLevel);
                  //gw.send(msg.set(lightLevel));
                    //lastLightLevel = lightLevel;
                    Serial.print("L=");
                  • DickD Dick
                    #include <DHT.h>
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    bool state;
                    int lastLightLevel;
                    DHT* dht[2];
                    dht[i] = new DHT;
                    timer = 0;
                    gw.process();
                    timer++;
                    timer = 0;
                    Serial.println(i);
                    if (!metric)
                    Serial.print(i);
                    Serial.println(i);
                    Serial.print(i);
                      Serial.print("L=");
                    DickD
                    DickD
                    Dick
                    @Dick
                    I get some closer but not complete working. Did also some playing met de debounce but no result. here the script till now with the error log
                    italicised texttempHumand_relay:24: error: redefinition of 'MyMessage msg'
                    tempHumand_relay:23: error: 'MyMessage msg' previously declared here
                    E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void setup()':
                    tempHumand_relay:43: error: 'incomingMessage' was not declared in this scope
                    E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void loop()':
                    tempHumand_relay:151: error: a function-definition is not allowed here before '{' token
                    tempHumand_relay:171: error: expected '}' at end of input
                    and now the code till now
                    #include <DHT.h>
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    bool state;
                    int lastLightLevel;
                    DHT* dht[2];
                    dht[i] = new DHT;
                    timer = 0;
                    gw.process();
                    timer++;
                    timer = 0;
                    Serial.println(i);
                    if (!metric)
                    Serial.print(i);
                    Serial.println(i);
                    Serial.print(i);
                      Serial.print("L=");
                    bolded text
                    • BartEB
                      BartEB
                      BartE
                      @Dick
                      Couple of remarks
                      This peice of code tries to declare the same variable twice (msg)
                      change to name to msgLight and msgLightLeven
                      MyMessage msgLight(CHILD_ID,V_LIGHT);
                      MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                      You also have to changethis line:
                      to this
                      gw.send(msgLight.set(state?false:true), true); // Send new state and request ack back
                      Also this line
                      needs to be adapted to
                      gw.send(msgLightLevel.set(lightLevel));
                      And i think the last } needs to be removed
                      Oh and please use the code mark up function for posting source code
                      (by using the </> icon)
                      • BartEB BartE
                        @Dick
                        Couple of remarks
                        to this
                        Also this line
                        DickD
                        DickD
                        Dick
                        thank you Bart, I am learning with these adjustment, how things work together aso. I change the code as you mentioned and still getting verifying errors as included. I hope you can help me so I can finish this, for me not so easy project.
                        tempHumand_relay:130: error: 'msgLightLevel' was not declared in this scope
                        tempHumand_relay:145: error: 'msgLight' was not declared in this scope
                        tempHumand_relay:170: error: expected '}' at end of input
                        • DickD Dick
                          DickD
                          DickD
                          Dick
                          does anyone know how to go on with the final part of this project?
                          • DickD Dick
                            DickD
                            DickD
                            Dick
                            Compilation finished without errors.
                            but I sea nothing on my serial monitor. What could be the issue?The script is now
                            #include <DHT.h>
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            bool state;
                            MyMessage msgLight(CHILD_ID,V_LIGHT); MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                            int lastLightLevel;
                            DHT* dht[2];
                            //gw.begin(incomingMessage, AUTO, true);
                            dht[i] = new DHT;
                            timer = 0;
                            gw.process();
                            timer++;
                            timer = 0;
                            Serial.println(i);
                            if (!metric)
                            //gw.send(msgTemp.set(temperature, );
                            Serial.print(i);
                            Serial.println(i);
                            Serial.print(i);
                              Serial.print("L=");
                              Is DEBUG enabled in MyConfig.h? If it isn't, you'll see nothing from MySensors on the serial monitor.
                              If you want your own serial prints to be visible, you need to run
                              Serial.begin(9600);
                              (or whatever speed you want to use in the Serial Monitor) inside setup().
                              You have commented out gw.begin. That means MySensors will not be started. If you don't want to handle incoming messages yet, you can use
                              gw.begin();
                                Serial.begin(9600);
                                gw.begin();
                                DickD
                                DickD
                                Dick
                                debug is enabled and I change gw.begin () and it worked, I see temp and two hum mesurements. But also my relay is uncontroling switching every secunds and the changing is not visible in the monitoring window. has that something to do with the
                                gw.begin(incomming
                                change?
                                  Try commenting out
                                  until you are ready to handle incoming messages.
                                    Try commenting out
                                    DickD
                                    DickD
                                    Dick
                                    I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
                                      Change the following in the setup
                                      pinMode(BUTTON_PIN, INPUT);
                                      digitalWrite(BUTTON_PIN, HIGH);
                                      This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
                                      // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
                                      #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                                      #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      #define NODE_ADDRESS 2
                                      int oldValue=0;
                                      bool state;
                                        gw.begin(incomingMessage, NODE_ADDRESS, true);
                                        gw.sendSketchInfo("Relay & Button", "1.0");
                                       // Setup the button
                                        pinMode(BUTTON_PIN,INPUT);
                                        // Activate internal pull-up
                                        gw.process();
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                        if (value != oldValue && value==0) {
                                        oldValue = value;
                                      • alexsh1A alexsh1
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValue=0;
                                        bool state;
                                         // Setup the button
                                          gw.process();
                                          debouncer.update();
                                          oldValue = value;
                                        DickD
                                        DickD
                                        Dick
                                        thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
                                        alexsh1A 1 Reply Last reply
                                        • DickD Dick
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
                                          I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
                                          I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
